Votex
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Arosa
Arosa Use this forum for Arosa specific topics.
Reply
Thread Tools Rate Thread Display Modes
Old 09-01-2008, 09:48   #1
Boo
The original wee beastie
Boo's Avatar
Boo has 10 points
Unhappy Speedo dash
Just had a call from my garage to say that they have fitted a new speedo sensor to my car and that it has not fixed my speedo problem. They said that I will definately need a new Dash display unit and are 100% certain that this will fix the problem. I can understand where they are coming from as my car overheated a few months back and I didnt get any warning lights or anything and now the speedo isnt working.
Trouble is a new one is something like £180, the one seat have in stock has been on back order for 8 weeks and I will then have to pay for the garage to fit it and code it. I could almost cry !!
How can something like this break ? I havent hit anything, I havent hit the dash - I rarely headbutt it these days as I have found the joy of primative measures such as hand signals and swearing ! My friend (who previously owned the car) and I have never removed the dash console ? Im completely flumoxed !!
Boo is offline   Reply With Quote
Old 09-01-2008, 10:04   #2
lunalupi
...is not a bloke!
lunalupi's Avatar
lunalupi has 10 points
Oh poo - why couldn't it have gone at the beginning of last year, I'd have grabbed the dash out of my donor!
I guess its like anything, sometimes they wear out? But ask them if they have had VAG-com on it - theres a test it runs which lights up all your warning lights and spins all the dials. If the dash was broken I assume none of that would happen...
__________________
55.8bhp @ 5068 rpm and 62lb ft @ 3605 rpm
lunalupi is offline   Reply With Quote
Old 09-01-2008, 11:58   #3
1litre wonder
(s)Low rider
1litre wonder's Avatar
1litre wonder has 10 points
TGG if you find out if all the clocks are the same i can get you a set of clocks if you tell me how to get the dash out . theres a red Mk1 about 3miles from my house breaking , its got no engine but i could get you the clocks out of it
__________________
Mk2 Arosa 1.0S 50bhp gone , 54plate Mk4 Ibiza Cupra 1.8t 20v 180bhp replacement ( now gone ) mk4 Golf GTi TDi 150bhp ( now gone ) replaced by B6 Audi A4 Avant Quattro 130bhp, mapped to 180bhp 297ftlb torque ( now gone), 53 Plate Leon Cupra TDi 150bhp
1litre wonder is offline   Reply With Quote
Old 09-01-2008, 12:18   #4
Boo
Boo's Avatar
Boo has 10 points
I will go and get the numbers out of the dash shortly. Motors in motion have loads and they would charge me £75 and £5 shipping. The garage say they can try it but, they arent sure if it will work - they arent exactly brimming with hope. Bit of a pricey risk when I still have to pay £45 for them to fit it and re-programme it too. MOT's around here are approx £55 - thats due in February and then my car tax is due at the end of this month. Im supposed to be saving money for my trip to Venice.
Old 09-01-2008, 14:29   #5
Boo
Boo's Avatar
Boo has 10 points
Ha ha ha !!! Much easier said than done. Seems a certain steering wheel is in the way - blasted thing. I mean, who would've thought I might need one of those ?? Got the 2 star shaped screws out of the top and there are a further 2 either side of the steering wheel just inside the housing. Rubbish !!!
Old 09-01-2008, 14:46   #6
1litre wonder
(s)Low rider
even if you use ETKA to get the part numbers and compair it to the part number for hte clocks for the rest of the mk1 range as im sure this one thats breaking was a 1litre as it had 239 brakes on it
__________________
Old 09-01-2008, 15:23   #7
Boo
Boo's Avatar
Boo has 10 points
Mine is a 1.4 Auto - Im convinced the worlds hates me this month !!! I think squirrels have the right idea in hibernating until it all blows over - Im going to hibernate.
Old 09-01-2008, 15:58   #8
1litre wonder
(s)Low rider
yeah its ab auto but it might still use the same clocks
__________________
Old 09-01-2008, 16:37   #9
Boo
Boo's Avatar
Boo has 10 points
Im just going to take it to a different garage to get an MOT done and go from there. Suprisingly enough the speedo isnt something they apparently check on an MOT - what do you pay £50 for ?? !!! you learn something new everyday.
Old 09-01-2008, 17:11   #10
F2 Stu
I. Am. Legend.
F2 Stu's Avatar
F2 Stu has 10 points
Quote:
Dont you do that anyway?
__________________
2004 VW Passat TDi PD130 Highline Estate
F2 Stu is offline   Reply With Quote
Old 09-01-2008, 17:35   #11
Boo
Boo's Avatar
Boo has 10 points
Quote:
Ha ha ha cheeky cow !!
Old 10-01-2008, 22:16   #12
Boo
Boo's Avatar
Boo has 10 points
Someone is breaking one in Manchester they have the cluster for £40 and £10 postage and packing, which seems more than reasonable Should be a straight forward swap and re-programme shouldnt it ?
Old 10-01-2008, 23:57   #13
1litre wonder
(s)Low rider
you could swap it yourself as long as you dont mind being towed into the dealers to get your central locking reprogrammed also get them to clock them so that it shows the cars proper milage
__________________
Old 11-01-2008, 18:34   #14
Boo
Boo's Avatar
Boo has 10 points
Im confused Phoned around quite a few garages today to ask them about changing the cluster over. Some mixed reactions and quite a few groans ! I then phoned Seat who said that the clusters are easy to change over but, the clocks cannot be adjusted or changed. So I assume if I buy a used cluster (how wrong does that sound) I will end up with the previous cars mileage which is as we all know horribly illegal. Looks like I will end up having to fork out for a new unit
Old 11-01-2008, 21:39   #15
Jochen
Banned
Jochen has 10 points
I am sure that on the mk1 arosa, the immobiliser has a seperate e.c.u, it is not built into the dash like the later ones, so you should just be able to put another cluster straight in and off you go.
Have the garage checked all the wiring between the sensor and dash? it is very rare the earlier dash's give problems.
Jochen.
Jochen is offline   Reply With Quote
Old 11-01-2008, 23:49   #16
1litre wonder
(s)Low rider
all digital dashes can be clocked , its just that SEAT wont do it , its illegal to clock a car and not say but if your clocking a car due to a clock change and your not changing the cars actual milage then theres nothing wrong with it and its legal
its only if you clock a cars dials and not tell the next buyer then its illegal
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 10
-LeonFR-, Big Ra, castle cars, CatB1, cmontgomery, cupra786, golfboz, lloydy007, Mr Az, ralph
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
polo gti dash! deanrankin85 Ibiza Mk3 19 26-09-2010 10:09
Speedo and Fuel Gauge modified_nutter Ibiza Mk3 2 21-11-2008 11:27
aura dash display stolen Leon Mk1 8 06-01-2008 10:04
Oh no not HIDs again! Can you help? Dash is packed up! mksteve1 Ibiza Mk2 6 23-11-2007 12:32
Dash boards! GeorgeF Ibiza Mk3 11 29-10-2007 18:24
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
