Revotechnik
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 15-04-2013, 22:12   #21
ARi01
ARi01's Avatar
ARi01 has 10 points
Cheers and will defo reroute as does sound annoying lol
ARi01 is offline   Reply With Quote
Old 15-04-2013, 22:15   #22
ARi01
ARi01's Avatar
ARi01 has 10 points
Quick question how much is my old climate control unit worth?
Old 15-04-2013, 22:19   #23
joostdeblok
joostdeblok's Avatar
joostdeblok has 10 points
Not enough to make money out of it and it will deny you of the option of reverting your car back to OEM/stock.
I will sell my facelift unit when I sell the car, probably value drops a few tenners but still OK I guess.
joostdeblok is offline   Reply With Quote
Old 15-04-2013, 22:21   #24
ARi01
ARi01's Avatar
ARi01 has 10 points
Don't you think would be better to sell with as looks better and prob draw more attention
Is it not worth much with full fascia and heaters?
Old 15-04-2013, 22:26   #25
joostdeblok
Depends if you sell private or dealer, private will probably increase value as the potential buyer will definitely like the look of the facelift control (specially if he had seen other Mk2 Leon's with the old unit).
A dealer will probably dont give sh*t about it and rather have it OEM because they normally dont like self-modded cars.
It's only a bit of fascia and a control unit m8, no heaters. I would guess value of the pre-FL cc unit is around 35 pounds (50 Euro).
Old 15-04-2013, 22:59   #26
Rodie121
Senior Member
Rodie121's Avatar
Rodie121 has 10 points
well ive got the pannel all sorted and ready to go, but im not even sure if i like the style of the new one, it looks a little jap? I know its easier to use but....
Rodie121 is offline   Reply With Quote
Old 21-02-2015, 21:19   #27
krisbutler02
kris
krisbutler02's Avatar
krisbutler02 has 10 points
Anyone tell me what connector A is please?
i cannot see any numbers either
Kris
__________________
LEON BTCC - Bentley Wheels, Airlift Air ride,Supersprint exhaust,Revo Remap, Forge Intake, Forge Coolant hoses, Forge engine styling , Cobra full retrim , Vibe install
krisbutler02 is offline   Reply With Quote
Old 09-04-2015, 21:16   #28
Norbeey90
Newbie
Norbeey90 has 10 points
Hi!
A want to change my "old" pre fl twist knob style climate control to a pre fl digital climate control, its possible to change? and what i need?
Norbeey90 is offline   Reply With Quote
Old 01-05-2015, 00:31   #29
DiddlyDonker
DiddlyDonker's Avatar
DiddlyDonker has 10 points
Sorry to bring up an old post but how is pin 20 removed??? I managed to get number 16 out of the connector by pushing down on the little metal clip but pin 20 is completely different. Pins 1-18 are in a cluster that removes from the connector which reveals the clips needed to be pushed to release the pin but pins 19 and 20 are separate from the cluster and have no clips for removing them ... ???
__________________
2006 SEAT Leon FR PD170 - http://www.seatcupra.net/forums/showthread.php?t=413954
18" Rial Alloys / H&R 40mm / DPF Delete
DiddlyDonker is offline   Reply With Quote
Old 18-08-2015, 19:36   #30
MACKA
Newbie
MACKA has 10 points
Thumbs up
Hi mate, what is the facelift climate control called i no iTs a stupid question but i cant find that version anywhere. (What model leon is it from?)
MACKA is offline   Reply With Quote
Old 18-08-2015, 19:37   #31
MACKA
Newbie
MACKA has 10 points
Hi mate what model leon is that unit from?
Old 19-08-2015, 14:48   #32
DiddlyDonker
Quote:
The facelift models 2009 + . Just type in Seat Leon Facelift Climate Control Unit, they can be difficult to come by though. Took me a while to find one.
