Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 11-12-2009, 11:33   #101
warren_cox
Back from the dead
warren_cox's Avatar
warren_cox has 20 points
http://picasaweb.google.com/warrenco...CamLobeNewOEM#
New cam lobe turned up yesterday from JKM (with a Cadbury's chocolate which was a bonus).
Will get out and fit it tonight / compare.
__________________
Panther Black Audi S3 Black Edition 3dr MY12
warren_cox is offline   Reply With Quote
Old 11-12-2009, 11:45   #102
m0rk
sarcasm comes free
m0rk's Avatar
m0rk has 100 pointsm0rk has 100 points
How much are the replacement parts?
__________________
[/right]
m0rk is offline   Reply With Quote
Old 11-12-2009, 11:46   #103
warren_cox
Back from the dead
warren_cox's Avatar
Quote:
£22 so not too bad. I'm not looking forward to fitting it, but only in so much as it's cold and I'm idle!
__________________
Old 11-12-2009, 11:48   #104
m0rk
sarcasm comes free
m0rk's Avatar
No brainer then to replace that periodically at that price. How old is your current one?
It's very nippy outside, and handling cold tools & car just isn't fun!
__________________
[/right]
Old 11-12-2009, 11:51   #105
warren_cox
Back from the dead
warren_cox's Avatar
Like the front brake pads it has somehow done 32k without replacement!
The cars been a bit lumpy in the acceleration recently and a bit bizarre at cold start, so having checked all the pipes for leaks and having found nowt (esp. since I've got the Forge end cap for the inlet manifold instead of the BSH catch can cover which was pap).
Only other thing I can check is the new plugs. Maybe the colder plugs don't like this cold weather so I should look at putting the hotter ones in over Xmas / winter?
Two weeks ago I insulated the garage door with foil backed insulation, then put draught seals round the door so am hoping it may be manageable without arctic clothing on!
__________________
Old 23-12-2009, 10:58   #106
warren_cox
Back from the dead
warren_cox's Avatar
UPDATE
Went to Storm Developments in Aldermaston to get them to change the cam lobe for me.
Initial inspections found the cam lobe to be in pretty good nick. Outer face which contacts with the inlet camshaft was in good condition as it has done the full 33k miles (10k of which has sen the car running Stg 2 + with HP internals).
We then had a look at the inside, and there were fairly pronounced markings inside the cam lobe where the HPFP makes contact.
To be honest it's not terrible, and didn't look as it was likely to break through anytime soon, however it would lead you to believe the HPFP is creating more erosion on the cam lobe.
More interestingly (for me), I had them do some quick checks when they were there to make sure all was well, and they checked the spark plugs. The literally new NGK BKR7EIX Iridiums were looking VERY pink around the electrode which they were concerned about considering they have done 2-3k of very easy mileage. Admittedly I hadn't torqued the plugs up to the recommended 26(??) on the wrench (opting for hand tight + 1/2 turn for safety), but they have recommended trying the 8's for a short while then checking them again in 2-3k as they are concerned the high boost levels are still causing the plugs to suffer. I'll feedback in the new year as to the effects of this.
Here are a few more photos from the day:
1) My fuel pump
2) A spare OEM pump they had in stock
Some cars kicking about on the day
And a 5 hour journey home (12.4 mile journey) caught in Berkshires gridlock:
__________________
Old 23-12-2009, 15:05   #107
warren_cox
Back from the dead
warren_cox's Avatar
And some pics of the pink plugs:
__________________
Old 30-12-2009, 14:15   #108
RobH
Senior Member
RobH's Avatar
RobH has 30 points
interesting about the plugs i have had mine in for prob 8k now and havnt checked how there doing, maybe your running a tad lean on fuel which is causing them to overheat.
i think i may get mine checked now just incase although mines always run a bit rich which might make things a bit cooler, although i may be barking up the wrong tree aswell lol.
