Jabbasport
SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4 » Tracking issue with Ibiza's? (knackering tyres)
Ibiza Mk4 For the 2002 - 2008 model
Reply
Old 15-08-2007, 12:13   #1
a11y
2 wheels better...
a11y's Avatar
Shiiit!
If I had adjustable suspension I'd blame that on too much negative camber (i.e. front wheels form an "A" shape when viewed from the front) but there's no way to adjust the camber on mine (standard SEAT suspension).
Any ideas folks?
Only had the car 3 weeks and just noticed this last night (I know, should've checked better...)
Ally
a11y is offline   Reply With Quote
Old 15-08-2007, 12:15   #2
dozza.13
PS3 Tag - Dozza1979
dozza.13's Avatar
Mine did this to its first set of tires! How many miles have you done?? Have heard that its due to various different things! Do a search, you will finds lots of threads on this subject mate!
__________________
SEAT IBIZA CUPRA TDI
dozza.13 is offline   Reply With Quote
Old 15-08-2007, 12:29   #3
rashcupra
MKV .;R32 OWNER
rashcupra's Avatar
mine does the same spose best bet is to get non directional tyres and swap them around to get the most out of all your tyres but sinse i put my coilovers on and ajusted the tracking at work it doesnt wear half as bad anymore or pull left that much!
__________________
CUPRA !SOLD!
,;R32 MK5 SOLD
mv agusta f4s 750 and 225 s3 HELLO
rashcupra is offline   Reply With Quote
Old 15-08-2007, 12:31   #4
dozza.13
PS3 Tag - Dozza1979
dozza.13's Avatar
There you go, good excuse to get the suspension sorted mate!
__________________
Old 15-08-2007, 12:32   #5
muddyboots
Power by Aptamil Stage 3
muddyboots's Avatar
Very common problem....mine did it badly until I got the alignment sorted properly.
__________________
muddyboots is offline   Reply With Quote
Old 15-08-2007, 12:36   #6
dozza.13
PS3 Tag - Dozza1979
dozza.13's Avatar
I want to get mine done by a proper alignment place, where they can do camber, castor etc, etc! Nowhere near me that has the gear to do it all properly, just the usual laser alignment places!!!
__________________
Old 15-08-2007, 13:02   #7
a11y
2 wheels better...
a11y's Avatar
Cheers,
dozza - noticed your comments in another thread too, cheers.
Not sure how many miles have been done on this set of tyres (i've done about 900 miles in the past 3 weeks since collecting it though). It's currently on 25k miles on it's second set of Pirelli's according to the last owner.
I'm just debating what tyres to go for. I certainly won't be going down the coilover route again (not worth the expense for my driving) so don't think I'l be able to have much adjustment of the camber, etc. I didn't think much could be adjusted on a standard suspension set up?
Old 15-08-2007, 13:35   #8
dozza.13
PS3 Tag - Dozza1979
dozza.13's Avatar
Toyo T1R's or Proxes4's are both excellent in both the wet and the dry, and cheap if you go to the right place, Goodyear Eagle F1 GSD3's are also superb! I got mine off ere, cheapest place on tinterweb! VVVV
http://www.camskill.co.uk/products.php?plid=m4b0s13p0
__________________
Old 15-08-2007, 18:21   #9
cuprakel
cuprakel's Avatar
i ordered 4 T1R's from this place - £220ish based on advice from here! couldnt find them cheaper anywhere else, hopefully get them fitted at the weekend n give them a wee test!
__________________
Previous Car: Mk4 SEAT Ibiza Cupra 1.8T
Current Car: Mk5 VW Golf R32
cuprakel is offline   Reply With Quote
Old 15-08-2007, 18:30   #10
Orcam0ng
Orcam0ng's Avatar
Just a thought - have you got worn bushes on your front wishbone.
You may be getting that wear pattern due to excessive play during braking.
I had the same but to a lesser degree and took the opportunity to install poly bushes
Orcam0ng is offline   Reply With Quote
Old 15-08-2007, 18:36   #11
a11y
2 wheels better...
a11y's Avatar
dozza, cuprakel: that's where I'm looking, although I'm thinking about the Toyo Proxes 4's, possbily in 215/40/17 rather than the standard 205/40/17. Certainly the cheapest for Toyo's by a long way.
