RS Tuning
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net additional Resources » Car Care and Detailing » FinerDetails - Detailing Guides & Examples
FinerDetails - Detailing Guides & Examples Iain from FinerDetails shares his vast experience and knowledge of car care. Check out some of his tips, guides and examples of his work here.
Reply
Thread Tools Rate Thread Display Modes
Old 09-11-2007, 18:48   #1
FinerDetails
Official SCN Supporter
FinerDetails's Avatar
FinerDetails has 10 points
Review: Snowfoams
I have pulled togther five different types of snowfoams. My aim being to test the different aims of these foams, and show the differences and their uses.
The Foams:
Left to right:
1- Valet Pro Orange Pre wash
2- Autosmart XL TFR
3- Espuma TFR with Rinse Aid
4- Valet Pro Snowfoam
5- Auto Rae Chem Snowfoam with Wax
To try to also compare these products as best I can I have aimed to keep as many aspects of the test as stable as possible. Therefore, all products have been mixed 5:1, all will be used through the standard foam gun on the same foam setting and the karcher pressure washer.
To test the foams I have three vehicles to present them on. The Silver cars will be used to test the TFR and pre wash foams, with the snowfoam and snowwax being tested on the FD van. My reasons for this will become very clear as the test continues.
Vehicle one: VW Sharan - last waxed eight months ago, and has Collinite 845IW on it. Full pic and closer pic (drivers door panel) to show current level of water beading:
Vehicle Two: Subaru Forster - last waxed eight nonths ago, and has Collinite 915 on it. Full pic and closer pic (bonnet panel) to show current level of water beading:
Vehicle Three: FD van - last waxed about three weeks ago and has about three wax layers on it - Divine, XMT180, Nattys Red.
__________________
FinerDetails Car Detailing for Manchester and the North West
FinerDetails is offline   Reply With Quote
Old 09-11-2007, 18:48   #2
FinerDetails
TEST ONE:
Valet Pro Orange pre wash and VW Sharan.
Being applied:
Once whole car covered:
after five mins:
water beading after rinse off:
__________________
Old 09-11-2007, 18:49   #3
FinerDetails
Test Two:
Autosmart XL and Subaru:
Being applied:
After five mins:
Water beading after rinse off:
__________________
Old 09-11-2007, 18:49   #4
FinerDetails
Test Three:
Espuma TFR with Rinse Aid - VW and Subaru:
Being applied:
Once covered:
After five mins:
After rinse off:
VW and Subaru:
and left to dry, this is howe they looked around 20 mins later:
__________________
Old 09-11-2007, 18:49   #5
FinerDetails
Test Four:
Valet Pro Snowfoam and FD Van:
Being applied:
once whole van done:
after five mins:
Beading after rinse off:
__________________
Old 09-11-2007, 18:50   #6
FinerDetails
Test Five:
Auto Rae Chem Snowfoam with Wax, and FD van
Being applied:
Once whole van done:
after five mins:
Once rinsed off:
Water beading after:
__________________
Old 09-11-2007, 18:50   #7
FinerDetails
Conclusion - comments, observations and thoughts:
The thickest foam of the three TFR/pre washes. Had the longest dwell time, but also required the most water to rinse off due to the thicker foam. Smell was ok too.
2- Autosmart XL TFR
A fairly weak foam, and didn't stay for very long, and must not be allowed to dry on the car either. Rinsed off easier tho.
Appears to sit bewteen the XL and Ornage pre-wash for foam thickness and also staying power. The rinse aid showed through in the rinsing off and also the amount of surface water left behind.
By far the thickest foam of the test, lasted the longest and also created the biggest grin for fun factor.
Not as thick as the straight snowfoam, but far exceeded the standard faom with regards to water beading afterwards.
Which foam for which task?
If you want a good pre-wash to sit and dwell for five mins - Valet Pro orange!
If you want a pre-wash for easy rinse off to save water and not loose performance - The Espuma with Rinse Aid.