__________________
Audi S3 8v S-tronic
RobH is offline   Reply With Quote
Old 30-12-2009, 19:07   #109
Blade
Blade's Avatar
Blade has 10 points
Had a look at mine after doing 4k and they were perfect - so were the o/e plugs i took out after 12k
Blade is offline   Reply With Quote
Old 12-01-2010, 21:54   #110
vRSy
Fabia vRS
vRSy has 10 points
anyone have links to where i can get a set of these iridium spark plugs. and what set is best, i here things about some sets being a colder setting than others???7's and 8's etc
__________________
Mk 2 Fabia vRS 1.4TSI - APR Stage 3. Loba LO270 hybrid, VWR DP, VWR Intake, OKADA coilpacks, Devils Own WMI, Wossner Pistons, VWR Springs, Superpro poly bushes, H&R ARBs, VIBRAtechnik engine mounts, TD1.2 alloys, Tarox 6 pot BBK.
vRSy is offline   Reply With Quote
Old 12-01-2010, 21:59   #111
YIN
Leon cupra Mk2
YIN's Avatar
YIN has 10 points
Quote:
JKM sell them
http://www.jkm.org.uk/performance/tfsimisc.htm
YIN is offline   Reply With Quote
Old 12-01-2010, 22:05   #112
vRSy
Fabia vRS
vRSy has 10 points
what is the benefit of the one heat setting cooler malarky??
http://www.halfords.com/webapp/wcs/s...m_vc=IOV4PLPZ1
im running these at the moment
__________________
Old 05-02-2010, 11:46   #113
danston
Posts: n/a
have just changed mine, small amount of wear in top but nothing showing on cam, i still think better o be safe then sorry, it was VERT easy people.
Old 05-02-2010, 18:45   #114
dazjb69
Senior Member
dazjb69's Avatar
dazjb69 has 10 points
My 07 cupra is out of warranty next month and I was wondering if wear to the follower could cause the 'rough' sounding engine on tick-over that a lot of people have mentioned on here, the cars done 40,000 now and having owned it only from 36k I have no idea if this has been changed, maybe best to just change it?
dazjb69 is offline   Reply With Quote
Old 05-02-2010, 19:01   #115
MrT
Stole my radio!!
MrT's Avatar
MrT has 10 points
Quote:
Mine has done 60k (07) no rough sounds and never have changed the bucket on the cam in the pump, running SC BF and all appears to be well.
Having said that, the wear on on the bucket will probably be gruesome...........Hey ho!
MrT is offline   Reply With Quote
Old 15-04-2010, 21:50   #116
RobH
Senior Member
RobH's Avatar
RobH has 30 points
Now i know alot have been fine but kmd now do uprated ones just so you lot know .
Here you go - http://www.kmdtuning.com/index.php?_...productId=1426
__________________
Audi S3 8v S-tronic
Old 20-04-2010, 19:33   #117
K1Shane
336bhp 319 lb/ft
K1Shane's Avatar
K1Shane has 10 points
Re: Change in design of TFSi engine. Important issue with fuel pump and engine wear
I will be picking up my K1 on 1st of May. It's currently having Tyres replaced and a scratch in the glass. It's a 58 plate so still under warranty. Is it worth me getting them to double check while it's in?
K1Shane is offline   Reply With Quote
Old 20-04-2010, 19:35   #118
Poverty
Posts: n/a
Quote:
they wont check it foc, or they will tell you that they did but really havent.
Check it yourself when you get it home mate, takes 15 mins, stealers seem to think it takes 2 hours however
Old 20-04-2010, 19:53   #119
K1Shane
336bhp 319 lb/ft
K1Shane's Avatar
Hahahaha I'll giv ya a shout wen I pick it up. Am fairly confident with engines etc always used to solve my own problems with my cars. This is my 1st new new though car lol am always a bit more careful with these newer engines. Too many sensors and electrics etc so will need some advice
Old 11-05-2010, 15:22   #120
hawtin1584
hawtin1584 has 10 points
Anyone in the north west?
