Listers - Parts
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 06-01-2007, 14:09   #1
higgsy regulato
Posts: n/a
Question dump valve problems
I was thinking of getting a dump valve for my Seat Leon Cupra 180bhp, I was told that it doesnt sound good and it is pointless.
Any ideas or suggestions.
true or false:
The valve on the car now leeks and is a common fault with the car.so it is really running at about 155bhp.so when you fit a dump valve the ecu picks it up as a leek and slows the presure of the gas causing a swoosh not whoosh.A seat mechinic said to get round it is to use a powertec st/st induction kit which will echo the sound and change the valve to a recirculating valve getting the closest to a sound you want to here. This should regain the lost break by tricking the ecu. please help
This does not happenen on cupra r.
  Edit/Delete Message Reply With Quote
Old 06-01-2007, 14:16   #2
higgsy regulato
Posts: n/a
true or false:
Old 06-01-2007, 14:19   #3
CupraUK
Pushing on
CupraUK's Avatar
CupraUK has 10 points
If you put an atmospheric dump valve on a 20vt it will throw a fault code.
You can hear the diverter valve working much louder by replacing the air filter
Some diverter valves are quite loud, I can't remember what Mike_Ibiza has got but its quite loud, I think its a bailey. Forge tend to be silent.
__________________
Now : 2014 Leon FR184
Past : 2001 Leon Cupra - Stg 1 Revo, EIP Shortshift, vented arch, Forge 007, ECS N75, HPA mounts, Pipercross panel filter, N249 Bypass - 211bhp, 14.6 1/4 mile
CupraUK is offline   Reply With Quote
Old 06-01-2007, 14:19   #4
richybigman
Senior Member
richybigman's Avatar
richybigman has 10 points
What valve do you have fitted?
__________________
Work Page
richybigman is offline   Reply With Quote
Old 06-01-2007, 14:20   #5
DPJ
DPJ has 10 points
Hi and welcome
It's not necessary to post twice. I don't think you've read the rules or done a search on your question have you?
Here's a tip, do a search for "wooshy dump valve"
__________________
Dave
dpj@seatcupra.net
...............................................................................Alhambra Stylance 140Tdi...KiwiCupra 8v...387.7bhp Leon Cupra GT
DPJ is offline   Reply With Quote
Old 06-01-2007, 14:20   #6
richybigman
Senior Member
Atmospherics do work on the 180bhp 1.8T's
__________________
Work Page
Old 06-01-2007, 14:22   #7
225
225's Avatar
225 has 10 points
All the 1.8 t variants do not work properly with an atmoshpheric dv, buy a forge 007p and an induction kit. Do a search for whooshy dump valves, it is the most commonly asked question in the world ever.
__________________
225 is offline   Reply With Quote
Old 06-01-2007, 14:23   #8
DPJ
DPJ has 10 points
Quote:
You'll take responsibility for his damaged engine?
__________________
Dave
dpj@seatcupra.net
Old 06-01-2007, 14:24   #9
225
225's Avatar
225 has 10 points
All the 1.8 t variants do not work properly with an atmoshpheric dv, buy a forge 007p and an induction kit. We are not going over this yet again.
__________________
Old 06-01-2007, 14:26   #10
richybigman
Senior Member
Quote:
Can you explain to me how it can damage his engine?
__________________
Work Page
Old 06-01-2007, 14:27   #11
m0rk
sarcasm comes free
m0rk's Avatar
m0rk has 100 pointsm0rk has 100 points
http://www.seatcupra.net/forums/show...7&postcount=57
__________________
[/right]
m0rk is offline   Reply With Quote
Old 06-01-2007, 14:46   #12
richybigman
Senior Member
Interesting read, cheers.
__________________
Work Page
Old 06-01-2007, 20:03   #13
higgsy regulato
Posts: n/a
cheers for your help. did not do a search.New to the site, i think ill just get a induction kit,4 bar pressure regulator, cat back and a remap.
Old 06-01-2007, 20:53   #14
CupraUK
Pushing on
CupraUK's Avatar
You won't need a 4bar pressure regulator unless you are going for a stg 2 remap (which you may as well do if you are getting the cat back too!). The price difference (from a revo point of view, not sure about the others) is small between stg 1 and stg 2.
