Flashing glow plug light
Codemasta
17
Hi all, had my Exeo 2.0 tdi a couple months now (1st experience of a diesel). Dpf/exhaust emissions light would come on & go off as soon as went for a decent run. Until recently when it wouldn't go off and now the glow plug light is flashing & has gone into limp mode. Any ideas on what it could be?
Many thanks
spj81
11
Did you solve the flashing glow plug problem? If so what caused it?
Mine did the same tonight and went into limp mode. Parked up for an hour, jumped into the car to drive home and worked perfectly for a mile then glow plug light flashes and drops into limp mode. Hate electrical faults. Seems like a mine field!
Codemasta
17
Hi,
I managed to get hold of a code reader and it showed a problem with dpf/dpf sensor. Got a carbon clean done and codes erased and has run fine ever since
