Remap NOT the cause of temp warning light!
InvisibleName
Candy White Bocanegra
Jun 28, 2005
101
Peterborough
Just wanted to make it clear that JabbaSport re-loaded my original parameters and the diagnostic light was back on within 3 journeys. At least I can now go back to Seat and say there must be a deffinate fault now.
JabbaSport were REALLY helpful & are just awaiting my call to up-load the new map as & when Seat have got to the bottom of this REALLY annoying problem (See new thread - titled: Diagnotic light for Error in Mapped Cooling System)
flashbsd
will they not turn round and say its out of warranty as jabba have broken the ECU seal?
9000GIRI
Excuse me for my english, I have the same problem after remap light turn on!!!!
I have more information for you:
if you reset the light, it came back if you start the car with a water temperature under 20°
if you put the original map by obd the light turn on again
if you remove ecu processor and remap it the light don't turn on!!!!
the problem is to make a good map because you can't remap by obd :(
Do you have news about this problem?
thanks