Anyone want to check mine for me, dont really know what im doing! £10 your way.
hawtin1584 is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 1690
-pseudonymous-, -SlicK, -UzY-, /dev/null, 1.8T, 10man, 140SPORT, 14k, 1Toomanycars, 2011LeonFR, 20vtB0b, 20vturbocupra, 22john, 22ssingh, 2die4, 2G, 3pointturn, 4/4 dirty dervs, 5imonharri5, 6moe66, 6th.replicant, 747_727, 8@nO$, 8bit, A.smith-Cupra, Aaron*, aaronb84, abbotsmike, abdullahb85, ablackcupra, Abs2788, acespizee, Adam's Cupra, adam1811, adam23, Adam83, adamb87, Adamm, AdamRoutley, adm013, Adman77, adrianofrcarlos, adulka, adz83, ADzABOUT, Aidso101, ajs14, aka, akg, akz, Al, Al3ks, alans, alesi27, alexj124, AlexK1, alexmsi, alexpb, alextt93, alijay, alionka, Ali_Hayes, Allan Andersen, AllanCupra, Allan_84, allbutt55, allisonbreed, Allsebrook2006, Almandino, Alnitak, alog4287, Alsh, Alunakis, alwaysinfront, alx_chung, Alzak, Amir_dan, ammar3689, andieleon, andpen, Andrei_Nick, AndrewJB, Andrewski, andrew_leon, Andy ap, Andy Bird, andy fr180, Andy McCombe, Andy,s.scfr184, andychef1234, andycupra, Andydavy, Andyg1978, AndyG_TSi, AndyH38, andymac123, andypower, andyspencer, andytaylor1980, Andy_FR, andy_lux, angy, anthony37, AnthonyDi, antipesto93, AntneeUK, Aok82, Ape, apsol, ArcticCupra, ares, ARi01, arsenalmorris, Art0ir, ARTTAY10, asasprey, Asce, ash101, ash3435, Ash5314, ashbash, ashthomas88, asifk, asilaydying1234, asquith_4, asthpsw, avendit, AwesomeAl, AwesomeHassan, AzzA Dobson24, B1rdy, b21playa, B5NGV, Babyface, Bacon, BagFullOfLeon, BAGZ, Baileyt, Bakes100, Balddee2, balls deep, bane_punk, banksy21, barnybullet, Barry-Lee, BarryB, batman1990, batwing, BazTango'd, bbob, Bbqforce10, Bedlam, beeko85, BeezerDiesel, belfastchris45, Ben CTR, Ben P, ben20VT, Ben750, ben@amdessex, benhampshire, benito, beniz, Benjic2, benrobbo, BEOWULF, bete noir, beterthanlife, betts, betty_swollox, BHP Addict, bibsen, BIBULENT, Big Dunc, big eck, Big Lee M, Big-Pete, bigbadjay, Bignod00, Big_Mikey_G, BIG_Y, Biker, Bikerz, bil44, billh, billyhas, birchy2010, BirdDog, bisto48, bjh_101, bjornatron, bkingb, BlackCupraa, BLACKNIGHT, Blade, Blades, blade_jo, Blaine, bloody_typical, bmb779, bobak, Bobanegra, bobphatboyphat, boditza, Bogwoppit, bondbill2k2, Bonzy1800, borderboy, borisvanhalen, Botor, boxster, Bozlin, BPrudence, bqd, Br!dges, BraddersThe3rd, brad_barker12, breedish, Breezapom, Bregt14, Bretty, Brinkz, bristolsparks, britishsligean, BrokenBones, Bronk, Browesy, BrownFox, Bruce GT3, Bruce-m, brucey1, BStones, bubba, bubbles1, Bully007, BumbleJC, burrell, Button, BUX FR170, Buzz123, bws, C.B, C3PRA, Cabbage, cadman2k, CalBrad420, calvR, campbell_p30, carlamos, carlt69, Carlymart, carl_ep91, carpboy, CatB1, cav, cawsey18, cdmalpass, cg11bby, cgrillo, Chambers_CUPRA, Chan_P1_TDi_FR, charisk123, charlesz1066, charlie boy, CharlieRCupes, Chemical