Over temp warning light flashing when engine is cold
Craig j
Hi there my girlfriend was leaving work 2 days ago, she was driving for about a minute then the red warning light on the temp gauge started to flash and beep 3 times even though the gauge was still sitting at the bottom (cold), she then pulled over and turned the ignition off then back on and it went out. Any ideas could it be a sticky stat or sommit?:confused:
Craig j
Did a search doesnt come up with anything to do with my issue, the car isnt overheating its just the light randomly comes on as soon as the engine has started its only done it twice.
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
Could be the coolant temp sensor
It can read that the engine is too hot as it is missreading :confused:
Sarah
andycupra
status subject to change
this it the coolant level sensor in the expansion tank.
it beeps 3 times right? (sorry you said that)
i bet if you turn the ignition off/on after a few miles its fine.
only on cold days?
few options for you in order id try them:
1 if the coolant level is towards the bottom of the correct range, top it up a bit (not a fix as such but can reduce incidence of beeping)
2 scrape the sensor prongs in the coolant, (they often get a build up of scaling)
3 replace the expansion tank. (as sensor is built in). However there has not been any update to the design and so this doesnt guarantee it wont happend again in 12/24 months time.
the light is on the temperature gauge but is not refering to the temperature but the coolant level if its beeping 3 times.
Gnollins
Bosh!
Jul 24, 2006
406
Yarnton, Oxfordshire
This is a common problem mate - it's the sensor in the coolant tank.
Fix: Take the lid off the coolant tank when COLD and use a flat-blade screw driver to scrape the two prongs that connect to the sensor. They accumulate some gunk that makes them mis-read and cause the warning light to come on. I had a this a few weeks ago and it's now fixed.
Or you could get the coolant tank replaced at a dealer, it's a fairly cheap fix.
Craig j
Yep the light comes and it beeps 3 times and funny enough it is on cold nights when she leaves work and when you turn the ignition off and back on again it resets. The temp gauge when warm never goes above 90 (the middle). It only ever does it to her lol
Craig j
Il give that a shot tonight rather try cleaning it first than getting a new tank, thanks for the advice mate.
Regrds
andycupra
she must be cold blooded and agrivates the issue ;)
the coolant level is often slightly lower when very cold and seems to effect the sensor also.
If its under warranty it can be replaced, but it will most likely happen again.
My advice would be clean prongs and top up coolant. Only replace tank/sensor if its keep happening after this.
Craig j
Yeah your prob right :whistle: lol
I think il just go for cleaning it, Atleast i know now whats causing it. Thanks very much for the advice.
Craig j
Oh well atlest when a search is carried out from now on a prop thread description name will come up. lol
Teasy
451
Middlesbrough
I rang local steeler & booked it in as its still under warranty & she told me that this isnt covered as its mechanical!!!!
[:@] I cant wait to see her [:@]
Mar 5, 2007
588
Tell her to suck your DEE.
Then tell her she can ring half the people on this forum and ask them if it's not a problem on the leons.
Stupid bint.