Orcam0ng: I'd hope not at only 25k miles, but I'll have it checked out when I'm getting the new tyres fitted and set up.
Old 15-08-2007, 18:44   #12
Tom B
Senior Member
All the cars that come into our work are like that, and unfortunately its down to the speedhumps round our way...we have them square ones with the sloped edges rather than the traditional one across the whole road type.
Nothing you can do about it, other than buy cheap tyres or avoid speedhumps.
__________________
Tom
MK5 Golf GTI
Previously had loads of Ibizas and a Cordoba SX
Tom B is offline   Reply With Quote
Old 15-08-2007, 18:47   #13
rashcupra
MKV .;R32 OWNER
rashcupra's Avatar
speed humps wont wear down tyres this much me thinks!!!! its the non ajustable camber caster settings only adjustment you can get on ibiza's are on the subframe bolts the lower arm bolts the strut to knuckle bolts and this is very limited tho
__________________
CUPRA !SOLD!
,;R32 MK5 SOLD
Old 15-08-2007, 19:11   #14
Tom B
Senior Member
Do you live in Northampton? Do you see the cars that come into my workshop? No, so you're not knocking my comments back!
Before the speedhumps were installed round here, we only had the odd car with uneven tyre wear, now we see it all the time. Two manufacturers I have worked for will refuse to pay warranty claims relating to uneven tyre wear for this very reason. We fit tyres and get them 4 wheel aligned and guess what...they're exactly the same in 12 months.
__________________
Tom
MK5 Golf GTI
Old 15-08-2007, 19:39   #15
rashcupra
MKV .;R32 OWNER
rashcupra's Avatar
so you mean the speed humps knock the wheel alignment out
no need to get all emotional and defensive im only stating my comment as we have loads of speed hump near where i work and i dont see this problem in my garage
__________________
CUPRA !SOLD!
,;R32 MK5 SOLD
Old 18-08-2007, 14:33   #16
sooty22
sooty22
sooty22's Avatar
i have this problem too... have had new tie rods, track rods wishbone bushes and tracked up three times have no idea what us causing this!
sooty22 is offline   Reply With Quote
Old 20-08-2007, 12:46   #17
Phil__Arosa
My cupra fronts inside edges were bald after 14k with about 4mm left on the outside (apparently 14k is quite good compared to others on here). Seat obviously wont do anything under warranty, but I wrote a letter to show my disappointment.
So I just got the full Hunter geometry set up by Elite in Essex. Camber was well within tolerance (slightly negative on both sides) which I chose to leave alone as I didn't want to bring it in to zero camber. And the toe was also ok. In fact the toe was slighlty out on the tyre which was in better condition, so I had the toe brought into its limit on both sides.
I don't expect to get any better wear out of the new GSD3s but hopefully rotating front to back should help a bit this time.
__________________
Ibiza Cupra Mk4
Phil__Arosa is offline   Reply With Quote
Old 20-08-2007, 13:01   #18
Guinness
On Route to Stage 3
Guinness's Avatar
14 thats bloody good I think I will be lucky to see half that out of my Toyo t1's
__________________
Modified 1.9TDI Mk4 Ibiza
Im back and with more mods planned
Guinness is offline   Reply With Quote
Old 20-08-2007, 17:55   #19
sooty22
sooty22
sooty22's Avatar
4k untill completely balled on the insied.... enough said!
Old 20-08-2007, 19:20   #20
dozza.13
PS3 Tag - Dozza1979
dozza.13's Avatar
Quote:
I rotated front to back on my last set of tyres and still only managed to get a bout 12k miles out of them, that did include a few laps around the nurburgring tho!!
__________________
Reply
Bookmarks
Tags
ibiza, issue, knackering, tracking, tyres
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 7
aanev, aterro, beezanick, Glennolls, martin150, nemo1983, rich77
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Odd tyres...what would you recommend? TeMpTeD Leon Mk1 4 17-07-2007 14:22
best tyres for LCR russman68 Leon Mk1 20 08-04-2007 19:43
Winter tyres on a LCR Willie Leon Mk1 3 31-03-2007 08:11
Tyres & Tracking Gnollins Leon Mk1 9 22-08-2006 22:06
Car pulling to the left after new tyres fitted babaa Leon Mk1 10 21-12-2005 12:44
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
