Jabbasport
SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1 » clutch problems on my LCR 03 plate AMK
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Old 06-05-2007, 17:50   #1
bigger_bish
Question clutch problems on my LCR 03 plate AMK
im having problems with my clutch.
i work in a garage/motorfactors (not as a mechanic, in the parts dept.) so im getting the parts + work done there.
the origanal problem was the pedal would go to the floor and i had no clutch.
we traced this fault to the slave cylender (master cyl is ok).
so out with the gearbox.
while the gearbox was out, i decided to replace the clutch and flywheel as they where showing signs of wear and to save future problems. so with the new flywheel, new clutch and new slave cylender, we put the gearbox back in.
next job was to bleed the system, it was a bit of a pain, but it was done in the end, the clutch pedal was back to normal, allbe it a little light.
the clutch wont clear. cant change gear with the engine running.
we have called the LUK tech help line, they say to change the master cyl as well, they didnt give a reason, just said that because we have changed all the other parts it must be that. but that was tested before anywork started, so we know thats ok.
we have called seat, they say thet there are a right pain to bleed, and thats probably the problem.
all the parts fitted are LUK, i sell them everyday, and have never had problems with them.
the tecnitian thinks that the fingers in the clutch are not right, too weak. so i have ordered another clutch, and the box will have to come out again on tusday.
has anyone had this problem before? anything else it might be?
any suggestions or comments welcomed.
bigger_bish is offline   Reply With Quote
Old 06-05-2007, 18:10   #2
bentaw
Revo'd LCR
bentaw's Avatar
how many miles has it done
__________________
Revo'd to 250.2bhp and 301lbs ft. Next i need someone to detail my car then onto suspension
bentaw is offline   Reply With Quote
Old 06-05-2007, 18:10   #3
sebasti0n
R u sure it was the SLAVE.... I have a standard LC and had the same problem with the clutch..... after phoning around several garages the opinion is that 9 out of 10 times its the MASTER..... As I don't trust garages and there is several hundred's of pounds difference between the 2, I decided to take a chance and get the Master changed at my local Garage.... Clutch all Ok now.
sebasti0n is offline   Reply With Quote
Old 06-05-2007, 18:17   #4
bigger_bish
its done 41k miles
i have read on this site that its more commonly the master cyl. be he did carry out sevral tests and diagnosed it as the slave. he might be wrong tho, but i would think it unlikely. i told him it is most commonly the master, and he did sevral tests on it. he a good mechanic, but even then mistakes are still made. so im not really sure!
Old 06-05-2007, 20:40   #5
wild willy
wild willy's Avatar
Out of curiousity how long does it take to remove the gear box from a LCR and do a clutch change.
wild willy is online now   Reply With Quote
Old 06-05-2007, 21:51   #6
bigger_bish
the book time to do a clutch is around 4.5 hours
Old 06-05-2007, 22:07   #7
vern
Derv power!!
vern's Avatar
Luk are good kit, it could be the Master Cyl...... let us know
__________________
Platinum Grey LCR now gone ................
Titanium Silver BMW E70 X5 SD M Sport.
Brilliant Silver Merc Vito 115 CDi Sport.
vern is offline   Reply With Quote
Old 08-05-2007, 06:43   #8
Stacey R
Stacey R's Avatar
Oops found my clutch peddle on the floor last week after a night in the garage!!
Pulled it back up again and it seems ok now?? Sounds like it's going after reading this thread.
Black LCR 02 plate 50K
Stacey R is offline   Reply With Quote
Old 08-05-2007, 23:09   #9
bigger_bish
back on the road at last!
the origanal problem was the slave cyl.
the first clutch kit fitted had a faulty pressure plate, fitted another today, and all is working as it should....until next time.
Old 08-05-2007, 23:12   #10
vern
Derv power!!
vern's Avatar
Glad to hear.........surprised as LUK are normally good
__________________
Reply
Bookmarks
Tags
amk, clutch, plate, problems, seat leon cupra r
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 8
basssound, danny m, GJH1960, IH786, ja2007, l.e.star, Mark300zx, Spud_G40
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Newbie LCR problems! winston Problem Issues Q&A 3 20-09-2008 20:17
Cupra Alarm problems Edgemo Leon Mk1 15 13-12-2007 16:54
Square Front No Plate For Lcr blade Leon Mk1 3 02-09-2004 18:14
weird clutch problems dropin73 Problem Issues Q&A 1 04-05-2003 09:32
Clutch Problems? BlockEd Leon Mk1 4 24-01-2002 10:02
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
