VCDS not seeing modules
xs2man
33
Ok guys,
So I got my new VCDS cable (genuine) as I figured it was about time I got one after having umpteen VAGs in the past. And currently am back at 2.
Anyway, so my ED30 is in getting looked at, so thought I'd have a bash at my Alhambra. See what error codes she is hiding, and have a bash at finding out which parking sensor is causing the monotonous tone I hear when engaging reverse.
So, I run a scan. First things first, it doesn't appear to run the CAN based scan, and CAN not ready appears in the port test. So I pick the Alhambra (7M), and run the scan.
Here is what I get...
Saturday,27,August,2016,12:12:58:19917
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: ******7M********* License Plate:
Chassis Type: 7M (7V - Seat Alhambra (1996 > 2010))
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
76
VIN: ******7M********* Mileage: 214470km-133265miles
Address 25: Immobilizer Labels: 7M3-953-257.lbl
Part No: 7M3 953 257
Component: IMMO 0008
Coding: 00003
Shop #: WSC 00000
VCID: 76E4230E528AF0F28A-4B2C
******7M********* VWZ1Z0G2901551
No fault code found.
Address 01: Engine Labels: None
Part No SW: 03G 906 016 JN HW: 03G 906 016 JN
Component: R4 2,0L EDC 000SG 9329
Revision: --H05--- Serial number: VWZ1Z0G2901551
Coding: 0000072
Shop #: WSC 00000 256 01574
VCID: 78F82D36089E868298-516A
1 Fault Found:
013112 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 209033 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 11000100
Temperature: 11.7°C
Bin. Bits: 00010000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 7M3-907-37x-ESP-F.clb
Part No: 7M3 907 379 J
Component: ESP FRONT MK25 0102
Coding: 0006154
Shop #: WSC 00020 000 00000
VCID: 448089C604D61262C4-516A
Address 08: Auto HVAC Labels: 7M3-907-040.clb
Part No: 7M7 907 040 J
Component: CLIMATRONIC MPV GP 0007
Coding: 00011
Shop #: WSC 00020
VCID: 397EE83223145F8AA7-25A8
Address 09: Cent. Elect. Labels: None
Part No: 7M3 962 258 BB
Component: 24 Multifunkt.Einh 0004
Coding: 04097
Shop #: WSC 00020
VCID: 7BF2323A69A8AD9AF5-50F6
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 2G AIRBAG VW61 0Q0M 0004
Coding: 12871
Shop #: WSC 00020
VCID: 275A3E4AC5A0D97AC1-514C
Address 17: Instruments Labels: 7Mx-920-xxx-17.lbl
Part No: 7M7 920 940 Q
Component: KOMBIINSTRUMENT VDO V66
Coding: 10421
Shop #: WSC 05314
VCID: 448089C654D61262C4-516A
1 Fault Found:
01336 - Company Data Bus for Comfort System
49-00 - No Communications
Address 18: Aux. Heat Labels: 7M3-815-071.clb
Part No: 7M3 815 071 C
Component: HEIZG. B/D5W 0001
VCID: 3068D516F06E9EC210-516A
5 Faults Found:
01492 - Function Lock-Out
35-00 - -
01409 - Repeated Flame-Out
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00020
VCID: 70E8151630EEDEC250-516A
1 Fault Found:
End-------------------------(Elapsed Time: 04:46)--------------------------
So it stops at Address 19, and doesn't go to any of the other modules. Anyway, that Glow Plug controller will need looking at I guess, but looks like only been logged once, 5,000 Km ago. But anyway, I clear DTC's and the scan re-runs, giving this:
Saturday,27,August,2016,12:27:12:19917
www.Ross-Tech.com
76
Coding: 0000072
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 214470 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 11000100
Temperature: 60.3°C
Bin. Bits: 01010000
Readiness: 0 0 0 0 1
Coding: 0006154
Coding: 00011
Shop #: WSC 00020
VCID: 397EE83223145F8AA7-25B0
Coding: 04097
Shop #: WSC 00020
Coding: 12871
Shop #: WSC 00020
VCID: 275A3E4AC5A0D97AC1-516A
Coding: 10421
Shop #: WSC 05314
VCID: 448089C654D61262C4-514C
Coding: 00006
Shop #: WSC 00020
End-------------------------(Elapsed Time: 05:00)--------------------------
So, at least it looks like that Glow Plug is a real fault, as it has reset the km counter to the current mileage. So I guess I'll want that looked at before it starts getting really cold.
But it also has now seen the CAN gateway, as it was showing No Comms before, and no fault on the Aux Heater either.
But I still don't get past Address 19, and cannot appear to get into the Parking Aid [76] separately either.
Any ideas what is going on here?
xs2man
33
Ok. So found out the parking sensors are an aftermarket Cobra kit. D'oh. So ordered the parts to fix (cable and sensor).
No longer worried too much about CAN gateway, maybe the car isn't REALLY a CAN based vehicle?
But any help on the glowplug controller fault would be much appreciated. Can't really find too much info out there about it.
hugosantos
46
London
for future user
I had to replace my injector/glow plug harness and since you have that open replace the glow plugs as well