Al, Chester, ChesterRover, cheungy, chilli, chopper-lew, chorlton, chr1sd, Chris B, Chris Bartram, chris1788, chris285, chrisb2284, chrisboyle999, ChrisCurzon, chrisf1903, ChrisGTL, chrisjgill, chrisjm29, chrispyvrs, ChrisSutherland, chrisw_mk2cupra, Chris_a_73, Chris_Cupra, chris_foci, chungster, cila555, Ciosmi, CJcupra, CJRamze, ckempo, Clark10, claroz, class2ldn, classic84, claudefrog, Clazzer, Clossie, CNleoncupra, cocadave, Colin C, Colledge87, colsy, ConnorWatt, coolantrs, Copey, corradophil, CoScolai, cossiedave, CovCupra, coxxic, cpcpeter, Crafoo, Craig D, Craig FR, Craig01988, craigboca, craigib76, craigy86, Crashapollo, crigisback, Crize, Crono, csd_19, CTID, cuky, Cupra Chris, cupra fan, Cupra Jim, Cupra Kev, CUPRA QRO, Cupra R, Cupra R Matt, Cupra Ross, cupra tda2, cupra yk1, cupra-ads, cupra-db, cupra-esx, Cupra-jay, cupra-tfsi, cupra.al, cupra123, cupra14, cupra2008, cupra2424, cupra29200, cupradan, CupraEst, CupraGTI16V, cuprakemp, Cupraken, cupralite, cupramillo, cupramk2, Cupranation, cupraNW, CupraR1, cuprar265, Cuprarob112, cuprarstu, CupraSport, cuprastoffs, CupraString, CupraTOC, CupraVAG, cupra_ahhh, Cupra_G, Cupra_Jay95, cupra_r_ick, Cupra_Wayne, CyborgCupraJQ, C_ED_99, D...B..., d11nyd, D8MNS, dafe01, Daffy, dainott2105, Dale_tem, Damon_, DaMouse, Dan FR, Dan.Payne, Dan07FR, Dan1720v, DandB, Dandle, DanGB, Dangerous Dave, DanH, Daniel H, daniel_18, danneth, dannocuprar, danny mk3 cupra, Danny-, danny20vt, Danny@INA, DannyC87, dannychapman10, Danny_FR, danpalmer, DansFR, Dan_90, Dan_FR_DSG, Dao, Darbo, Dario, darkhorse, darren2611, Darth Revan, Datapro0, dav, Dave 20vT, Dave 77, dave mac, dave.richmond, dave1814, DaveD, davej_anderson, Davescooby, DaveysFR, dave_ph, david.swanson, davo, davyboy, daz, Daz P, Daz031178, daz20vt, Daza, DAZFR72, dazjb69, DBD19, dbscupra, DCNI, ddc, deamer44, DeanJ, deanogee7, dearly beloved, Dearnie, Dec66mk2fr, Deebo, deebow, deepdragon, degzy, delboyuk2005uk, densil, Deplunk, DerbyForget, derelyth, dez22, dezthestig, dfort1uk2, dicky FR, diesel01uk, Diesel81, dieselface, DIFT, diggerbucket, DigiGuru, dijas, din_Shaz, Dirt Junkie, DJ-LIAMC, dj.bang, djscorch, DJ_Steve, DMackie, dmkay_80, dnahacker, doctor rage, dohc52uk, Donnyboy, dooresy, Dopedpanda, Dorny, Double B, Doug, Doughmac, dougiekillen, douglas10, Dr-LCR, drewFR, drizzlefizzzax, druddle, Dubslag, Dude, Dudemeister, dukebox9reg, duncinascoob, dustyivan86, dvinell, ecklad, eddiel34, Edgarasv, edgeog, edtheduck, effess, El Dingo, el leone, elfigo, Elliman98, ellsmacd, Emm, Emocion77, emsquared, EndlessNameless, EoinM, epts2008, Eric87, Eriedor, Erijaso, erminio, eta76, Evan@APR, evo2345, Evsi, ex888, fa11ows, Fahid82, Faisal, faisal1203, falzotti, FarisBB, fat andy, Fatal_Angel, fATCH, fellowsuk, Ferryman, fike, finchyboy....K1, fireblade929, Firefox75, firestorm, Fl@pper, FlameRevenge, Fluff, Foo56, Fordy_FR, ForgeMotorsport, fossie, fozzybear, FR