Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rate Thread Display Modes
Old 24-01-2018, 14:36   #1
tommy_l
tommy_l has 10 points
Leon Fr 170 Cold start issue
I'm having issues when cold starting my 2010 Leon fr 170. When outside temperature is below 9 degrees c approx., the car takes a couple of seconds to ignite, a feeling similar to when you have a slightly flat battery and struggling to start the engine.
I thought it was a battery issue as the battery was about 7 years old, but a new battery has not solved the issue.
Any advice is appreciated.
tommy_l is offline   Reply With Quote
Old 24-01-2018, 15:27   #2
Rusty2k
Rusty2k has 10 points
Are you waiting until the glow plug light goes out before turning the engine over?
Rusty2k is offline   Reply With Quote
Old 24-01-2018, 16:40   #3
tommy_l
I am waiting for the lights to go out.
I forgot to mention that when I turn the ignition on and off three times before turning the starter over, it ignites as it should, turning the ignition on and off twice is not sufficient, three is the magic number it seems
Would this suggest glow plugs or something more serious?
Old 25-01-2018, 15:19   #4
tommy_l
Any ideas anybody?
Old 26-01-2018, 01:20   #5
Swanbon
Newbie
Swanbon has 10 points
Mine was the same through that cold snap, but I blamed mine on short journeys. And until mine doesn’t start it’s staying like that.
What your doing with the three turns is what is done with old glow plugs. How many miles has it done?
Swanbon is offline   Reply With Quote
Old 26-01-2018, 01:46   #6
tommy_l
Found out this morning that the three turn trick didn't work.
Struggles to ignite 1st thing in the morning, short 10 minute journey to work, engine does not warm up to full temperature. Car starts fine after work, Standing for 7-8 hours, outside temperature warmer than mornings. Car stands outside house for over 12 hours overnight and struggles to ignite again.
Milleage is approx. 75,000
Old 26-01-2018, 20:49   #7
jonnybravo
jonnybravo has 10 points
Hi Tommy
don't dismiss the battery just because it's new,put a multimeter across battery terminals and try cranking engine battery power should not go below 9 volts whilst cranking if it does you won't start a diesel in cold weather.the other option may be a lazy starter motor they get full of dust over time with brush wear.
jonnybravo is offline   Reply With Quote
Old 28-01-2018, 18:29   #8
tommy_l
Tested the old battery and it seemed fine, just changed it as it was the original battrery, just thought that it deserved a new one! Will have to wait until the starter goes completely, not going to go to the expense just on a whim! Thanks
Old 29-01-2018, 21:46   #9
jonnybravo
have you done a cranking test tommy.as said multimeter across terminals while some one cranks engine cold it must have 9volts plus while cranking,check cranking power on battery label against what is required in your handbook ,
Old 05-02-2018, 15:15   #10
tommy_l
UPDATE!
Had the car hooked up to a diagnostics machine over the weekend, there was a fault recorded with the glow plugs or the relay for the glow plugs, will now be a process of elimination I suppose.
Old 10-02-2018, 12:36   #11
Lorand02
Lorand02 has 10 points
Mine does the same , glow plugs are the problems
Lorand02 is offline   Reply With Quote
Old 13-02-2018, 10:45   #12
tommy_l
UPDATE.
Installed a new relay...problem remains. Going to have to be the glowplugs.
Old 13-02-2018, 11:43   #13
JHox
Newbie
JHox has 10 points
Let us know how it goes with the glow plug change
JHox is offline   Reply With Quote
Old 21-02-2018, 14:17   #14
tommy_l
UPDATE / SOLUTION!
After installing a new relay first, was the cheaper option (£36 for a genuine part which was meant to be £90...don't ask how I got it at this price.) As mentioned relay did not make a difference so had to go for new glow plugs, which I am happy to report has solved the problem. No doubt the old relay was fine after all.
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 29
Ape_, Asce, bree9482, DavieTDI, dennis10, Hawkers, heggie, iNeoTom, Jacey Boy, jake, JHox, Jimbobcook, jonnybravo, Liam-Leon, Lorand02, Mhug, Muttley, Number12, Project1P, rubenpatricio, Rusty2k, Scam, Smeagol65, steve7786, Swanbon, tafakasam, tommy_l, UltraObamaX, Umar K
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
