Hi everyone,
Please excuse my english as I'm not a native speaker and I don't live in UK.
I have a very annoying problem with my Altea and was wondering if any of you guys can help. My model have a sunroof and one of the drains hoses seems clogged (if you pour on some water it doesn't go away. The other one works fine). As a result, when it is raining there is water dripping from the air opening in the drivers or passenger seat. It goes just on your feet. My guess is that the clogged hose of the sunroof is connected with that issue. The top part of the hose, up to ~1 meter, is not clogged, so it must be soewhere at the bottom end. Unfortunatelly when I remove the splashboard/fender I see the end of the hose coming into a special hole, but can't have access to it, so I don't know when it goes next and if it is clogged.
p.s. Pollen filter is NOT wet. And the leakage goes to to drivers footwell and passenger's footweel at random. Or maybe it depends how the car is parked - bent on the left or on the right
I appologise again if I'm not accurate with the english terms
Any help will be much appreciated!