__________________
Old 06-01-2007, 21:02   #15
higgsy regulato
Posts: n/a
Iam goin for a stage 2 not sure when thou its all money!
Old 06-01-2007, 22:37   #16
CupraUK
Pushing on
CupraUK's Avatar
You could always get a stage 1 remap first when you have the cash for that, then get the 4 bar and exhaust after, then you just need a stg 2 upgrade to your remap. That way you can get lots of extra power quickly without waiting and getting it last.
__________________
Old 07-01-2007, 13:11   #17
Big_daddy
Going going gone.....
Big_daddy's Avatar
Big_daddy has 10 points
CAN A FORGE 007p FAIL/ PLAY UP? ANY SYMPTONS THAT YOU COULD SPOT?
Big_daddy is offline   Reply With Quote
Old 07-01-2007, 13:16   #18
Mitchy
TTRS
Mitchy's Avatar
Mitchy has 10 points
Yes wastegate chatter meaning the valve is sticking.
The usual woosh noise becomes a suirrely type noise
Mitchy is offline   Reply With Quote
Old 07-01-2007, 13:20   #19
CupraUK
Pushing on
CupraUK's Avatar
Quote:
I love that sound on highly modded LC and LCRs as the DV struggles to vent
__________________
Old 07-01-2007, 13:21   #20
CupraUK
Pushing on
CupraUK's Avatar
Quote:
Forge DVs have a lifetime guarantee, give them a call if you suspect its faulty, their customer service is legendary. They will probably send you a service kit which pretty much replaces everything anyway.
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 150
03cupra, 2die4, aaron-gardner, addavis89, Andre B, andytaylor1980, as92lv, Baker92, BenCupraR, Benjuan, bh1kh4, big deano, Big Lebowski, BlueCupra01, bo!, Bobs_cupra_r, bogs, bournemouthal, BPrudence, Cabbage, cf22cupra, Chri$, chris_lcr, Coffeelio, Conzo_f, Crabby, Cupra Ross, cupra118118, CupraDaveG, cuprajose, cuprapete, Cupra_Chris, cupra_r_ick, Danio, DannyB_21, dave92en, DaveJL, davidhunter, dazescort, dazza1414, Dazza88, deajam, deansutherland, dj_troopa, doodle86, Dozer360, Ed +, effess, frost87, gavyn g, Gaz5350, Gazaho, gazbrum, ginger9860, Graeme74, Graham1984, Graham89, Gui, gunnergibson, h7 cya, hairy_child, harj, Hedgehog Dodger, henryvx, Hopkins9205, hotrodisgod, ianmessy, ilovemycupra, Impulsive87, J0n3, Jackkk, james0560, Jamiec89, Jammy.lcr, jaydenturbo, Jimmy3rown, johnny_reyno, Jonnyj88, Josh Holden, kpm197, leegreenaway, leon.cupra, leoncupra2012, Leoncupra79, lewis20vturbo, lofty987, luppy, mackgold, mark garfoot, MatP, matty85, micaley, mike.ford84, milner575, mk4 cupra, N3 CPRA, nath86, nathal, nathan_20vt, nazamin, Northy 8, Olivermalyn, philguy1992, phillip877, pillboi, powerdbycupra, pugparcels, Purespeed, R333DDX, rackha, RaggedLob, rbooth1984, richie kaye, Rob Kelz, sambmx, scotty18, Shields, Silentnight*, si_88, slimwiltaz, Smcdee, Smoke'n'poke, SNAZ85, Snowsurfer, spudboy6, Steveboy86, stevievegas, stuibaby, terryliggins, Terrywoo, Thafussa, ThatCupraGuy, thecrow85, Tombob1080, tony08hooper, Trainer008, Trigg, trouble-with-id, tsotd, Twisted1, v0id, weeally, wezy0, will.i.am, Will89lcr, wilz1234, window60, Worthy93, xdelboyx, York
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
dump valve? Jontys Ibiza Mk3 2 29-11-2006 18:21
Forge Dump Valve rubbing TimBarratt Leon Mk1 8 18-11-2006 18:31
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
