SEAT LEON 4 POT BREMBO CALIPERS on mk3 ibiza
SupraDupraCupra
will Seat leon Brembo fit on mk3 ibiza
I know there 5 stud but will the standard disc fit
cheers
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
i was looking to do this aswell. I think yo need to get some sort of hub adapters to change from 5stud to 4stud then get the carriers mod'd to fit. Im sure there are a few threads on this. Im gonna have serach and see
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
guys there was a thread on here today, which talked about converting the 312 s3 brakes (5 stud) to 4 stud ibiza.
Like I posted there, its a question of redrilling the discs. you need an extra 2 holes and the other 2 you can use from the ones that are already there....
First search then ask???
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Apart from its different to 312mm S3 brakes as he is asking about Leon Brembos which will be larger and also have a different caliper carrier.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Hence the fact I was referring to the redrilling only...
But searching for the 312mm S3 thread would not have helped him at all as its a totally different set up. The way you wrote your reply also makes it seem like its pretty much just a redrill and the other answers can be found in the said 312mm thread which they cant.
