1.6 16v cuts out for a second then back running??
Madmund
Hi all hope fully someone will have experienced this problem and know of a possible fix
So I found the seat intermittedly cuts out then straight back in this can happen while accelerating or costing when it does revometer stops working and oil light flashes its a lot worse when more people in car so this suggest it's more prone to do it when engine is under more load
Engine fault codes are 16706 engine rpm sensor g28 no signal
17961 sensor altitude
Any help advise greatly appreciated !!!!!! Thanks
moomin500
Hi, my 1.4 has done this too. Seems to cut out for a hearbeat then normal again, only did it twice, but both recently. Thinking of binning it. Sorry not much help for you, lets hope there is an answer out there.
