Monster Motorsport
SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1 » Hid's affecting radio signal.
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Old 21-04-2007, 17:29   #1
Mr_Magistus
who am i???
Mr_Magistus's Avatar
*** posted this on the fitting guide too for suggestions
*** fitted a set of HID's but when on they are affecting the radio signal. *** done the following
1). disconnect both and tried my old bulbs....radio is fine
2). connected left side only.....radio affected
3). connected right side only....radio affected
4). removed and re-fitted them and still no joy....
anyone anymore suggestions?. *** got the standard seat radio in.
Mr_Magistus is offline   Reply With Quote
Old 21-04-2007, 17:30   #2
Mr_Magistus
who am i???
And can someone tell me why (I ' v e) comes up as ***
Old 21-04-2007, 17:55   #3
ChrisUK
Eat My Smoke
ChrisUK's Avatar
txt speak filter
__________________
Leon FR TDI - BAS Stage 2 Remap|Sachs racing clutch|HID's|Uprated dogbone mounts|Tinted rear lights|Green panel filter|Re-spaced Leon|Custom rear strut brace|De-Locked|Cupra front grille badge|Chrome grille|Chrome mirrors|Sparco front strut brace|Civic aerial|Fabia rear wiper|JBS short shifter|Cupra R Splitter|BT Pioneer HU|RA Compact|Foldy heated mirrors
ChrisUK is offline   Reply With Quote
Old 21-04-2007, 17:57   #4
Brummy
Winter-Mode
Brummy's Avatar
Location: I tell you, you tell someone and before you know it, everyone knows where I am
you need to put the apostrophe in, fella...
bloody commoners.. learn to spake proppa.. wassamadder wiff ya?
__________________
John
My Car
Brummy is online now   Reply With Quote
Old 21-04-2007, 17:58   #5
dmmsta
Sold car - bought bike
dmmsta's Avatar
It's only "i v e" (***) that get's filtered "i've" is fine...
__________________
The Dmmsta ...
Flash Red Leon Cupra - Gone but never forgotten!
dmmsta is offline   Reply With Quote
Old 21-04-2007, 18:02   #6
dmmsta
dmmsta's Avatar
Just had a thought, is it acutally drop of radio signal or is it earth static from somewhere...ie - does it do it when tape / CD's are played or just radio?
Where about's are you located?
__________________
The Dmmsta ...
Old 21-04-2007, 18:08   #7
tinbum
tinbum's Avatar
Quote:
I agree, very likely to be an earth problem, dont see how it could actually effect the radio signal !!!
tinbum is offline   Reply With Quote
Old 21-04-2007, 18:56   #8
Mr_Magistus
who am i???
Doesnt do it when ive got the CD or tape on at all
Old 21-04-2007, 19:48   #9
Cyclone
Newbie
Cyclone's Avatar
When these lamps are in operation a continuous arc is produced across the two electrodes which causes the gas/metal combination inside the glass tube to glow and produce light. When the flow of electricity is forced to arc, it sends out an electromagnetic pulse, which is the cause of your interference on your radio.
Radio receivers are very sensitive to this type of interference, and as the lamp is constantly arcing, the interference will probably be heard as a buzzing.
The best advice I can offer is to make sure your lamp ballasts and cables are well away from your aerial coax. Also make sure the coax sleeving is correctly connected as it's there to shield the main signal in the centre and prevent interference.
Cyclone is offline   Reply With Quote
Old 21-04-2007, 20:09   #10
Mr_Magistus
who am i???
Wheres the ariel coax cable then please?
I`ve got one ballast stuck to the water bottle and the other to the side of the battery.
Old 21-04-2007, 21:21   #11
RobM
Disturbed....
RobM's Avatar
Mine are in very similar positions to yours and I have no troubles. And as far as I know, all components of the audio system, including the radio components, are well away from these areas.
I think it might be something to do with the powered aerial, but I'm just not sure what. The only thing I can think of trying, is ordering the wiring harness to go along with the HID kit. There was one for sale in the For Sale forum here recently, so might be worth checking to see if that's still for sale before ordering though.
RobM is offline   Reply With Quote
Old 21-04-2007, 22:32   #12
Mr_Magistus
who am i???
Im right in saying its Red to blue and Brown to black for the wiring.
I had the HID's off a mate and he says they were ok but couldnt say if he had notice any chance in the radio
Old 22-04-2007, 00:14   #13
dsrr
dsrr's Avatar
It's down to different brands of HID's, I have 2 x HID kits fitted, one to the Main which doesn't cause any interference and one to the driving lamps which does but only on stations with a fairly weak signal, down to the shielding used on your kit
dsrr is offline   Reply With Quote
Old 22-04-2007, 01:11   #14
Cyclone
Newbie
Cyclone's Avatar
If you're using a signal booster for the radio, then that would certainly amplify not just the wanted radio signals, but also the interference from the lamp system.
The coax aerial cable goes from the aerial at the rear of the roof, to the back of the radio slot. Checking the outer copper shield is intact in the coax going into the back of the radio could be a start.
Otherwise as dssr says, could be poor shielding on your ballasts.
Can't really think of anything else other than putting ferrite blocks on the back of power cables on radio to absorb unwanted RF? That's probably a long shot though.
I'll have a think!!
Old 22-04-2007, 11:16   #15
tinbum
tinbum's Avatar
Simple answer, dont listen to the radio !!!! lol
Get an ipod
Old 22-04-2007, 12:07   #16
CHR15B
Still driving a Passat!
CHR15B's Avatar
I had this problem with the Toledo, but don't notice it anywhere near as bad on the Ibiza.
__________________
Not driving a SEAT anymore!
CHR15B is offline   Reply With Quote
Old 23-04-2007, 09:49   #17
Mr_Magistus
who am i???
Quote:
Thanks, Any ideas on whats the best way on shielding the ballasts?
Old 23-04-2007, 09:55   #18
dsrr
dsrr's Avatar
You can get plug in ballast shields, I looked into it but the interference is so little only notice it on quiet tracks with a bad signal
Reply
Bookmarks
Tags
affecting, hid, radio, signal
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 13
1.9...stefan, adm013, barcode1001, barry4ord, ChrisG, george130, ini, lotusandy, mickhep, mikkeli, mt audio, Staff25, stusweeney
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Error Codes Sharky_82 Ibiza Mk3 50 23-04-2009 19:53
Cupra Radio - Problems/Interference with MW? SeanyK Ibiza Mk3 5 19-03-2009 11:32
Poor Radio Signal ADAM_84 Leon Mk1 39 21-10-2008 11:06
Radio interference/cutting out simonlid Altea - includes XL and Freetrack 1 04-04-2007 15:16
help with bad radio signal? moditsteve Problem Issues Q&A 2 02-08-2006 21:15
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
