idle speed, sticking throttle
pdtdi150
Hi Folks on an Ibiza FR TDI sometimes i notice my idle speed to be a little high, maybe 1k rpm, if i blip the throttle or lift the pedal with my toe it drops. Any ideas, is it a sticky pedal, bushing etc? is there any point that requires a bit of lube etc?
Seatmann
Rough around the edges
Sep 16, 2010
5,568
9
Scotlanda
There's a tps (throttle positioning sensor) on the end of the shaft thing up by the clutch pedal on most of the tdi's, maybe it's a bit loose or needing tweaked. Check the action of the throttle pedal while you're down there too and see if you can feel any stickyness, maybe could do with a lubrication.
