What you need to install an aftermarket stereo in Mk2 Leon
Pheo
275
I just installed a Sony Mex- BT3800U. Sound quality is definitely much improved, and it does Bluetooth, plus proper iPod/iPhone integration. Combine this with the Connects2 adapter and you can control the iPod from the steering wheel! Pretty useful!
I'd highly recommend replacing the stock unit now. Although I'm not convinced you need to spend more than £130 on a head unit unlike some!
Will post photos of the clips on Monday guys.
Pheo
275
Location Photos of Stock Leon Mk2 Stereo Retainer Clips:
Bottom Clip Set:
Seanbroc
I managed to get mine removed with keys out of halfords plus a bit of gentle persuasion. Didnt even have to buy them they guy in store just lent me a set as they were out of stock. Not often you hear it but... Thumbs up for halfords!
adrianwood
I'm having trouble locating the areas where to use the radio removal tools on a fl fr standard mp3 cd player. It differs from the pictures on this guide so far, any chance anyone has a front on picture of the fl stereo highlighting where to use the removal tools?
adrianwood
Thanks for the reply although the video shows a pre fl radio and as I have the fl fr the radio is different and I don't think the removal tool holes are in the same location, unless someone can confirm they are as I can't get it out
lumor
57
that panel looks identical to the altea I've opted to lose the steering wheel controls as the trim and pocket were £28 from seat. I forgot the clips but they are 25p each. I think the golf mark 5 trim is cheaper option. Will upload photos soon doesn't look great. Bought the quad block from ebay for £4 and aerial adapter for £4 too. I'm tempted to order the Sony connect 2 adapter then cutting and chopping the cables that don't go any where. As the 2nd part of the adapter is £35 rip off!
lumor
57
Okay done my wife's car. Would have ordered the connect 2 canbus if it was my car but she didn't want to spend £60 to put a £80 stereo in :whistle: I've set the stereo to auto turn off after 30 secs of pressing the off button, though you can hold it down to turn off. A lot easier than running a switched live to the fuse box :)
for both you want
Amplified Fakra Aerial Adaptor £3.77 off ebay
ISO stereo adapter for your car got mine for £3.40 off ebay
Leon MK 2
1P2 858 063 - trim for RHD 2 DIN slot
5P0 857 232 A - black stowage shelf
1J0 858 137 B - clips you'll want 4-6 / 27p each
Altea MK 1
5P2 858 063 A - trim for RHD 2 DIN slot / £7.26
5P0 857 232 A - black stowage shelf / £16.46
1J0 858 137 B - clips, you'll want 4-6 / 27p each
the trim took over a week to come in, I assume it's ordered from Spain. The stowage shelf clips into the back of the unit meaning you don't really need the individual clips unless you want to stop someone making off with your radio so easily.
tom.b
209
Nottingham
for both you want
Leon MK 2
Altea MK 1
good guide, i was wundering though do you need an amplifed arial adapter or will a normal one be ok? and could you post a link to the one you got please.
thanks Tom.
lumor
57
item number 150356197709 for the aerial adapter, don't think you can get a normal one? you are converting a Fakra amplified aerial into a non amplified one. When I took the blue cable off the aerial adapter it didn't seem to affect the signal strength Though that could be because the antenna base on the roof needs replacing.
lumor
57
sorry yes mine was for a Sony head unit, that should work though it doesn't have the amplified option on it, might be a problem?
found this one on ebay item # 160347836193 hope someone can say whether we need the amplified bit or not. Can't hurt to have it though right?
tom.b
209
Nottingham
yeh i know what you meen about it carnt hurt to have it, im just trying to mimimise the wires at the back of the HU and i hardly listen to the radio anyway usually the mrs lol so im not that bothered lol
ashy7
14
Quick question about the aerial adapter - Do i connect the blue wire on the aerial adapter to the blue and white wire (remote lead to other equipment) on the stereos wiring loom?
tonto
1,265
plymouth
the aerial power booster / adaptor wire (blue) goes to the ant/cont / p.cont or rem. for a switch 12v feed.
Pheo
275
I have sold my Leon now so just incase anyone is interested Ihave my Sony BT3800 as mentioned above, mounted into the SEAT mounting kit for aftermarket, and all the wiring gear for integration to steering wheel available. Just sat around collecting dust. Message me if anyone is interested!