__________________
Old 19-08-2015, 15:28   #33
zamzia
Gixer 750 K8
zamzia's Avatar
zamzia has 10 points
Good info. Thanks for sharing.
zamzia is offline   Reply With Quote
Old 19-08-2015, 16:26   #34
vINyL3
vINyL3 has 10 points
I try to do this swap, it didn't work.
It don't cold down temp with aircon. It only blow air.
Now neither a equal climatronic like i had before work... It stop blowing fresh air after I while, maybe because i can't do the basic test calibration.
vINyL3 is offline   Reply With Quote
Old 19-08-2015, 23:40   #35
DiddlyDonker
I have a similar problem after switching the units over from pre FL to FL whereby when I turn the aircon on, cold air will blow out of the vents then after about 1 to 2 minutes the air coming out of the vents slows down and the cold air stops and normal air is thrown out of the vents instead. Took it to the garage who have said it needs to be sent to a SEAT dealership to have them look at it as they have no idea what's causing it, but at £109 p/h at my local SEAT dealer I'd rather just cook on the rare occasion we have a hot day in Britain!
__________________
Old 20-08-2015, 10:27   #36
vINyL3
That's what is accouring in my climatronic.
Already try to return to pre-fl climatronic, and now even that do that.
It just stop blowing fresh air from the vents.
Seat say it need a new climatronic, but i already try that and don't work.
Old 27-12-2015, 14:57   #37
aaronb84
aaronb84 has 10 points
For anyone looking for one of the units I have just listed mine on ebay. Link below
http://www.ebay.co.uk/itm/-/131686105462?roken=cUgayN
aaronb84 is offline   Reply With Quote
Old 19-01-2016, 00:38   #38
KebabWarrior81
Senior Member
KebabWarrior81's Avatar
KebabWarrior81 has 10 points
Hi all has anybody ever fitted a fl head unit into a pre fl as I want to change the climate control and the head unit but unsure if the radio will be plug and play or it will need coding.
__________________
2008 Candy White Cupra R-Tech Stg 2+ 370.1 BHP/406.3 FTLB BCS TBE
MY READERS RIDE
http://www.seatcupra.net/forums/showthread.php?t=412099
KebabWarrior81 is offline   Reply With Quote
Old 19-01-2016, 13:48   #39
Updown789
Updown789 has 10 points
Will be plug and play wiring wise, will obvs need radio code and if you have the large screen it may not work due to conflicting fw
Updown789 is offline   Reply With Quote
Old 11-01-2018, 22:46   #40
Mackaa-1
Newbie
Mackaa-1 has 10 points
Quote:
Originally Posted by joostdeblok View Post
Yes. But if you dont reroute the wiring on the A-connector it has no memory set in the unit and therefore it will be @ random settings every time you start up the car. Annoying but all settings work as it should
Hi, i know this is an old thread and god knows how many of you still have your car seat leons, but ive just got one, im more of a golf guy, but i liked this one and needed a run around. Im wanting to fl my interior, iv found a climate panel, bjt tk reroute, you put pin 16 on connector A to pin 20? But then where do i put the wire from pin 20? Back into 16? Or just leave it out completely? Also what facia do I need to install a newer radio stereo from the facift (will get a nav later as i have other things to purchase as of yet) thanks