If you want a good thick foam to use for washing the car with a mitt - Valet Pro Snowfoam
If you want a foam to leave added protection on the paintwork - Auto Rae Chem Snowfoam with Wax.
Most manufactureres produce each of these types of products, eg a foam with wax retc, so brands isn't an issue in my mind. What I have tried to do is show which foam can be used for which task.
Last comment I would say, the TFR were not terminal on the wax layer, not completely stripping it away, but did greatly reduce any wax protection which was remaining.
I hope this has been of use, its taken me an age to compile and I had to the re-wax the VW and Subaru as a result!
Thanks for reading
Iain
__________________
Old 10-11-2007, 08:09   #8
Funkyfin2000
Black Leon Cupra R 280bhp
Funkyfin2000's Avatar
Funkyfin2000 has 10 points
thanks for that Iain!
Great reviews and very worthwhile excersise!
all credit to ya!
__________________
Black 2005 Leon Cupra R
APR Stg 2 Map - 280bhp plus tons more!
Funkyfin2000 is offline   Reply With Quote
Old 17-04-2008, 15:36   #9
Adam R
Diesel ISN'T a Dirty word
Adam R's Avatar
Adam R has 20 points
nice write up Ian.
i have a karcher foam lance and some Supa snow foam that is use. i know you have not included this prduct within your review, but i would like to ask your opinion on it.
Basically i think its a load of poo, i use pleantly of the stuff, it foams nice and thick (i leave it for 5 - 10 min) then rinse off with the pressure washer, but to me it does not really remove any of the surface dirt.
i hear people rant and rave about how good this stuff is but i just dont see the results myself.
is there something i am doing wrong or am expecting far too much from a cleaning product.
Adam R is offline   Reply With Quote
Old 17-04-2008, 16:17   #10
FinerDetails
what wax is on the car? and when was it last applied. For actual cleaning ability SSF is average compared to what is now available.
__________________
Old 18-04-2008, 10:17   #11
Adam R
Adam R's Avatar
i use auto glym UGP (ultra gloss protection (their sealant))
then use a liquid wax from megs. u usually apply every 1-2 months. depending on weather etc
Old 26-01-2010, 20:25   #12
gogs
gogs has 10 points
Where did you get your foam connection, I've tried two now designed for Karcher, first was a pain to fit and leaked like hell, second is a pain to fit....infact it wont even go on!
gogs is offline   Reply With Quote
Old 03-05-2012, 20:54   #13
bargibin
bargibin has 10 points
Good wright up I enjoyed reading that! I personally use the Valet Pro Snowfoam and it does what I want it to.
bargibin is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 575
