| Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only> |
#1 |
faster on 2-wheels
Will clearing error codes make my car run better?
Sometimes my LC feels like it is being strangled and can't get enough air. Putting my foot down causes it to stutter and black smoke to come from the exhaust. It happens most in 6th gear and comes on without warning. At most other times the car is fine if a little snappy on the throttle.
So-far I have;
Only thing I haven't changed is the N75 (trying to source one) and the car has de-cat pipe which I am going to change back for standard (de-cat pipe anyone?) when there isn't a danger of the cat being killed by the occasional back fire that I also have experienced. I have checked for split hoses and loose joints and haven't found anything. With all the above logged there is likely to be a mass of error codes. If these are cleared is it likely to make my car run better or not? Will a weeks driving be enough to log new codes that might pin-point the problem? My car is standard other than the de-cat pipe mentioned above and has the early APP engine. Any thoughts on what might be causing my problem? Thanks.
__________________
Altea XL 2.0TDI DSG - Magic Black, Aero body kit, Leather, 17" Avigor Alloys 18" SEAT Sport wheels and SEAT sport exhaust trim waiting to be fitted when gritting has stopped
#2 |
status subject to change
well it wont do it any harm to clear them.
dpeends on the exact fault codes whether it will change anything that you will notice. who did the de-cat? was any work done ecu wise to take this into account?
__________________
Smeg
#3 |
faster on 2-wheels
The de-cat was on the car when I bought it and I have since sourced a second hand cat to replace it. The de-cat looks like the original pipe work with a straight section welded in its place. I don't know about ECU work but doubt this was done.
__________________
#4 |
SCN Admin
lamda is probably dead
__________________
Saul SCN Admin email: saul@seatcupra.net url: http://www.seatcupra.net Golf Edition 30 SNWMAPS 'Ring Tour 2003 |
#5 |
__________________
Smeg
#6 |
faster on 2-wheels
I have seen that GSF do lamda probes for £20. Are these universal so will they fit the Leon cat and does anyone konw if they are any good?
__________________
#7 |
SCN Admin
you will need a vag specific one to fit your car (to suit the wiring) this is if it is your lamda mind you
what error codes are you getting? also, it wont make a difference fitting a new lamda with the decat still on
__________________
| Bookmarks |
| Tags |
| car, clearing, codes, error, make, run |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 4
| cupra_clive, pete1220v, Proc, SimmoCupra |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Had my car remapped today | CupraTDI_Rob | TDi - SEAT Diesel specific topics | 3 | 27-07-2007 16:06 |
| Does your car ever feel faster than usual? | Willie | Leon Mk1 | 7 | 14-07-2007 18:23 |
| General car cleaning and supraguard | Mike Green | Car Care & Detailing Q&A | 1 | 10-06-2007 15:15 |
| It's the little victories that make it all worthwhile.... | RobM | Leon Mk1 | 38 | 06-06-2007 14:54 |
| Driven : Vauxhall Monaro VXR vs Audi S3 | LDoR | Cars Non SEAT or VW | 24 | 15-02-2007 01:58 |
