Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net Sponsors - Trading area » Forge Motorsport
Forge Motorsport Manufacturers of VAG Turbo tuning accesories Custom build intercoolers , Diverter valves , Blow off valves , Forge Silicon Hoses by siliconhoses.com
Closed Thread
Thread Tools Rate Thread Display Modes
Old 04-12-2006, 17:36   #1
ForgeMotorsport
ForgeMotorsport's Avatar
ForgeMotorsport has 10 points
Servicing on the 007 dump valve
We would normally inspect the valve every 12000 miles or so .......
In order to determine if the valve requires a service I would recommend that you carry out the "leak back test" , in order to see if it is required.
1. Simply push/displace the bottom piston up to the top of the valve either using your finger, a pen or any suitable implement, whilst doing this cover the top small vacuum nipple with your index finger.
2. Leaving your finger covering the vac nipple, remove the pen, the piston may drop approx 5mm but should then stay in position by vacuum.
3. You should now see through the bottom port that the piston is held/drawn to the top of the valve .
4. Next, remove your finger from the vac nipple. The piston should return to its seat.
5. Repeat this test several times and if there is no gradual leak back all is satisfactory and the valve can be refitted to your vehicle.
6. If however the piston moves back down, whilst you have your finger covering the vacuum nipple, the valve requires servicing. If this is the case please order a service kit from this link
http://www.forgemotorsport.co.uk/con...product=FMDVSK
Item 2 . we do not upgrade the springs on the cars we tune at Forge , however some customers feel that this modification suits them , if you would like to order on line please go here
http://www.forgemotorsport.co.uk/con...duct=FMDVSU110
ForgeMotorsport is offline
Closed Thread
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 547
&rew, -=Rob=-, -pseudonymous-, 03cupra, 2die4, 2footpegs, 45_CB, 51mo, 8bit, AaronGS, aaronipswich, AC, adam cupra 20vt, Adam's Cupra, adiohead, adp, ad_182_uk, ajay_parekh, Al Wyn, alans, alexbradford, Allan Andersen, Allan_84, Allen, allyboy, Ami-Jane, ammo, andieleon, andreww, andy.morgan, andy68, andyc58, andypower, andy_lang, anthony37, Ape, Applemobile, arron2004, AshleyBOC, aterro, aviii, AzzA Dobson24, Azza_, b1nuzz, bakester69, barney501, bbewekim, BearAttack, beastgtir, belfastchris45, Ben-ibizaFR, ben@amdessex, bendohhh, benjiwales, ben_edwards30, BEOWULF, Berg, bh1kh4, big eck, Bigjohn84, bigrick, Big_daddy, Bikerz, billyhas, Blucupra, BlueCupra01, Bolland, Booby Supper, BoomhaueR, Bouncerbeater, Br!dges, brad1002, Breezapom, Bret, brwmogazos, budweiser28, bully, Burnz, c-n-d21, Cammy, cap r 225, carew, carl_ep91, casper20v, CatB1, CD, chaazza, Chambers_CUPRA, Charlie20v, charlie_j17, cheungy, Chino_UK, Chris rickard, Chris-cupra R, chrispcupre, chrissy1502002, Chrissy20vt, Chuggy, CJRamze, coldturkey, conc, ConnorWatt, conorc, Conzo_f, cookieboy, coops10, CooptoCupra, Cos, CovCupra, Cowie, Crafoo, Craigus, Crize, CrossyR, Cupra Grant, Cupra R101, Cupra Ross, Cupra-cal, cupra-db, cupra-gaz, cupra.al, cupra02ben, cupra118118, Cupra137, Cupra20v, CUPRACAR, cupradan, CupraDaveG, CupraDean, Cupraken, cupramillo, cuprapowerpaul, cuprarsam, CupraSean, cuprastupot, cupratdi-matt, cupratune, cuprawill, cupra_ad, Cupra_collins, cupra_jobe, cupra_matt, cupra_poolie, cupra_r_04, cupra_tan, czaki, D.K, D3DNA, d3m0niTe, d4ns, Damoegan, Danaxeman, DandB, Daniel 1.8t, dann, DannyJigg, Danny_B, DaNnY_LaD, dav3, Dave 77, davegrayburn, Davem, davidcupra, davo_turbo, daz20vt, daz_cymru, Daz_Wilko89, Deejay, defected123, dentist, dezthestig, DGF264, diggerbucket, Dione