Cupra & Cupra R p/n's for Cams, Coolers, Clutch/ Flywheel/ Box, Turbo, Fuel Pump etc
Al
7,331
9
The info from GtSport is incorrect. The Facelift Leon Cupra R shares the wider intercooler with the S3, but it has the smaller plastic end tanks. The earlier S3 intercooler core was the same width but with large stainless end tanks. The facelift Cupra has the same intercooler as the pre facelift Cupra which shares the end tanks with the new S3/facelift Leon Cupra R, but the core itself is narrower.
robin_nerf
73
Sweden
Okey, so mine got plastic ends? Will it be a much better cooling effect for me to change to a IC with stainless ends ? I'm planing to have about 350hp (have 320 now).
K16-MYK
Could you supply the number for the Fuel Pump Spring, that sits on the Cam follower?
Its for my 2007 Cupra TFSI
Al
7,331
9
If you call Will at TPS in Aberdeen you will get it Mike. Or David from SERE (sponsor on here)
I don't have the part numbers here with me now.
