Jabbasport
SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk2 » Problems with new 1.9tdi Sylance
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Old 13-07-2007, 18:13   #1
Who. Me?
Hi
Just thought I'd post some problems with my 1.9tdi Stylance.
It's booked back in to the dealers next week, but I'm interested to know if any of these faults (and their resolutions) are known to others. I haven't told the dealer about all of them yet. I keep remembering more!
1/. 'Miss-fire' at 2000rpm, under load. (Think this is known to others, but hasn't been noted here for a while?)
2/. 'Bonk' noise from underneath car when reversing. (Like a trapped component, springing back in to place.)
3/. Occasional, 'gritty' feel on the bite-point of the clutch. The grinding can be felt through the clutch and brake pedals, so might just be the pivot? It isn't always there though.
4/. 'Owling' from the engine/turbo under light load at constant 2100-2250rpm. (I know this is known to others.)
5/. Water in the doors. (I know this is also known and I can't see a design fault. The door seals don't appear to obstruct the drain holes when the doors are closed. I think there is too much waxoyl in the bottom of the doors and it's causing water to pool, rather than drain.)
6/. Wet Windows (see 5 above, I reckon they're related issues)
Car is about three weeks old with 850miles on it.
Andy
Who. Me? is offline   Reply With Quote
Old 13-07-2007, 18:25   #2
googies
Senior Member
googies's Avatar
1. Mis-fire at 2000rpm uner load could be the DMF issue again?? I am having trouble with a mis-fire type fault at steady speeds , then i get a hiccup in the power!?
2. Havnt a clue, nothing stuck or jammed in, stick, debris etc?
3.When driving along, press clutch in, there is certain amount of freeplay for a few cm, but at point of pressing clutch i feel noticable vibrations?
4.Owling maybe from the N75 valve (boost Pressure Control).
5.Water is meant to be in the doors, but not pooling i wouldnt think!
6. Wet windows, still trying to get to bottom of this problem, booked on for next tuesday (3rd time! Not happy, 5wks to get a tweeter replaced and mis-fire looked at even with previous visits! Muppets) so will hopefully get it fixed, am sending them to this site if they start to give me lines again!
__________________
2005 Toledo 1.9 PD TDI - Lluvia Blue - Seat Mats - Ultimate 6000k HID's H7R - Debadged - Modified 17" RS8's in satin black - Chrome Mirror Covers - MudFlaps' - Smoothed box:blink - Picy's Here
googies is offline   Reply With Quote
Old 13-07-2007, 22:02   #3
J500ANT
J500ANT's Avatar
2) its not the air recirculation flap clonking is it?
__________________
Tony Now totally SEATless
J500ANT is offline   Reply With Quote
Old 14-07-2007, 00:11   #4
googies
Senior Member
googies's Avatar
Is 2. where the re-circulate activates in reverse, ususally only hear the air/fan getting louder.
__________________
Old 14-07-2007, 09:37   #5
Tam
Santa in disguise :)
Tam's Avatar
that will be DPF i assume and the 1.9's don't have one only the 2.0 170bhp FR.
__________________
Red Mk2 Leon FR TDI - Bluetooth - 18's - Xenon's
Tam is online now   Reply With Quote
Old 14-07-2007, 15:17   #6
googies
Senior Member
googies's Avatar
I had problems at this speed with bad vibrations and was flywheel.
it cant be DPF as the car is a 1.9?
__________________
Old 15-07-2007, 12:30   #7
cupra1.8t
leeroy
oh dear
__________________
revo stage 2,n249 bypass,de-cat,custom exhaust,17s,sparco bucket seats, hi spec big brakes, full powerflex bush kit, forge tip ,4 bar,custom front mount intercooler,got rid of aircon,carbon canister,secondery air valve,custom intercooler pipework
cupra1.8t is offline   Reply With Quote
Old 11-08-2007, 16:07   #8
Who. Me?
Car is with the dealer at the moment, trying to sort the clonk in reverse and for them to PROPERLY sort the cosmetic damage.
I had to go on a test drive with a technician to prove faults, and the only two problems I can re-create on demand are the clonk in reverse (they reckon it's the sub-frame bolts needing tightening) and the grating clutch.
The technician put the grating clutch down to movement in the Dual Mass Flywheel clutch. Anyone else find that it grates, particularly when pressing the brake pedal at the same time, and depressing the clutch?
They've loaned me an FR while they fix the clonk and the cosmetic damage and that doesn't have a grate.
Don't like the FR as much as my 1.9. It's seriously quick when it's moving, but absolutely gutless if you don't keep the revs up, especially when pulling away from a standing start.
Bog all happens, then it bites you. Not a pleasant experience at busy roundabouts.
Old 11-08-2007, 16:24   #9
Marsden1002
I am experiencing a grinding noise when braking only, but i have other problems as mentioned in a previous post with my 1.9 stylance. But they gave me a 1.6 which im not impressed with
Marsden1002 is offline   Reply With Quote
Reply
Bookmarks
Tags
19tdi, problems, sylance
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 8
coggie, davemetcalfe1, donl76, HocusPocus, huvo, leapy, neonitrix, vekic
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cupra Alarm problems Edgemo Leon Mk1 15 13-12-2007 16:54
TDI FR problems with starting mj88fr Ibiza Mk4 17 28-09-2007 21:43
2005 cupra tdi problems r555 foc TDi - SEAT Diesel specific topics 8 26-06-2007 17:31
clutch problems on my LCR 03 plate AMK bigger_bish Leon Mk1 9 08-05-2007 23:12
Ibiza 1.9TDi problems dutchdave Problem Issues Q&A 2 15-12-2005 15:14
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