1.9...stefan, 1L19, 285cupra-matty, 4937Liam, 53 Leon SX, 5509433, abdus, Ac2709, ackers1987, Acksaw, Adam R, adam taylor, Adam's Cupra, Adamm, ADAM_84, ade1lung, adm013, Adman77, Adz87, Ahsan, Aiden, AJR, Alan Partridge, alesi27, Alex Cupra, alextdi, alnsaz, alwaysinfront, alx_chung, AMDetails, Andy McCombe, ANDYH1966, Andywest2k1, antnee, APDTDI, ashley600, audiintegra, AviTurbo, b1nuzz, b9rgo1234, bainsycupra, bargibin, basil, beezanick, ben-ducky, Ben-ibizaFR, Benji, BenW, Berg, bertrum, bigdog3, bigtb, binky, bla1n3, Bluto&Purdey, bobphatboyphat, boki, Bolland, bonsaiman, BoomhaueR, Boostboy, boroboy19, bradders07ibiza, brad_barker12, Breezapom, briggy, Brookes, brownie, Bruce GT3, Buglass21, BumbleJC, burnsey, buzbi, C1TPT, c4tman, cable, Cainey, Cal91, Callumc, cappitman, carew, carlsoundwave, Cbreslin91, CDJONES3495, cdmalpass, CGD217, ch1lly, char_baby, cheshmatt, Chester, Chippo, CHRIIS, chris c, chris2r, chrisbond69, Chris_a_73, Cjam, CluneZ, CoalBurner, conkerman, Copey, cossydave, Couga85, Covps2blue, Crafoo, craig26283, Craigbarnley, Craigus, crezz, crftom, crigisback, Crispy_fr, Crono, CrossyR, cudsy1, CUPR, Cupra Grant, Cupra R, Cupra Ross, Cupra-Matt, cuprabaz, CUPRACAR, cuprachrissy, CupraCol, CupraDaveG, cupramillo, CupraR-S6, CupraString, cupratdi-matt, CupraWill13, cupra_r_04, DA-BADMAN, DaBigDogg, Damoegan, Dan 6N, dan boy, danfr, dangerousdriver, danny m, DannyC87, Dannym, dannypea, DaNnY_LaD, danston, Dante L2A2, darkhorse, darrenc, DarylDunkley, Datapro0, dav3, davea, daveh1, DaveP, dave_6, Dawesy90, dazjb69, dazjstuart, dazvessey, Dazyid71, Deanf, Dean_dubber, Deejay, dErZ, dezpair, dh00001, dicky FR, ding-dong, Discostew, Disco_Biscuit, Dmoe, Docaroo, DonniD1991, Dopsonj, dru, drue1, dubz_wm, duckviglen, Ed87, edy_jz, ell0070, EMMH, English, erichuyn, ET, ET CUPRA, Exe_LeonCR, f15h, F2 Ed, fackers, Fahid82, FASTER, Fien, fishman, flares, Fox god, foxes, fr-tdi, frfred2009, fuzzy232, G2HSE, g60stu, g8rvn, gard_ian8, Garetht, gav_FR, gazR, gcott, genelson, George 3G, gezmeister, gillian & james, GlanzaV, Glennolls, GodsUnicorn, gogs, golf on 20s, green87, Greene36, greenhearts54, grinnell27, GTi T, gti_jones, Guffers, h7 cya, haich, harty190486, hazman, Hilla LCR, Hobbiniho, Holdup, holty, Hugo Nebula, Hugos, Hunter, Ibiza 09, ibiza staff, Ibiza125, ibiza20vt, ikhlaq206, InfernalBadger, ings22, inkey, Irie, itfben, J.C, J44APX, J@mes, jaba101, Jace, jack-cuprar, jack_1.8t, Jake9119, james walker, james.milroy, James23Parkin, JamesL, JamieG, jamski, jasonwinslow, JaWalks, jay26, jaykicksass, jaymd, Jayo, JBY001, jcorky, jedijones666, Jedimaster65, Jelly Baby, jeyre, Jez_B, Jfox, jh1, Jhouse_101, Jimmeh, jimmibiza, JimmyL, JK_cupra, Jm05cop, JODmeister, joe-20vt-toledo, JoeF, Joens, John-Cupra_TDI, johnbev, johnboii225, johno1404, johnson88, jonjay, JonnyTeabag, jon_boi_91, Jordan20vt, Jordanwaterhous, joshbro90, JP6, JP_LCR, jrsmooth, JU5 2 SLY, justjoe, jwilkinson, J_King, K18NEO, kassim, Katangaleon, kazzy, kbrad44, keaney, Keir, kenny-cupra, Kevgrady, kevinking2020, kidinspace, Klone, knight, knight85, kw1984, Lancashire_guy, langy, Lant, LClittlebob52, LCR 225, LCRglen, Lee