Ritchie, FR+TDI, FR-LUMPIT, FR200, fr550, FrChappers, FReakingSeat, Frederic-cupra, freekie, Freewheelin', frodofast, frost87, fr_craig, FR_Kris, FSiLeonMike, fyfe9, G.P, G19RJS, G4reth, G5RBY, g60stu, Gabster, gac, GainfulShrimp, gammar, Gandi67, Gar3th, Gareth 265 R, gareth86, garetha1980, Gareth_1.8T, Gary S, Gary@Cookies, Gaz-04, Gaz20VT, gazbcupra, Gazbo22, Gazhill81, GazM, gazprice79, gazz01, Gazza_24, Geordie2001, Geordie_Paul, GeorgeChios, Georgel, gepsoh, Gex, gfarm101, GhostMjr, ghosty, GhulamAfzal11, Ghunter, gillygilbert, Ginner, giveadinet, Gixxer3000, Glovepup, GMInsite, Gnollins, goldie87, Golf-GTI-MK1, googies, Goot, Gracey, Graf1x, GrahamFR, Gray & Kirsty, GrayT, Grbeduff, greenocktriple, gregy_reynolds, GREG_R84, GREY 225, greyfloppyhat, GS16LRHP, gsdude, GtSport, gulzar, Guncha, gunnergibson, gunsdontkillppl, Gw19, H & H 2.3, habboub, Haddock, Hairy, Hamburgalarr, hamlyn, hamps_w, hara, Harris., harry171, Hartosh1, Has, has22fas, HasF, Havok316, Hawkers, Hawkins, hawtin1584, hayesey, hazzagrant, Hb69, Head on Fire, Healyrae, hedgehog-harvey, heggie, heliliam, hellowed, herbie147, Hilla LCR, hilly81, Hobbiniho, HotHatchSteve, HTarim, HuckingFell, Hud, Hudson, hulf_fr, hungabunga, hunggar, Hurdy, huvo, Hybrid, Hydrovert, IanG, Ibia FR 1.8T, IbizaAlex, ibizacupra, ibizajamie, IbizaTDI08, ibiza_1.4tdi, icemancupra, icestorm81, Ictoanuk, iDan, idjbell, Igor23, INA, Indy, indyr, InfernalBadger, Invicta, Invincible, Invisible, invisiblekid, IOMMAN, irf, itsmefishy, J0N, J0n3, J3PPY, J400uk, J500ANT, J888MYY, J@mes, jaba101, Jacey Boy, jackett, jackoni, Jairm88, jake, jakesbrakes, Jakeyz92, jam1, jamandspoon81, james.milroy, james12, JAMESYBOY-08, James_3, jamfool, JAMI3, Jamie55, JamieF, jamiegwillym, Jamiemerrilees1, Jamiethorley, Jamiex17, Jamie_k1, Jamie_Ldn, JamMar360, JamMonkey, Jammy78, Jarre, Jaruba, Javirero, Jay, jay-bob 25, jay87, JayCee, jaykicksass, Jaynemc, Jayz, jazza fr, JB21, JC, jcp, jc_boc, jds, Jedimaster65, jeff030379, jeffg, Jelly Baby, jendy, jez283, jezyg, jgy6000, jh1, Jhouse_101, Jhunter_83, Jimbobcook, jimboy, jimjamsco, jj06, JK1, JKM, jlecour, jma8299, jmc1976, jmcvicar, JMP, Jodrell, Joe M, joely, Joens, joestella28, Joe_3490, John-Cupra_TDI, john.s, johnbev, johnny_reyno, Johnstone, jon-tfsi, jonathanp, Jonezyfr, jonjay, Jonny, jonny1978, jonnyash, JonnyBCK, JonnyF, Jonnyruddick, jonovan82, JoonasFr, joostdeblok, Jordan359, Jordanlivi1, jordanogrady, jordyboy004, jorgii, Josh, JoshCupraR, Joshh, Joshkcupra, JoshRedCupra, joshwill, JP6, jpclarke, jreedy, jurand, Justa, justsean, Jwk, JWLeeson, J_280, K.S.D, K1 SNY, K1ROSEDAM, K1Shane, k1_cupra, k1_Joynesy, k1_tom, KarenJ, Karl db, Karl w, Kaza, kazand, KDV, KebabWarrior81, Keith Wood, Keithio, KELHAM, kenny_fr, Kenshi0001, kerem129, KernowFR, Kev