EGR help
Air_Wolf
9
Hi,
My engine management light came on and I hooked it up to my VagCom and the fault code that came up is 15536 EGR Sensor1, P0405 00 (136) signal too low.
I've looked on ross tech but can't find an exact match so I searched EGR sensor 1 and read possible causes but I'm not sure it's taking me down the right track.
Can anyone help me with a possible cause? Ibiza 1.2 COPA 3 cylinder diesel. Car is completely normal and no other faults detected.
Thanks in advance.
JRobinson
I would of thought it is the fairly common EGR & cooler unit that has failed. Seat U.K. Tend to put a small amount of goodwill on these.
viren
16
Hi you can actually turn the requested value down in vagcom in engine 01 adaption channel 2 turn to max
