Badger5
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 09-07-2007, 17:16   #1
junkstermac
Posts: n/a
Changing the rear brake light
Hi all,
my friend has an 04 SE and her rear passenger (RHD car) brake light is out. I took a quick look and I'm guessing you need to take the light assembly out to swap bulbs (like my custom BMW rear lights) but maybe I'm wrong
I took the plastic panel off and I can see a screw to loosen one side of the assembly but I'm not sure what to do next as I couldn't see much
or do you have to remove the whole of the plastic panel by loosening all the torx screws instead? (bit of a faff on just to change a bulb tho)
yeah I know it's a simple job but any advice and guidance is welcome
cheers
Old 15-07-2007, 19:08   #2
ibizaneal
need more mods
ibizaneal's Avatar
ibizaneal has 10 points
the brake lights are in the cluster attached to the rear quater not the boot lid(this is what i think u mean), to take that off you undo the two large torx screws attaching the cluster to the car and pull/wedge the cluster out as its two sort of spring clips holding the rounded edge in place, once this is out(it is a bit fiddly) remove the wiring connector, unscrew the phillips head screw and the bulb assembly should come out, bobs your uncle. do in reverse to put back in.
__________________
'55 plate ibiza cupra 20v turbo in red
ibizaneal is offline   Reply With Quote
Old 15-07-2007, 19:18   #3
junkstermac
Posts: n/a
Quote:
thanks for the info mate . I said the boot lid as I only came across in the car to see my mate and there was another guy looking at getting into those light and I saw how awkward it was going to be . I've since realised that is the rear quarter that are the brake lights as I've seen a few Ibiaza's on the road. I didn't even check to see which light was actually out before having a quick fiddle around so looked at the wrong light
I've seen the 2 spring clips you mention in an online pic I came across of the cluster and I remember they aren't the easiest things to get out as my old cars have had them (in indicators)
again thanks for the confirmation as I can see I need a torx screwdriver
cheers
Old 15-07-2007, 19:23   #4
ibizaneal
need more mods
ibizaneal's Avatar
i did the same thing when i came to do mine for the first time and it took me ages to get the cluster out,
__________________
Old 07-08-2007, 20:03   #5
Shortride
Newbie
Shortride's Avatar
Shortride has 10 points
Im having trouble. We can't get the cluster out when you pull/wedge the cluster out involving the sping clips.
Shortride is offline   Reply With Quote
Old 07-08-2007, 20:10   #6
ibizaneal
need more mods
ibizaneal's Avatar
you do have to pull pretty hard, i had this trouble too so i pulled back the side inner liner and put a bit of pressure on the back of the clips with a flat bladed screwdriver (this is very fiddly) the clips are pretty hard to get to but it should get it out.
__________________
Old 07-08-2007, 21:11   #7
Shortride
Newbie
Shortride's Avatar
Cheers for that. Tried as you said but still had no luck Its exacly the same on the otherside as well so I'm taking it to the dealer.
Old 16-08-2007, 15:12   #8
paule
Posts: n/a
Any other tips on getting the spring clips to release? Tried puching them with a screwdriver and no luck. Do you need to pull the cluster in a certain direction to make this work better?
Old 16-08-2007, 17:25   #9
ibizaneal
need more mods
ibizaneal's Avatar
on my drivers side i had to pull at a pretty sharp angle to get the cluster out so maybe try that, it does take a bit of force to get out though.
Neal
__________________
Old 16-02-2008, 17:19   #10
Torquemonster
Torquemonster has 10 points
Quote:
Went to replace my offside brake light today(mot next week).Had the same problems,so took it to my local garage(not Seat).Took off the 2 screws and try as they might,they couldn't shift it.Thay told me to leave it to Seat(at the mot),as they were afraid they might break it.
Never one to admit defeat,i headed off to Halfords.Told them about my problem.Typed it onto his computer and it came up 'do not attempt to fit,danger of damage to lamp cluster'!. Guess i'll leave it to the bulb changing specialists at Seat.What a joke!.
Torquemonster is offline   Reply With Quote
Old 16-02-2008, 17:46   #11
CHR15B
Senior Member
CHR15B's Avatar
CHR15B has 10 points
One of mines was a bit of a nightmare to remove, gave it a little knock at the side and it came out though with no problems.
The other came out a doddle.
CHR15B is offline   Reply With Quote
Old 22-02-2008, 17:11   #12
RichieRich
Mk4 Golf GT TDi
RichieRich's Avatar
RichieRich has 10 points
i have taken out all four before now quite easy if i remember correctly, just to do it and clean everything properly... might do my fr lights the same some day
__________________
PD115 packing 152 & 266 lbft before Turbo back decat exhaust and Egr delete, 17" deep dish Rondell alloys, lowerd 35mm, Kenwood 9 series cd player, JL audio amp, 2x Kappa comp sets, Green cotton, Black W8, TT pedals, TT Short shifter, Areo wipers
RichieRich is offline   Reply With Quote
Old 22-02-2008, 20:10   #13
Torquemonster
Quote:
MOT tomorrow morning.I can just see the service receptioist coming through to the waiting room.'I'm afraid we're having a bit of trouble removing your rear light cluster'!.Maybe someones glued it on!.Wish me luck!.
Old 22-02-2008, 20:13   #14
Fl@pper
Cruising with the 6 Pot..
Fl@pper's Avatar
Location: Easy life Cruise control with 200bhp of Bavarian RWD slushboxed Leather Comfort :)
Fl@pper has 10 points
you wanna try the new audi A3 rear lamps
right @:&£$%!£!%$£% to get off
__________________
Fl@pper SouthernPikeyBigEaredHotRoddingIronMaidenMetallicaFan@e-parts.co.uk
Fl@pper is offline   Reply With Quote
Old 22-02-2008, 20:32   #15
Torquemonster
'Makes note'.'A3 off the shopping list'!.I've owned loads of cars over the years.First time i've never been able to change a bulb....
Old 22-02-2008, 20:37   #16
CHR15B
Senior Member
CHR15B's Avatar
Quote:
If it a diesel? Try changing one of the front sidelights - theres a job and a half!
Old 22-02-2008, 20:48   #17
Torquemonster
Quote:
It's the same car as your's- 130 Sport!.How i long for my old E reg Cavalier again!.You could change any bulb in 2 seconds!.Maybe it's the shape of things to come.'How dare you attempt to do anything yourself'!.Give it to us,and we'll rip you off for the privelege!.
Old 22-02-2008, 21:05   #18
CHR15B
Senior Member
CHR15B's Avatar
Aye, got it in one buddy!
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 29
beezanick, bubbles1, Chris_a_73, CJS-90, dmjw01, Genoc, Gooner_Mike, Hartosh1, Hollow_83, Ibia FR 1.8T, Jmaes5926, JU5 2 SLY, keany19, lankman, lee_fr, lucus_j, MadFaz, matt l, munkimafia, neilo42, processpaul, retrogrrl, rocky2008, Ron Conno, RossIBIZATDI, ryan2403, SEATCOOBER, Shadders
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Brake light in spoiler Rob1977 Leon Mk1 7 13-08-2007 13:40
Brake Light - when does yours come on? FINN Leon Mk1 4 01-03-2007 17:44
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
