sub and amp install (now updating to include full Amped speakers too!!)
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
now you have connected those RCA converters on to the output of the HU...
lets focus on the speaker wire you just cut!!!
you next have to blank off the rear speaker cables (trust me on this please), wrap a bit of tape around them to keep then neat. and make sure they cant short.
next thing you need to do it get your good quality speaker cable and connect it to the front speaker cables. this will enable you to use the stock wiring on the front speakers :). if you dont want to do this then do as i did and run the speaker cables to the speakers then back to the amp in the boot.
right next you have to wire your good quality RCA cables down the drivers side of the car.. i found that wiring the cables under the fuse box, then under the plastic plate that holds the bonnet catch, under the carpet and along the sill. (also wire 2 x decent speaker cable along with the RCA cables)
(PICS)
Adam R
Mar 5, 2007
2,851
lee in the solent
run the cables down past the bonnet catch:
then down the side of the car
in to the boot area arounf here
then then feed under the carpet and come out here :
this is the link between where the rear bench sits and the boot
from this i decided to install the 2nd AMP behind my sub on to the rear of the seat using velcro. i wired the rca cablesup the little ridges in the seat behind the amp to hide them away.
Wire up the speakers cables you ran from the front of the car with the RCA's to the output on the amp (front speaker outputs).
pics
Adam R
Mar 5, 2007
2,851
lee in the solent
if you use the rear speakers, then get sopme speaker cable dircetly from the amp, wire this under the boot cover then up either side of the boot to the speakers. i dont have pictures of this as i ripped that part of my install out.
DivadLarsen
No grommet
I've been trying to find one, but cannot find anything other than where the wires for the rest of the cars electronics are run through... This might be in relations to me not realizing your Ibiza is a Mk3 and mine is Mk2 (sorry about that) - as far as I can see, there is no other way through the wall...
Sorry for the doing my research first, was just a little bit over-eager.... If you (for some reason) happen to know or catch anything on the Mk2, I would very much like to hear from you!!!
Thanks,
DivadLarsen
nmahi
Thanks,
DivadLarsen
easy, drill a hole and buy a rubber gormit for it ...lol[B)]
DivadLarsen
Okay, thanks for the reply.. If I cannot "piggy back" ( :D ) the cable with the others, I guess I'll just have to drill a new hole - although I'd prefer not to!!!
Thanks for the help,
DivadLarsen
Gordon396
ave got a mk2 1.4 8v. there is a big gromet below and behind the water collint tank, on the left if ur facing in to the engine. i ran 3 lines of 4 gauge no problem thourgh the gromet. if ur car has abs then its a little harder as its closs to the gromet.
only possible if the car has no air-con as this is the hole the air-con pips run through.
spongee
well adam, i think your post has been a great use to me because i will soon be fitting all my audiobahn gear and was looking for info like this.
Adam R
Mar 5, 2007
2,851
lee in the solent
iglad it has helped spongee... i really need to get some free time and finish this thread off! its not too difficult to pull my car apart again :rolleyes: :lol:
no seriously i will try and get the rest done by the end of this weekend.
sparkie1984
sparky
Aug 17, 2008
1,005
amazing thread adam, i was starting to be put off getting an ibiza due to stereo probs etc, but its great to see that you can still do bits to it! excellent guide too! will be using this when i finally get my car
Oj 89
Senior junior member
Aug 19, 2008
1,747
NW Kent
Can I put this in my sig so it (might) get a bit more publicity? It's a great guide and thread. Many thanks Adam. 1 little q with regards to the CD changer, I found one that will take MP3 cd's... Dya think it'd work in the mk3 ibiza?
Adam R
Mar 5, 2007
2,851
lee in the solent
yes please put it in your sig so people can see it as it is a helpfull thread and it is 'over looked'.
if you could say its mine though :p
CD changer is no problem...
mine is an apline cd / mp3 6 cd changer. it can take up to 300 mp3's per CD and 6 CD's so.......
thats alot of music :D, just get a 'connect to' or other specialised box.
sparkie1984
sparky
Aug 17, 2008
1,005
its a shame they dont f.a.q it! theres loads of common question that people keep asking because theyd have to sift through 50 pages of info to get to it.
Oj 89
Aug 19, 2008
1,747
NW Kent
Howsat! Had to take the link out to my development thread :( ah well. I'm sure people will get more benefit from this