Hall2, Kev07, Kevgrady, kevin1989, kevlaa, kevscupra, Kewster83, kezFR07, khaos, kidinspace, killbot, kiminauta3000, King of comedy, kingy89, kirkyboy3, Kiukas, Kneller, knight, Knight_Rider, knoted, koala5, kohmikey, koush, Kr1s0121, kr42yxx, krik, kroni, kryptik, kw1984, kwstasp, Kye69, kyleb123, KYLEB88, kylemartin93, Kylep943, L.R.C., L@on, Laidbackdaddy, lajohnz, Lally, LasseO, Lavery, Lcampbell_91, LCR User, lcr.kenny, LCR350, lcrb, lcrboy, LC_15, lc_allan, Lee M, Lee2.0tfsi, lee3011, lee3272, leeapole, leecupra240, leedscupra_r, leegriffiths, leemclellan, Leeoncupra, Legojon, Leigh15, lelilo, lemmentalja, Lentäjä, Leodis, leon cupra r, leon petrolhead, leon.il, Leon1600s, leon263, LeonCR, LeonDK, LeonFR07DSG, LeonFRDave, LeonFRMK1, LeonFRNik, LeonJamie, leonmk2cupra, leontdi130, leonvt2001, leon_in_uk, leon_lib, Leon_MHX, lesinge2k, leviathan18, LewisW, lexyy, lips10, Lisacupra, littlefella, liver-red, locky, Lodey23, lodge, lofer, lofty987, Londy, LONZO, lordgibbness, LOU ROB, lsg60, lsm, LucaFR86, lucifer666, Lucio Bravo, lugsy, luke101, lukecupra2001, LukeFR, lukey K1, Lukeyx, Lukeyy, Luke_buk, luke_h, lupocharged, m.001, M1C VX, M1KEH, m3eater, M477YEO, m4rtin, M600RKC, M6TT F, M7R, Mac, mach4, mackgold, Mad Jock, MadFaz, madfx, Madman0405, Madmile, magicmcfc, mainaman, maj81, makkakm, malaroo978, MalcB, Maln, Mandu, manhota, Manny, Marc87, marcosport, marcus.l, Marino, marjanot, mark-cupra, MarkE, markgb, Markkoni, markl, markm49uk, markmeus, markojay, marks_leon, mark_eisner, marraa, Marshall, martas4676, martin j., Martin P, martybelfasTfsi, martycupratdi, martziniuk, maryius, Mashburn, massouille, Masterkm, Matchman50, MathiasVN, matt-tsi, matt09, MATTCR, matthab, Matthewsarg, matty1000kk, Matty1986, matty_glanza, matt_s, matylad, mc funbot, mccracd, McZan, mdmay, Mdonno, mds1256, Memme112, metman9185, Mick288, micky 32, mihai_0507, Mike H, MIKE THOMPSON, mike000, mike0105, mike89, mikee66, mikef92, mikeymike, Mikey_P8, mike_allison, Mike_Leon, Millbo, miller 666, mini_racer, minority, miscreant, Misko, miss_cupraR, Mitchy, MitraShark, MJ, mk2 cupra r, mk4 cupra, mk4dub, MM95, mnkiboy, moggy, moggytom, mogsy, Moley RUFC, monk3y303, monkeynuts, monkgti, morini, moschopz, mosso, mouse1989, Mozza82, mozzer260185, Mr Bigglesworth, Mr Cellotape, Mr Scubatank, Mr&MrsS, MrDurst, MrFwibble, mrkev, mrowell, MrStevo, MrT, mrvavavoom, msz, mty12345, MUFFIN, muks11, Murdered LCR, murph81, mwat5on, MWG, MyCarSpares, mYGeL, n0ble, Nads123, nam, NAS23, Nath-leon, Nath., nath86, nathan., Nautilus, nc30rider, nealy578, Neel-Cupra, neeleyveeley, Nef, Neil82, NeilC, NeilMcK, NeilW, neil_1821, neil_f225, neo265, neon1, NewShoes, Newstarter, nibbles, Nick, nick-fr, Nick666, nickbrown_500, NickCupraR, NickLCR, NickP, NickShaw, Nick_TDi, NigelCupra, nikolai, nils 6l, NinjaPirateUK, Nobber, nog, noktoto, northern