J, DJ-LIAMC, DOLBY, Dougy, Dozer360, drty--den, DubSteve68, D_O_U_G_I_E, edmong, ejarvo, EL, eltel, escovedo, everitt1980, F1990, Fahid82, Faisal, FASTER, fATCH, fcuknafe, Ferryman, FishmanUK, flares, FLK, ForgeMotorsport, fourtwofive, Fox god, frenchman, frijj, Fu Shou, fuzzgeller, G3K, gary_cupra, gavbey, Gaz5350, gazbrum, gazR, gb, George 3G, George657, gezmeister, gillygilbert, gingerben, godber225r, Goo, Gooner_Mike, GrantM, Gravesie-363, Gray & Kirsty, Greavesy, greesha, GregLCR04, GREG_R84, GreigAKAHendo, Gubien, Guffers, h22_dan.., h7 cya, HallycupraR, Hamzilla, hardcore4, Harris., Hartosh1, harty190486, Havok316, Healyrae, heggie, hendo#1, herb2578, Hilla LCR, Hobbiniho, hyphon12, ianmessy, Ibiza125, ibizatom, IH786, INA, irf, J0N, J19 MRD, J@mes, J@mes W, Jackkk, jake, james walker, James.Judd.1, james.l, jamesypyk, james_cupra, jamfull, Jamie P, jamie1, jamieread, JamJay, jamski, jase20vt, jasecx, JayFR150, JCLCR, jcorky, jcullen88, Jedcupra, Jii, JKM, JMP, joe-20vt-toledo, JoeCav, joe_thompson, johno1404, jonathan_phang, jonesy118, Jonny, Jonny95 SXE, JONNYVT, JU5 2 SLY, jwfcms, K1Shane, karls cupra, keaney, kegger, kevlpool24, kinder, Klone, Kris@Forge, krisbutler02, kriso, l.e.star, L14M H, L31GH C, LandanSam, LCR 225, lcrsammy, LEE69, leegreenaway, lee_fr, Leigh200sx, Leigh_o, leon cupra r, lfc4life786, Liamx, living2xs, lmow01, Longy82, loonitic, lordgibbness, M14KCY, M3rta, maberzee, mackgold, madmonk, Magnerz, marco cupra, marconi118, mardon, markbrum, markgb, Markyboyt, marshyc, Martinscaff, matt88 lcr, mattyholmz89, matty_fr, matylad, mc funbot, Mick288, mike000, miller 666, milner575, mini_hammy, MisterD2010, MitraShark, MM95, Mo Arif, MonkeyTibs, Mooks, mookster, morrischad, motty225, motty_90, MrBen2k7, MrNailer, MrNorma, mrvavavoom, mrwookie, Mr_Dave, mt audio, munkyboy, muttly, Mylo, n1ff, N3 CPRA, NAB_ARCK_86, nathal, nd-photo.nl, neil, NiallCupra, Nicholai, nicksxjr, Nick_A, ntcupra, nutter_engineer, OFI, oneofthetwins, OvEr_KiLL, OVNIWCE, Ovni_cupraR, ozzymyster, p34ch3y, Pander, paul-murphys, paultownsend, pedro1989, pete147, peter_cupra197, Pew., phatchoonz1, pillboi, PiperRS, pj1985, Pommeh, porterbmx, Prebs, prezf, psycho6285, Purespeed, push, QU4RESMA, R1ch85, R3ign, RabReith89, rackha, RaggedLob, Random1989, rasco, Readie46, Readiee1.8t, ReDBull, redcupraboy, Ric 2001, Ricardo, Rich79, Richy Cupra, RichyV, rk696, Rlawrie45, RobDon, robertbadlad, robertj, robjnr, robk2009, Rocky Rocastle, RodneyA, Roffel, roger1965, rogers, rogerw86, Ronin225, Ross_Cupra-R, rs-tuner, rteone, RW20VT, ryan106, Ryan6926, S's Cupra, S15YCE, s1l3nc3r, s1mon, Sam B, sambryant, sam_cupra_R, ScoobyJawa, scottc1088, Scotty229, Sean1060, SeanyK, seatcupramad23, seatstu, shaun., sheffboy, sheph4rd, SidewaysCupra, sie77, skinny04, SlimLCR, smiff, smithsc, Snower20vt, SNOWZ, sonic_vi, speedinsaxo, speedsix, Spirit Furtive, Spurt, Squintstream, ste-lfc, Steely, stef cupra, SteveCl, STOCKY, Stoker20VT, Stuart83, Stuart_cupra, stupac, styling, supa_sam, super_electric, suukmiideek, swoosh225, Sxanth, t0m, TAFFY aka beast, TAOTAO, tarzan, TazLCR, TheBigGM, thehawk18, Tim_Rooi, TINCAN, Tiz Cupra, toledo sport, tom w, tomatcess, TOMSY, tonycane, traumapat, trebormint, Trublu07, TRUMPY, TubbyTwo, Tucker157, turbo009, turbos, Twiggy86, tyrer, UFO Yellow, v-g, v0id, vagman2001, vaudaz, Vaughny, venner, Vrchris, vw-aj, vwbassett, vwsean, W11TTX, w1ll0711, w8scc, wade.k10, wakko, Watson©, Wazuke, welchy, Weler, wigz45, wild willy, wilky19, will130787, willows86, wilz1234, wisejason, Witalik, worzel, x24sevenbikerx, xDaNx, xSCYTHERx, Yaboy, YIN, Yosh, ySoCereal, zan, _chris_
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
intake dump valve location?? loveturbopower Ibiza Mk3 20 21-09-2009 09:45
Recirculating Dump Valve Question sporting wood Leon Mk1 42 26-03-2009 14:09
Dump Valve Help cupra_tan Leon Mk1 16 25-03-2009 23:16
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