Edgecombe, Lee182, leesmith, LeoCupra, leon_81, leon_lib, LGB, likeanoven, living2xs, lm_gauci, lock1981, Lodey23, lugsy, lukecupra2001, luke_h, luna fr, M30 SCK, M600RKC, macca324, makaTDI, ManOnTheMoor, Marc J A, marco cupra, mardon, markirel, markojay, markscupra, MasterKey, Mat, mathewh09, matt2e1cpc, Matthew FR, matthewbentham, mattyholmz89, Mcleon, mdking, mekonj, metman9185, metroarmadillo, mhill, Michael Andaz, mick-fr, Mike R, mike.1981, mike000, mikem1, mimilos, minimat, mini_hammy, mini_racer, minority, Mk2Ibiza, Mobo, Moffat, moshii, mouse1989, Mr Bigglesworth, MrBen2k7, MrNorma, mugge, n11tht, N3 CPRA, NAB_ARCK_86, nads, Neo, neon, Neo_VR, Nev_LCR, nickcopa, NickLCR, Nick_A, nik555, nikstar, NinjaPirateUK, NJG, noelbmx1, norgax, NWhiteley, obou, oboyle20, oldman, Optimus Prime, p-hoey, P13ULC, p77_macca, PARKE9037, parksy, pars911, PAS, paul-murphys, pault56, paul_zx6r, Phat Busted, Phil__Arosa, PID, Pingu101, Pinocchio, PJ_leonCupra, PlatinumR, pmerryman, pompeycupra, Poochy, Popadopalous, psycho6285, R0b3r, R69, R88CKS, racingsquirrel, RajClat, RAMBO MKII LC, ratgreen, Ravey_Cupra, RDS, Rich110, rich2310, Richiekuk, rmn640, rob - 73, ROB IS THE STIG, robepton, robv160, rpk, RS Dave, rudgey, S.E.C.T., s30tt, sadape, SalSheikh, scarface, scotbren, scotty026, Scotty229, Se130Leon, Sean01, SeanCorky, seanD, Seat Gooner, Seat racer, sebby225R, secret.squirrel, SHADY-NINJA, shakefraf, Shani, sharples, shaunymac, simonc1979, SimonFRTDI, SimonM, simorris105, singh123, Sinkezg, SiPrince, si_devil1, sjolliff, Sjw_LCR, skeat12, slickbone, SlimLCR, Sloth, smitty13, Snowsurfer, Soapie, soche, sovk1n6, Spanish Spaniel, Sparkie, spidara, Spirit Furtive, splinter26, spyke85, SSimpson3, staffordian, steady_eddy, STEALTH 225R, steffers, stellaf, steslatt, steve p, Stiglet, stoke1863, stornolad, stpete, Streetie, strugers1, such, sunny2k2000, swf7y, tackits, TatoTDI, tb130, TDI PEP, tdi_chris1, theArchitect, thebrasso, Theowls88, thePHILosipher, therench, The_Viper, Thyper, tinky, tjjammo, tjking, Tobs, TomArnold, TomJackUK, tommy12, tommyp, tomxt99, tom_tom_ass, Tonybeau, top0cat, treborleon, Trotski, truss, TSVB, TubbyTwo, Tuck3r, UFO Yellow, unkle funkle, Viking, vrs130, vulcan303, waitsey, Warning, Wash It!, wazb, wazzzer, wbph, weestu, welchy, Wellsy, who me, WHOZBOSS, wigz45, wild willy, will-225, willc, willows86, Willsy33, Witalik, Xanthianx, xreyuk, xXxstylexXx, yakirmac, zach225, zan, zeroSignal, zilcho, [lloydy], _chris_
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Review of My Stage 2 TDI Remap turkish TDi - SEAT Diesel specific topics 3 22-11-2007 15:30
Review of my Leon FR TDI Monumental Leon Mk2 7 07-11-2007 09:13
SEAT Altea Freetrack 4 Autoexpress review rhumber Altea - includes XL and Freetrack 2 22-10-2007 21:24
top gear review luke c Ibiza Mk4 32 24-07-2007 19:00
The Times Review mjr600 Altea - includes XL and Freetrack 6 15-06-2007 11:37
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