monkey, northernmonkey, Number12, Nutkin, NVM, NWhiteley, Octane2097, old yella, OLDLACE, OldManPooley, OLDOILER, OldSpeckledBen, olethalb, OliCupra, olip74, olitaylor07, Oliveracc, Olivermalyn, Osc, oscar-cupra, oswal, OU0Cupra, outstandingwork, OvniAl, owen lcr, ozaudio, ozzymyster, p11lkw, P13ULC, pagey198, Pander, Par, Pat15312, Paul B2010, Paul Cupra R, Paul197, paul7619, paulfs, paulgtir, PaulieB, Paulki, PaulLFR, paulplom, Paulr89, paulw2427, Paul_W, paul_zx6r, pavel1771, PBrowny86, Pedestrian, pedxxx, Penguin, penny58k1, Peppermuncher, Petecog79, Peter 87, peter3hg, PeterS, petrolhead, PH1L NI, Pheo, phil 9289, phillbriggs, phillyhall, PHILMEWAGON, PhilYerBoots, phil_monk31, Pigeon142, Pinocchio, PiperRS, pj1985, PlatinumCupra, plipman, PLuKE, PnP, pointypatrol, Poko, POLMAN, Poochy, POPOV, porksword28, Povke, powly1621, PPHenry, pr0xy, predo, prezf, probee, Proby, processpaul, Project1P, ProSpec, pstables, PSV6, Ptar64, ptycupra, Pure:Torque, push, putridmocha, pwskingle, qczarq, Quadrablast, QuietQuackers, quintonrose, R 20vt J, r1kbo, r30lac, r401caw, R4cup, racer66, Racheluk, Rael, RafLad, Rafterman79, ragazzi, rageuk, ragga63, Raider, Rallye Dale, ramborobert, Rampage, Rarpuc, rastajambo, Ray_n_Debs, RazorBoy, realneal00_0, Red ibiza, redcupra07, Redemption, RedFive, Redgie, redkite, RedR, redreligion, RedRob83, reece1591, reesy, Revo Kev, Revon, Rhys Beal, ri5t0, Rich12885, Richard D, RichardB, richardc, RichFR, richibiza, richicupra, RichN, Richoscos, richserena2310, Richy!!!, richybigman, Rich_Derv, RickyD1975, rickyleon, Rigla, riker, Rikman, rikwandi, rik_t, Rivva, rllmuk, Rob FR TDi, Rob GTI, Rob-Cupra, Rob66, rob929, Robbo73, robbob, robcorkhill, ROBD--M15RPD, robdf2, RobDon, Robert Barnes, RobFR, RobH, robin cur, robin_nerf, robjnr, robo2731, RobsCupra, robt880, robthebubble, Rob_B, rockape, rocket_26_, Rodie121, RodneyA, roiLaredo, Romigo, Ron Conno, Ronin225, Rorza, ross27, rosshutchie, Rosskie, rpmleon, rryans11, RSBUBBA, rsrich, rsulam, rsx, rs_jon, Rua1r1, rudgey, Ruff Ryder, Ruffy, RuidCi, Russ3474, Russ_tdi, Rusty Nuts, Rusty2k, rv2583, Ryanoceros, ryehorse, rödcupra, S2TTB, s3atl3onFR, s700 mcv, saintelise, Sam89, sambryant, Sammae, sando88, Sano, Sast, satli, sau, Scby555, scoota80, Scott.T, Scottmf, scotty026, scotty1310, ScrapMechanic, sd123sd, seagully, SeanCorky, Seanographer, SeanyK, Seat racer, SEATCOOBER, seatcupramad23, SeatDanny, seatkev, seatstu, seatturbopower, seatvirgin, seat_rich, Seb_P, secret.squirrel, Segger, seione, SexySeat, Sh0ckwave, Shadders, Shandy, Shapin, Shar, shaunymac, Shaun_E, shaw25, sheffboy, Shepdog, shnazzle, Shrek, Si, sibbocupra, Siboneh, sie77, SigmaDelta, Signor Whippy, silver surfer, silverfox, SimD1978, simon128927, simon54321, SimonFRTDI, simonp123, Sinbad, singh123, Si_TDi_FR, sk4tec, skard, skiddusmarkus, Skisbp, slappy_dunbar, slim20vt, slysi84, Small, smbitin, Smee, Smigger, SMiiTHY, Smiler-MK2, Smurfy, SNAP-ON, Snarks, snavE