Member map and signitures
antnee
2 suggestions.
1) Is it possible to have a new interactive member map?
2) Could we have new rules on sigs, something like only 1 or 2 lines of text, no images? It makes the forum loads quicker, even more so for people using mobiles to access the forums.
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
if you go to userCp
then edit options
scroll down to Thread Display Options
Visible Post Elements
You have the option to show or hide various elements of messages, which may be of use to users on slow internet connections, or who want to remove extraneous clutter from posts.
Show Signatures
Show Avatars
Show Images (including attached images and images in code)[/QUOTE]
deselect what you don't want from the list will help
ZBOYD
Looking up at the stars!
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
Indeed as Flapper suggests just turn off signatures and other related images from the user cp.
Were not sure about the member map, it's been problematic so we might be removing it for good.
antnee
On another forum I used to go on, they had a member map, which was a link to another site with the mapping software, everyone just entered their name and address, then you could browse to see where everyone lived. Ideal for organising meets :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Correct, it worked sporadically on here, but because it sometimes falls over & isn't supported on this version of the forum it's currently (and probably permanently) offline
