Revs hanging (dropping very slowly
jovi12
11
Hi guys I've got a 240 cupra. It's been in and out of the garage for about a month my revs drop very slowly back to idle (it idles fine)but there's no fault codes coming up. Me and the garage and scratching our heads we've tried to mag isv air leaks etc but nothing. Have any1 had this problem or could point me in the right direction? Thanks in advance
Sent from my SM-G930F using Tapatalk
Shaggy's FR TDi
99
Check timing. Make sure aligned properly as sounds like one cam is out causing back pressure. Or possibly oil breather from bottom to top of engine blocked....
Sent from my SM-G955F using Tapatalk
jovi12
11
My timeing is on -1 according to my obd could that be the issue then?