ttaM, Sneaky1337, Snower20vt, Snowsurfer, soche, sonic11, sotaville, Space Coyote, sparkie1984, Sparkopolo, Sparksy, sparky707, Spawney, spearce, Speedy83, SpidaCZ, spiralfries, Spirit Furtive, splinter26, splinter_cdo, splitpin, sportbilly, springer, spud31, SpursMadDave, Squealy, SRStdi, stabilo, Stakeknife, staneko, ste-lfc, SteA, Steed8, Steede, stefanbrash, Stegor, stellabelly, stephen1982, stephenSF, steve7786, SteveClarkFR, stevedevett, stevesulsh, SteveTDCi, steveyg, stevie go, StevieCupra92, Stevoz03, stevo_nwuk, stewbie55, Stewprovo, Stiggy, STOCKY, Stonesie, Storey1984, stpete, Street, streetbeef, string, stu666, Stuart19577, Stuart83, STUARTCLARK1982, stuflo, stuFR, Stupra, Stylance, StylancePaul, Subc, Suddy, Suicida1 Zombie, sunny2k2000, Super gaz, superkarl, Supershorty, superstu88, surajb1, surfo, swannley, T-Bull, T0DDY, t0m, t121anf, Taipan, Tam, TAOTAO, tapman, TarekElsakka, tatestar1, techieboi, tehguy, telmo.r, TFSI Elise, Tfsi_Mike, th0m4s- c33, Thafussa, thaivol, thanassis, The Old Codger, The poloman, TheCraig, TheDean, thefatplasterer, thermalp4, thestonegate, Thompa93, Thor_Asgard, Tiburon, TidzaCupra, tim1547, TimJK, TimJohnson, Timmyboy, TimSawf, TJenkos, toca72, toilet, toledoChris, Tom B, tom t, tom.b, Tombstoneuk, Tomer 20VT, tomhcupra, Tomibz, tommy918, tommy_a, Tom_SE_2009, Tonezz, tonipieleanu, tonto, tonycane, toot, Toxic, Traction, tractorboy, traumapat, Trekkie, trevorg1988, Tricky Red, triggster, trippy21, TrophyJem, truant2000, Trublu07, truss, TSI BOY, tundrarocks, turkish, Twisted1, Tylerjet, T_Free, uncle, Uncle Fester, unclelonghair, uniseat, unsheenashashin, unyonion, Updown789, uzzy, v0id, vagmanFR72, VAGUE, ValeriCUPR, valverjam, varley16, vdawg, veloc123, Veyron, vfr400racer, vialli69, Viking, Vimes, vINyL3, Virdz, viren, volvic, vRSy, vtxracer, w.reid306, w5ccb, waggyy, walkerfr, Wallie, Wama, warren30, warren_cox, wazza16, webb204, webdiod, webhype, webwysard, Weedall, WeeG, weejim, Weetz, Wellsy, WelshConan, Welsh_Steve, Weslington, westy2k1, wezy0, whitecuprak1, WHOZBOSS, wigz45, wild willy, WileEcoyote, Wilko, wilksy, wilky19, will-fairburn, willber, willc, williburp, Willz17, Wilson9, Wimbledonian, window60, windy1664, Wings988, Wire_Gal, wisejason, wolfiecuprar, womble68, worleyg, Worthy93, WRC555, Wullyboy, WW_VRS, X cupra, xander_leon, xavier de, xhellixx, xreyuk, xyz, Yannerson, yarlie7, yaue10, yaza01, yazmidani, yea_good_1, Yello, yellonvi-R, YIN, YoDan, Yohan87, yooni7, Youbee, younger25, Youngy81, zak, ZiggyEP3, Zipcode, [M]ike, _chris_, _sql_
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ibiza 2008? Offspringy Ibiza Mk5 182 30-05-2008 22:05
Revo map for NEW Mk2 Leon Cupra warren_cox Leon Mk2 83 19-10-2007 09:17
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
