fsult showing for epc and eps
frankval
hi can anyone help please i had the fuse blow for the windscreen washers i replace it and all ok but haveing removed several fuses to find the correct one as no indication at all in manual i now find my esp andepc lights are staying on i have been told that you have to reprogram the control system to remove this fault by turning the steering wheel left then right then driveingthe car at approx 20 mph for a while is this correct thanks from a newbe
