Got my roll cage back from the powder coaters ***PICS***
ibiza_95
1.8T MK2 Conversion
Bought the cage from revokev, went and picked it up on friday. Looked sweet when i brought it back, but i always intended on having it powder coated to make it look like new again. I had to grind down some brackets so it was all smooth, so i did that and smoothed itall off before i sent it.
The results....
Absolutely stunning :D Couldnt be happier with it.
Thanks to Kev for giving me the cage and Darren, who will never be on here cos he drives an MGzr but thanks to him as well for doing the powder coating for me :D
Few pics of the before and after for you...
Im not sure how its gonna fit in the car at the minute, as the legs nearer the front seem wider than the actual space inside the car.
May have to trim the feet a little bit at a guess
Anyway, the pics :)
First got it
The journey home in the car
Grinding the brackets off
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it fits fine, you just need to remove the door cards :)
Looks good now it's been painted though
ibiza_95
1.8T MK2 Conversion
its not the door cards that are in the way, its down by the floor whereits struggling to fit... ive not really looked at fitting it yet tho, so it may just need the seat belt rails removing which will happen when the buckets go in anyway. Kev said it would flex into place......!? We tried and failed...
Thanks tho, im really impressed with it, looks spot on :D
EDIT: Its a proper roll cage, but bolt in
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
The Plates were made for the BIG plates that needed to be welded to the car
can't find any pics off hand though
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
go on top of small towers (plates on top) dont they ? or was that just one the track day mk3's ?
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
The rear triangulation will flex to a certain extent but not by much.
I'd start off with the B pillar mounts first, make up & weld in the plates(dont torch your fuel lines!!:doh:) bolt it up making sure its sitting straight then fabricate the C pillar mounts
When your done, get it recoated as it will get scratched
Have fun:)
Revo Kev
www.onlyrevo.com
Feb 24, 2003
1,488
www.onlyrevo.com
Saul had some plates made up similar to those that stu attached but he had the cage modified as well (if my memory serves me correct). Can't remember what he had done though. It was in the Cordy with no rear door cards and the the seatbelt mounts bolted to the cage.
