20VT Toledo now wrapped GREEN
spudboy6
722
114
Swindon
Thanks , now cooler is on I'm going to get a 4bar pressure reg cupra r fuel pump and injectors and get AMD to go stage 2 on it with launch control if they do it :)
spudboy6
722
114
Swindon
so this week ,
shark fin aerial fitted ,
DAB radio and screen aerial fitted
injectors removed , refurbished and re-fitted
new boost pipes ordered for charge pipe to turbo
charge pipe to pancake pipe
n75 to tip
all to be fitted this weekend ,
then at AMD next weekend for stage two and more power ,
pics to come
spudboy6
722
114
Swindon
Today new boost pipes fitted so no more seat hoses on boost side ,
Turbo to charge 90" elbow
Charge to pancake
Custom pancake pipe
Pancake to cooler
Cooler to inlet
Also n75 hose and DV hose
spudboy6
722
114
Swindon
Mid way through my next venture spent a small fortune this week ,
Welly cooler
Bam manifold
Bam injectors
7bar in tank pump
Bam charge pipe
Custom charge elbow
Catch can
Will delete SAI Etc
Pcv simplification
Still to buy
KO4 turbo and manifold
spudboy6
722
114
Swindon
Today I started my conversion , BAM inlet on to an AUQ allowing for a proper intercooler ,
It's a really easy conversion and I will list all the parts required and rough estimated prices in the oncoming days
Here some pics old v new
spudboy6
722
114
Swindon
This week , I got a cupra r front bumper from Ronin225 , had it resprayed and new grill and splitter and she's on
Tomorrow it's being mapped again as sai delete is giving incorrect flow even with resistors in , also having few other bits mapped in like bigger injectors from the 225 , wil report back on that tomorrow ,
dubslife
booost
Jul 30, 2010
81
So much win going on with this! Would be curious to see how it looks from the side with the front bumper? Was considering this when I had mine but thought it would need skirts to?
spudboy6
722
114
Swindon
I'll get you a pic later on , to be honest you can't even see the bumper past the front wheels , but I'm going
To do the skirts soon ,
I'll keep this updated just on the rolling road as we speak
spudboy6
722
114
Swindon
She ran 223 WHP which converts to about 256BHP and 273ft-lb ,really pleased as was running more (300ft-lb) but wound it down as rods wouldn't last long in that state of tune ,
Next is to forge the engine and go big turbo ,
No longer tuned by AMD ESSEX as they couldn't remove EML from SAI delete or map in launch control or flat foot shifting which my new tuner can and has videos to come
spudboy6
722
114
Swindon
Clutch started slipping as expected with upped power , Now running valeo single mass flywheel and clutch conversion kit fitted it this morning took about 5 hours so quite an easy clutch to change
spudboy6
722
114
Swindon
Just retro fitted cruise control . Very easy and simple enough
New disc and pads all round
Got round to fixing the broken bit on my centre console after three years
Poly bushed whole front end with psb bushes from eBay , really good fit and quality
Painted calipers
Fitted a forge oo8
Changed spark plugs to 1 heat range cooler as advised by tuners to keep head cooler
Then I managed to help my friend wrap his bonnet after a deer decided to re-arrange his front end and we couldn't fine a platinum grey bonnet anywhere !
Here is the car with the bike that forced me to get a tow bar :(
spudboy6
722
114
Swindon
Big changes coming ,
Did a track day and she performed well keeping in tow with the s2000 and mx5 turbos , was pleased
Possibly the only yellow Toledo out there coming
spudboy6
722
114
Swindon
Today I fitted a flat bottom steering wheel I had made , takes original airbag and is a modified original wheel , was £130 plus £20 postage .
