| Alhambra Use this forum for Alhambra specific topics |
Thread Tools | Rate Thread | Display Modes |
#1 |
praying mantis
turbo cut out?
hello does anyone know why the turbo seems to shut down at 3000 rpm approx on my 51 plate diesel SEmodel , when it shuts down it will not work in any of the rev range until i turn the car off and then its ok to 3000rpm again?
cheers stuart
#2 |
OEM with a 'Twist'
Sure its the turbo cutting out? and not just going into limp mode? Get it on vag-com that should give you some more info.
David. |
#3 |
Sounds like the turbo may be overboosting causing the electronics to put it into limp mode, by turning ignition off and then back on you are re setting the computer.
#4 |
Mine did that, it was a sensor gone making the ecu think it was over boosting. I ended up getting a new turbo fitted before the problem was correctly identified... an expesive misdiagnosis!
#5 |
Editing your spelling
sounds like the old overboost going into limp mode, theres ,loads about it if you search the TDI section.
__________________
#6 |
praying mantis
hello, could i ask which sensor was replaced please
cheers stuart |
#7 |
Can't remember the name of the sensor, but it was the first one after the turbo, in the manifold I think... sorry my knowledge isn't that brilliant!
#8 |
Newbie
had same prob,wastegate sticking freed off but in the end put new turbo on ok now
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 22
| 100andthirty, alan3423, Alhambra Family, cakes, cisenti, cupratdi53, dingle, Goz, ironarm, l18oud, Mike90, PlymLeon, sarnie, shaggy121, stevebee, stuart edwards, sunny2k2000, super1dude, Tricks, trinialhambra, zah1r, __B3NNY__ |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| pressure drop between turbo and throttle | robbellfth | Leon Mk1 | 2 | 10-06-2007 21:09 |
| I want a cupra R Turbo charger, but need help please!! | wazo786 | Leon Mk1 | 3 | 09-06-2007 11:59 |
| strange turbo stutter? | rob1 | TDi - SEAT Diesel specific topics | 19 | 07-06-2007 16:12 |
| turbo rest period? | cupraRgstar | Ibiza Mk3 | 13 | 01-06-2007 11:44 |
| What would cause more turbo lag.. other than my imagination? | Pabs | Leon Mk1 | 11 | 15-04-2007 09:37 |
