| TDi - SEAT Diesel specific topics exclusively for SEAT diesel specific topics only. |
#1 |
Prof. Myang Li - Yum!
Oil leaking from intercooler
This morning, I noticed that there was oil that had dripped from the front offside of the car onto the drive. I am sure that this is coming out of the intercooler as when I recently had to remove the front bumper to refit some HIDs, the base of the interfooler was caked in oil and crap. There was also a lot of oil in the areas of the front bumber valance that goes beneath the IC.
A bummer but just wondering it is it normal for this much oil to go through the IC? As far as I know, charged air goes through IC with some oil but this much?? I hope I am not looking at a bigger problem other than a blown IC ![]() ![]()
__________________
NOW: Honda FR-V i-CDTi Previously: VW Bora TDi 130 Sport; SEAT Leon Cupra 230 BHP (Jabbasport re-mapped); SEAT Leon 1.6S |
#2 |
Senior Member
Its normal but I would suggest you check the seal out of the intercooler and the one on the the pipe which joins the long one in the off side wheel arch mine was doing the same it just needed a new seal which did not cost much at all.
#3 |
Senior Member
I had a passat before my leon and I used to wash the intercooler through every couple of months loads of sh**t used to come out.
#4 |
Power by Aptamil Stage 3
This is fairly typical:
http://muddyboots.fotopic.net/p15502319.html http://muddyboots.fotopic.net/p15502320.html So yes, it's normal for a small quantity of oil to accumulate in the pipes/intercooler, and to seep out around the pipe joints under pressure.
__________________
#5 | |
Quote:
There was a clip that was undone when we had a look with the bumper off. That was re-secured. Never noticed a seal though, just IC end of the pipe going into the pipe, no seal, just a metal clip holding them together. Something missing? Is it possible to have a look without taking the bumper off, just unfastening and pulling back the wheen liner??
__________________
#6 |
There should be a rubber ring that sits on the outside of the pipe insert (ie the male half
) and seals it into the housing.
__________________
#7 | |
Quote:
Only noticed some had dripped out this morning, car has been stationary on my since Thursday afternoon...
__________________
#8 |
Senior Member
You will always get some oil in the charge pressure and inevitably some will come out of the joints or in some cases just one joint.
It does come out of the intercooler joint on mine and I cant stop it but its not that much so I have left it!. |
#9 |
Editing your spelling
yes, but at the same time it shouldnt be an amount which will cause a drip....
__________________
#10 |
Agreed Stew, makes me wonder whether the O-ring is missing or damaged.
__________________
#11 |
Back to this topic again
![]() I cleaned all the exterior of the IC with Gunk about a month ago and underneath around the join. That was roughly a month ago and now there is so much oil, starting to drip once again. In a month the car covers about 1,400 miles. If it is the O Ring that is damaged / missing, is it simply pulling the IC away from pipework and replacing the O Ring? Thanks.
__________________
#12 |
yes Kam.
__________________
#13 |
Newbie
Sorry for bringing back up an old thread....but does anyone know the part number for just the o-ring??
Spoke to Seat this morning and they said it doesn't come seperately...you have to buy the whole pipe & joint?!? Which doesn't sounf right to me.... |
#14 |
¡Sexo Rápido!
I shall have a gander on ETKA tonight if no one else finds it before me.
__________________
My TDI ARL Progress Thread |
#15 | |
Insurance co's are crap.
Quote:
Of course if your car is different then the part number may be aswell.
__________________
My Sig. |
#16 | |
Senior Member
Quote:
Twatted my car last week its in 4 repair and all my history /receipts are in the boot else could of told you straight away! Glynn
__________________
Full sachs organic uprated clutch, stage 2 turbo technics hybrid turbo, stainless magnex, green cotton filter stage 2 Jabba map and decat. |
#17 | |
Newbie
Quote:
Cheers guys.... |
#18 |
Righto, ETKA lists the seals for the intercooler as "Part number unknown" but links them to the inlet and outlet pipes, so it could well be that Seat don't supply them as a single part.
However, ETKA for VW lists the same engine (ARL) for the Golf GT TDI and they list the seals seperately as "1J0 145 117 A" for both inlet and outlet on the intercooler connections. Different part numbers for seals further on down the line. Maybe nip along to a VW dealer and ask them.
__________________
My Sig. |
#19 |
Senior Member
Did I not say get them from the vw dealer!
Glynn
__________________
#20 |
Senior Member
This is in case some of you out there do not know this.
All parts for seat/vw now come direct form TPS (trade parts supply) who effectively are vw. If you can get them from a vw dealer you can get them from TPS. I believe you can buy direct form TPS without a trade account, effectively cutting out the useless Seat dealer (sorry mine really is crap). Just find the TPS outlet nearest to you. Glynn
__________________
| Bookmarks |
| Tags |
| intercooler, leaking, oil |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 12
| 150 TDI, Bassedout, Clark10, coope182, davie, diesel knievel, fat andy, gulzar, Juba, motty264, Richy!!!, typezero |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oil filter & oil renewal howto (inc pictures) | tcrichton | Ibiza Mk3 | 23 | 07-11-2008 18:26 |
| info on leon fr pd150 intercooler | leontdi130 | TDi - SEAT Diesel specific topics | 3 | 01-05-2008 11:11 |
| Oil Light | finracer | Cordoba | 4 | 09-04-2008 12:35 |
| oil light mystery | mick18274 | Leon Mk1 | 3 | 08-04-2008 11:12 |
| Decieving Oil Reading Too Much Oil Help! | Havok316 | Leon Mk1 | 8 | 09-11-2007 13:27 |
