Filter Change Advice and whats this sensor!!
Jan 8, 2008
528
Portsmouth
Hi All!
2 questions ... i think i may have a partial blockage in an injector but really don't want to pay a lot for full strip and rebuild on all injectors!
If i replace the fuel filter lots of people have said to put pure injector cleaner in the filter and run the engine with this, is it safe / worth doing???
If i do this what brand of cleaner would be best to use, how much of it and should i mix with diesel or literally pure injector cleaner!?
The other thing is i changed all vacuum lines today and replaced the N75, i then noticed another small sensor on the back of the engine above the inlet manifold, it has one vacuum pipe going to a T piece by the N75 and another vacuum pipe that ive blocked (i think it used to go to the EGR that''s gone!!) I know its not the N18 as thats in my hand lol!!
Ok its more than 2 questions but any help would be appreciated!!
Im hopeing this will cure my rough idling engine!!!!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The "sensor" sounds like it could be the N239 valve, which controls the anti-shudder flap valve. If you've deleted the EGR you've probably also taken the flap valve out.
