Badger5
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rate Thread Display Modes
Old 04-02-2018, 19:32   #1
UltraObamaX
Newbie
UltraObamaX has 10 points
Door problem?
Hi, I have a 2009 Leon fr, facelift, and all doors apart from front left lock, wether using the remote or manually. I'm guessing it's the actuator? Does anyone know the part number? Thanks.
UltraObamaX is offline   Reply With Quote
Old 04-02-2018, 20:12   #2
Jimbobcook
and karma is restored...
Jimbobcook's Avatar
Jimbobcook has 10 points
Do the doors open from the outside if you have previously opened them from inside?
Currently Driving - SEAT Leon Mk2 Cupra R 2010
Previous Car - SEAT Leon Mk2 FR 2007
Jimbobcook is offline   Reply With Quote
Old 04-02-2018, 20:18   #3
UltraObamaX
Newbie
Yes all doors will open. The only way to get the door to lock is by putting the key in the 'hidden' key hole when door is open. After that it will stay locked, until I open it from inside.
Old 04-02-2018, 20:24   #4
UltraObamaX
Newbie
Also, I don't know if this is related, but there is a red LED on driver and passenger doors and 1 in the centre. Only the passenger 1 flashes when locked, the 1 with the lock problem. Is this normal? I though all of them would flash when alarm is set?
Old 04-02-2018, 20:24   #5
Jimbobcook
Jimbobcook's Avatar
By hidden key hole you mean at the drivers door?
I have this issue
http://www.seatcupra.net/forums/showthread.php?t=442409
This your issue or am I miss reading lol
Old 04-02-2018, 20:25   #6
Jimbobcook
Jimbobcook's Avatar
You could also try re pairing the key to see if that helps
Old 04-02-2018, 20:26   #7
UltraObamaX
Newbie
No the 1 on the passenger door. There is a black bung, you remove that and there's a key hole there. It's like on the side of the Door, just above the catch.
Old 04-02-2018, 20:27   #8
Jimbobcook
Jimbobcook's Avatar
Is that the child lock key hole?
Old 04-02-2018, 20:28   #9
UltraObamaX
Newbie
I don't think it's child lock, as it's front passenger Door, and it can be opened from the Inside.
Old 04-02-2018, 20:30   #10
Jimbobcook
Jimbobcook's Avatar
Apologies I didn't know that existed.
Old 04-02-2018, 20:33   #11
UltraObamaX
Newbie
How do I re pair the key?
Old 04-02-2018, 20:55   #12
Jimbobcook
Jimbobcook's Avatar
Try that...
I would recommend reading the entire thread as for facelift cars sometimes you may have to use vcds to remove and re code a key
http://www.seatcupra.net/forums/showthread.php?t=310803
Old 04-02-2018, 20:58   #13
UltraObamaX
Newbie
Thanks.
Do you know where I should post to see if someone has vcds near me?
Old 04-02-2018, 21:03   #14
ray
ray has 10 points
Mine does the same, also doesnít lock/unlock from the buttons inside the car.
It sometimes locks but never unlocks, front passenger door too.
From what Iíve read itís easiest just to replace the door lock module, I just havenít bothered my arse to do anything about it yet.
ray is offline   Reply With Quote
Old 04-02-2018, 21:03   #15
Jimbobcook
Jimbobcook's Avatar
Quote:
Originally Posted by UltraObamaX View Post
Thanks.
Try here or if you go to the main section for the forum I think it's called diagnostics tuning or something lol in there will be vag com / vcds then inside that there will be a host of info for you.
http://www.seatcupra.net/forums/showthread.php?t=262363
Old 04-02-2018, 22:11   #16
Rusty2k
Rusty2k has 10 points
If one door lock is not doing something the rest of them are then it won't be the key / remote programming.
Get it plugged in and see what fault codes are showing.
Rusty2k is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 17
Asce, bree9482, Fishy, Greipfrutas, Hawkers, Jay sx, Lorand02, Mhug, Number12, Rslou, Rusty2k, superstu88, thaivol, Traction, UltraObamaX, Wenny123, Wizzard
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
