Help my dad with both right door not unlocking
DadsAltea
Croatia
Hello, quick introduction. I've recently did my drivers test and I passed. Now sometimes I grab my dads Altea but both right door are not unlocking after pressing unlock on the remote. My dad isn't sure what could be wrong with them even though he is car mechanic himself ( specialized on bit older cars ), as for him he is not sure what do, but he cant post here since he doesn't speak english. He tried our "local" forums but 0 answers.
Problem :
  • After pressing unlock on remote
  • Both left doors unlock
  • Right doors "unlock" but can't be opened from outside
  • Door has to been open from inside
  • After being open from inside, doors can be opened x times from outside.
Car we have is Altea 2008 1.6 MPI
Big thanks for the input from both of us. :thanks:
Dai_O
154
Cardiff
lol I have the same issue, but mine are both on the left hand side (passenger)
The rear was the first to go, then the front, they went a little intermittent at first but now both are knackered, and as you say can only be opened from the inside and still can be, once opened they can be opened from outside all the time until it is locked again.
I was lucky as I say went intermittent to start, I had the child lock set to ON on the back doors cause of the kids, but I found then I couldn't open the door from out or in, so child lock is now set to OFF on that door, eldest now sits over there lol, so at least we can open from the inside now
Lots of people mention door locks, I should get around to looking at them one evening
Maybe take one out and have a poke around
Dai O
hugosantos
46
London
IF you plug the car into the PC using Vag-com it should say what the fault code is, and then you could go from there, it could be the door lock mechanism or the door electrical module but you will know for sure once you see the fault code
DadsAltea
Croatia
Well, to be honest, he wasn't so keen on taking the doors apart since thinks its not something as easy as it is on the older model cars, but we will have to look into it for sure, since now its become so boring to stand outside and wait for doors to be unlocked. But once in a month I'm able to open door from outside ( this happens so rarely that I have to celebrate that opening). Well Vag-com is paid so I suppose we would have to pay for code to be read, or it can be done via OBD2 reader which we have ( highly doubt this will work ). Thank for the replys
Dai_O
154
Cardiff
Just changed the rear near side lock assy on my 2007 Altea XL.
It wasn't letting me open it from the outside even though it was unlocked, I could open it from inside and once I had opened it from inside I could then open from the outside as many times as I liked until it was locked again
and bingo we have a lock which now unlocks and is openable from the outside again
Bought the lock assy from a scrap yard for 30 quid and maybe an hour later old one out and new one in and all seems good
a few little fiddly bits but nothing too tricky really, if anyone want to any instructions let me know and I will see if I can remember the procedure.
Got to do the front one now, but I guess it should be very much the same as the front, back to the scrap yard and get the front lock assy
cg82lee@gmail.
cg82lee
Feb 17, 2015
68
Problem :
Just need to replace the door lock mechanism , they are prone to going on the altea (all vag of hat era for that matter) can be found for around £40 each on eBay , or around £120 new each , take old one out (lots of guides on the web of how ) and then using the part number , order the right one and refit , not too difficult to do watching you tube vids to show you, mine been fine since , and that was with the eBay ones at £40 each
