Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net additional Resources » Frequently Asked Questions Section » Problem Issues Q&A
Problem Issues Q&A A place for common issues affecting any specific SEAT issue, or tuning problems. If you have problems and are looking for answers this maybe a place to start.
Reply
Thread Tools Rate Thread Display Modes
Old 21-04-2007, 14:42   #1
monkey73
Posts: n/a
Engine management light - ibiza 2002, petrol 1.2
Hi all,
I've searched the forums and as I dont have a Vag Com and no warranty - just need a bit of extra help/advice before I take it to the garage (or not).....
Have a 52 plate 1.2 petrol ibiza with no mods and the engine management light came on yesterday when I set off for work.
The engine sort of stuggles/shudders when it's just idling (like when stuck at lights etc) and stalls unless I give the accelorator a bit of a push. The engine light flashes slightly before staying on constantly again.
Then when I drive off it shudders slightly again, before being fine also sometimes shudders slightly if I try accelerating hard.
Other than that seems to be fine, no fumes, revs look ok and no drop in speed.
From what I've read I gather it's prob the spark plugs / coil packs... what do you think?
If so are they easy to replace myself? Can I just get them from Halfrauds? Is it expensive?
Can I call my breakdown service to do it (even though the car still drives)?
Will I be ok driving it, till it get's fixed???
I know I should try and get someone to do a diagnostic on it etc. but would like to try and do something myself first if possible.
Sorry for the essay, but I'm getting a bit fed up with the car at the mo - just had to replace the drivers side window modulator today for the 2nd time !
Huge thanks.
Robb.
Old 21-04-2007, 14:43   #2
m0rk
sarcasm comes free
m0rk's Avatar
m0rk has 100 pointsm0rk has 100 points
Quote:
You know you're right then! if you can, get it scanned - it'll save you guessing all the while otherwise
__________________
[/right]
m0rk is offline   Reply With Quote
Old 21-04-2007, 20:00   #3
monkey73
Posts: n/a
I know, I know....
I was just wondering wether it was worth a try.....
Plus it's more a case of how safe am I driving it ?? I'm taking it very easy and not pushing it.
Had a look under the bonnet today and all seems fine, belt's ok etc. Started it up and starts off alright but a minute later if you leave it running it splutters a bit, shudders and then stops.....
Hoping to get it into a garage on Monday
Old 21-04-2007, 20:01   #4
m0rk
sarcasm comes free
m0rk's Avatar
Yellow light = OK to limp somewhere
Red light = stop now, drive no more
I don't think there's one that says "go on, you can drive it to the pub & it'll be OK" sadly, so I'd lay it up until you take it to the (nearby?) garage
__________________
[/right]
Old 21-04-2007, 20:25   #5
monkey73
Posts: n/a
Cheers Mork.
Just leaving it where it is at the mo, then will hopefully be ok for me to get to work/the garage on Monday.
Live in Chester, Work in Liverpool (about 50 min drive!) so keeping my fingers crossed - they can fit me in and get it done the same day.
Thanks again.
Old 24-04-2007, 20:04   #6
monkey73
Posts: n/a
Ok - Back from the garage (AlexLawrie Skoda) nothing fixed, as they say the stealer have to do it !!???
They did a diagnostic quite cheap though and cleaned my car (!!) seems there's two probs:
EGR - control difference - sporadic
Clylinder 2 Misfire - sporadic
They also said I needed a software update from Seat ??!
Called Seat in Warrington (IMG) and they can't get me in till 15th May !!!
Any ideas if I can do this myself? I'm guessing the coil packs would be fine - but where to get them?Is there a specific product code? and anyone know of anywhere else I could go to get them done ?
Cheers.
Old 05-08-2007, 21:48   #7
Cookster
Posts: n/a
Hi, I bought my Ibiza 3 days ago and the engine light came on today.
Same as you, shudders when idle etc.
Just wondering how you got on in the end?
Got a warranty but wasn't bought from a Seat dealer.
Old 12-08-2007, 17:57   #8
leonbeastmk1
Posts: n/a
hello workin in a seat dealership myself i kno u can get the coilpacks at your nearest seat dealership and they are easy to fit. The EGR vavle itself is easy to fit aswell but both faults will have to be earased by the dealer aswell as the software update cheers
Old 10-09-2007, 23:44   #9
ugly
Posts: n/a
Hi i read that you work for a seat dealership is it possible for you to tell me how i can get the black engine cover off my seat ibiza se 1.4 2003 model so i can replace the spark plugs as i to have a misfire?
Thanks for your help.
Old 11-09-2007, 19:05   #10
leonbeastmk1
Posts: n/a
Answer to engine cover trim
I'm sure on those models they have a big square cover that cover the whole engine,if so then yes it's possible to remove. The trim itself is held on by rubber plunger bits so all you have to do is lift it of, it will feel tight to begin with but it will pop out
cheers
Old 10-02-2009, 21:00   #11
derekdiggs
Posts: n/a
good thread to help with this prob
seatcupra.net/forums/showthread.php?t=141031
Old 29-04-2009, 16:46   #12
amandaseatibiza
Posts: n/a
also helps me with the problem im havin with my seatibiza 1.2 aswell thanx
Old 26-10-2010, 00:10   #13
phillpotts92
Buy Cheap, Buy Twice! :D
phillpotts92's Avatar
phillpotts92 has 20 points
i have same issue
phillpotts92 is offline   Reply With Quote
Old 26-10-2010, 00:10   #14
phillpotts92
didnt do it in my old beeza tho and that was 52 plate
Old 26-10-2010, 00:11   #15
phillpotts92
my new one is an 06 and it has started doing it!!! its really annoying
Old 26-10-2010, 00:11   #16
phillpotts92
it only happens when i give it some beans off the mark though!!!!!"!
Old 26-10-2010, 00:12   #17
phillpotts92
sorry about all the posts but im a newbie and have to up my posts lmao!
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 41
andy17, Arkaig, AvoK95, BeezaDave, benny12357, Blanco92, chris_200120vt, coalport, Connor7, creatz, cuprajose, cupratune, daza b cupra, Delfine, dunjamon, eccles1990, higgi, highguyuk, holmesy55, ibiza64, Jordanwaterhous, jtonline, Khaosie, Kie183, kriso, leoncupra2012, markisgoing, maxlifo, phillpotts92, Reload_6, rf860, Rhys_Walters97, robo2731, seat-newbie, teeth2k, thatguycraig, the-dubster, Wilber, X MA7T, Zappa
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Engine Management light blackturbo Ibiza Mk3 31 03-04-2007 16:22
engine management light on...... quick lambda question? sean h Ibiza Mk3 7 16-02-2007 15:46
Engine Management Light On hardyj Leon Mk1 7 05-02-2007 14:10
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
