Map sensor
MK
Hi
I have been told my ibiza 1.4 has shown a map sensor fault code on the diagnostics, have been quoted 100 quid by garage, seen map sensor for my model on ebay 30 quid, are these easy to fit? does it require any setting up?
LregG
map sensor measures air pressure in the inlet manifold (found after throttle butterfly)
maf sensor measures quantity of air going towards inlet manifold (found before throttle butterfly)
Is it a mk2 ibiza?? If so then the map sensor is more than likely in the ecu
