Revotechnik
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Discussion » TDi - SEAT Diesel specific topics
TDi - SEAT Diesel specific topics exclusively for SEAT diesel specific topics only.
Reply
Thread Tools Rate Thread Display Modes
Old 02-04-2017, 12:07   #1
teeth2k
teeth2k's Avatar
teeth2k has 10 points
cam sensor issue
I'm having this cam sensor issue, vcds throwing me error
Camshaft position sensor (g40) implausible signal.
Not I'm doing my research on the web and trying to find possible solutions, have already replaced the sensor but fault still present.
Question is until I can find the fix without throwing buckets of money at it is
Car starts after about 5 turns with the cam sensor unplugged, although a little lumpy but, will running it with the sensor unplugged cause any damage?
__________________
_____IBIZA mk4_______ _____Altea XL box standard______
gun metal grey 17" leon fr alloys.
teeth2k is offline   Reply With Quote
Old 02-04-2017, 23:03   #2
Speed-FReek
Senior Member
Speed-FReek's Avatar
Speed-FReek has 70 points
The cam sensor is needed so the ECU knows which stroke each of the pistons are on (induction or compression).
The other important sensor, the crank sensor enables the ECU to determine the engine RPM and more importantly, when each piston is at TDC. However, the crank sensor alone will not enable the ECU to determine whether a particular piston is on an induction stroke or a compression stoke. This is where the cam sensor comes into play because it enables the ECU to determine this missing piece of information.
If you run without a cam sensor then the engine will usually run (as you've already discovered), but it can take longer to initially fire up (again, as you've discovered) and it will generally run in "batch" firing mode which is less efficient than "sequential" firing mode that occurs when both the cam and crank sensors are both working together.
You generally can't do any damage running without the cam sensor working although you may notice a difference in engine running and throttle response/power. Fuel consumption may also go up slightly but this isn't always the case. It depends how the ECU has been programmed to perform batch mode firing.
Speed-FReek is offline   Reply With Quote
Old 02-04-2017, 23:10   #3
teeth2k
teeth2k's Avatar
Thank you very much indeed for you reply, the fuel economy on long runs is about 45mpg at present, I have installed the dark side egr delete last week and that has helped with power.
I guess its going to be one of these long to get to the end of problems
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 9
cheshire cat, clag, Dizzle, fettweg, imikk3, kitsune56, Speed-FReek, teeth2k, webb204
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