Mackaa-1 is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 319
-Cooper-, -pseudonymous-, 1.9...stefan, 1kevintaper, 2a1n7867, 8arran8, aadan113, aaronb84, Adam D, Adzn3k, afcajax73, AGTDI, AlexK1, AlorLeon, andy.morgan, andy550, AndyG_TSi, AndyH38, andypower, Ape_, aran, ARi01, arsenalmorris, Asce, asohotra, Atteman, b21playa, B5NGV, basstard, batwing, Ben K, Ben P, Ben750, Bengal, beterthanlife, Big Lee M, BIG_Y, Bikerz, blueleontsi, bmxshane, boggle, bondbill2k2, Bosher, breengin, Brego, Cabbage, CameronJohnston, carlamos, cfitzy6, cheungy, chouman, Chris Bartram, ChrisLindsay, chrissy66, ChrisW16, chrisw_mk2cupra, Ciosmi, coggie, Colledge87, Countryboyhaha, crigisback, cupra-barn, Cuprajake08, cupraNW, cupra_ahhh, cupra_r_ick, custard22, czapel1988, D17, daan, Damo H, Daniel M, Dani_b19, Dan_FR_21, darkwolfe, DaveysFR, Dave_addo, davidif, DavidLeonFr, DavieTDI, davo, dbscupra, densil, DiddlyDonker, din_Shaz, Dorny, drizzlefizzzax, dynamik, EgyTuner, ElaD, ELLIS82, Euan1P, evgenyk, F3ADM, fa11ows, fabioss, fede16, Fixay, Flynny, foellii, FR56, frboyz, fvranjic, G4reth, Gavinlin8, george g, gethinwr93, Gex, gillygilbert, goldy1234, GrahamFR, GreazyJack, GS16LRHP, Hargo, holmefield, hopegreen, hubbly_bubbly, ibizakie, IbizaNI, Invincible, iomegas, J400uk, jaba101, jackett, JackK, jake, jam666999, james6583, Jay sx, jeff030379, Jimbobcook, jj06, joestella28, john a, John-Cupra_TDI, jonovan82, joostdeblok, JP6, Jwk, K.S.D, k1_cupra, Kako51, Karl db, kazand, KebabWarrior81, Keithio, kemp2368, Kevgrady, kevinmcm19, kevlaa, kevzy, Kiukas, Konijntjes, Konmak, koush, krisbutler02, kroni, L8W FR, Laidbackdaddy, lajohnz, lc_allan, LEE69, Leericho, Legion1978, LeonCR, LeonFRNik, leonpr81, Lesroy, lizard2k5, lsm, lugsy, luke101, LukeFR, MACKA, Mackaa-1, Mackers, magaizeris, Mandu, markh2908, Marthamm, Masterkm, Matthew FR, matty1000kk, matty_glanza, matt_s, matylad, melkor12, mike0105, mikeypur, mini_racer, Mk23078, Mkaragianni, MM95, MrDurst, MrFwibble, MrStevo, NAS23, nd_cento, neil_1821, nick-fr, Norbeey90, Northy 8, Ode_BTCC, Olivermalyn, Ollie1990, P1 MKF, p11lkw, p1d9m73, paddles, Paulr89, Penguin, pete8tch, petous, PlatinumCupra, PLuKE, pmurray209, podderz, POPOV, porksword28, powly1621, Qk1, rackha, rairozay, reece1591, reeceee92, rich RS, richicupra, RichyFR, Rikman, rik_t, Rivva, rllmuk, Rob66, robbo990, RobFR, robthebubble, Rob_Talisman, Rodie121, rryans11, RuidCi, Rusty2k, Ryan6926, sau, scardy, scazenave, Scby555, SCleon2008, Seal_LCR, Senseitim, Seth110, sfmk2., Shamx1166, ShaneMitchinson, Shapin, Shaun, shaunk8, Shayz, shaziman, shorty971, simon128927, slartibartfast, SLCR1977, Slincer, smithy363, Smoki333, Smoothnick36, Smurfy, sotonsmut, Sparkopolo, splinter_cdo, spoonflames, Spoons1999, Steed8, Stegor, steve7786, SteveCR, steveo1259, Stevie.B, Storey1984, StrangletMuh, stuflo, Sumo1991, swordfish103, TarekElsakka, Tdb-123, Tiburon, tizurcio, tomica, tommy12, tone, too hot, toosmiles, toot, Toyolish, UltraObamaX, Unit9, Updown789, valverjam, vanny, veno, Veyron, vfr400racer, vicb, vINyL3, Virdz, viren, volts, warren30, wasvw, WHOZBOSS, wilksy, Will_s87, window60, Wizzard, xreyuk, YIN, Young Arson, zamzia, ZiggyEP3
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
