Votex
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk3
Ibiza Mk3 For 2000-2002 Specific Information.
Reply
Thread Tools Rate Thread Display Modes
Old 11-02-2008, 00:03   #1
Importcupra
The Best Rev Hard
Importcupra's Avatar
Importcupra has 10 points
Ths intercooler fitted and coolant temp sensor
Hello guys fitted my intercooler yestaday, and i must say its made a big improvent! car pulls alot harder and theres no heat soak atal! also i have a dead coolant temp sensor would this cause the car to over fuel and stop it from starting from time to time and would this restrict performance? ( it was doing this before the intercooler was fitted)
Importcupra is offline   Reply With Quote
Old 11-02-2008, 00:36   #2
jonesya3
jonesya3's Avatar
jonesya3 has 10 points
looks good nice job
__________________
Fitted : Blueflame/Jetex Turbo Back, Revo Stage 2, Forge FMIC, TIP + 007 DV, Seat Sport Strut Brace, OZ Superleggeras, LCR Splitter, 6k HID'S, Brembo's, Drilled Brembo Disc's + DS2500 Pads, Eibach F + R Hubcentric Spacers, N249 Bypass, KW Coilovers, TT Short Shifter, Toyo T1R's,ECS N75, Jetex Filter, Spec 3 clutch and flywheel
jonesya3 is offline   Reply With Quote
Old 11-02-2008, 00:39   #3
Importcupra
The Best Rev Hard
Quote:
Originally Posted by jonesya3 View Post
looks good nice job
cheers dude!!
Old 11-02-2008, 00:50   #4
andygolf
Senior Member
andygolf's Avatar
andygolf has 10 points
yea looking good easy enough to fit.
__________________
Ko4-001 Ibiza
BMC CDA,MILTEK DOWNPIE STAGE 2 REVO 4BFPR FORGE FMIC ATP MANIFOLD FORGE TIP
POWER ???? WAS 210BHP 250FT/LBS
1/4MILE WAS 14.74@95.6
andygolf is offline   Reply With Quote
Old 11-02-2008, 01:02   #5
mr_D
Senior Member
mr_D's Avatar
mr_D has 10 points
really nice. i like it
__________________
[center]
mr_D@tcc-uk.net ----- ryan@streetlegalevents.com
image removed due to trade links
mr_D is offline   Reply With Quote
Old 11-02-2008, 07:59   #6
Importcupra
The Best Rev Hard
yh it was easy to fit ( even easyer when u have a ramp
Old 11-02-2008, 08:31   #7
C1TPT
C1TPT's Avatar
C1TPT has 10 points
well done Gav! at least you'll be able to touch your inlet mani and charge pipe now
__________________
SEAT Ibiza Cupra - Black, tinted windows, supersprint cat back exhaust, custom induction kit, THS FMIC, Forge split-R, seat momo front strut brace, Spax RSX coilovers, 6000k HID's, LCR Front splitter, nomad pillar and boost gauge.
C1TPT is offline   Reply With Quote
Old 11-02-2008, 08:49   #8
Importcupra
The Best Rev Hard
Quote:
haha, fink we need to go for a lil play again ( on a private road ) noooooo more heatsoak for me!! any body got any idears bout the senser?????
Old 11-02-2008, 09:08   #9
C1TPT
C1TPT's Avatar
C1TPT has 10 points
well i scaned mine a while ago and got a coolant temp sensor fault, i cleared it and it came back! so i fitted a new one but i had no visable problems. it ran fine and started every time..
__________________
Old 11-02-2008, 09:24   #10
Importcupra
The Best Rev Hard
well uv seen when mine dont start and i have to open my expansion tank botle to get it going and when it does that it over fuels like a **** sooo im hoping it is just that
Old 11-02-2008, 19:23   #11
Importcupra
The Best Rev Hard
can u buy the coolant seser on its own or do u have to buy the bottle aswell??
Old 11-02-2008, 19:35   #12
redcupraboy
Senior Member
redcupraboy's Avatar
redcupraboy has 10 points
your intercooler looks great, nice job! seriously like the aston martins in your pics in the back ground, with your car on the ramp.
redcupraboy is offline   Reply With Quote
Old 11-02-2008, 19:40   #13
jNx
jNx's Avatar
jNx has 10 points
Loving the garage
THS looks good!!
__________________
J8 NXE
"Surrey's Largest Online Modified Car Community"
jNx is offline   Reply With Quote
Old 11-02-2008, 20:31   #14
gregorcupra
gregorcupra's Avatar
gregorcupra has 10 points
How straightforward are these to fit ?
How much did it cost if you don't mind me asking ?
gregorcupra is offline   Reply With Quote
Old 11-02-2008, 20:35   #15
Importcupra
The Best Rev Hard
thanks for the coments. lol and as for the astons i nthe back ground just another days work! they are relli simple to fit and for the cost of 210 the differance is unreal!!! im running revo stage 2 btw!
Old 11-02-2008, 20:36   #16
gregorcupra
Does the slam panel etc not need cuts made in it ? Where did you get it all from ?
Old 11-02-2008, 20:42   #17
Importcupra
The Best Rev Hard
yh u need to make cuts to the crash bar and the bumber but apart from that its straight forward! i got the intercooler from http://www.thsperformance.co.uk/ and the pipes from sfs hoses in luton. i called them up and told them wot intercooler i had and hew new wot hoses to supply!!
Old 11-02-2008, 20:42   #18
Matt S!
ovni ibiza cupra 1.8T
Matt S!'s Avatar
Matt S! has 10 points
Did you need to trim the bumper??
__________________
Evo 8 MR FQ320 in gunmetal grey
Matt S! is offline   Reply With Quote
Old 11-02-2008, 20:49   #19
Importcupra
The Best Rev Hard
yh i did, i cut away qite a bit so i could mount the cooler as far forward as possible to keep it away form the rad. i will take sum pictures of the bumper for u guys 2moz so u can see
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 10
Big_Lad, eleriroberts, gege971, Importcupra, jamieread, jim s3, krisbutler02, miller, SeanyK, thomasa
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ECU warning light LCR 2003 Kelman70 Leon Mk1 26 21-02-2008 20:24
coolant change on mk4 with Climate Ant FR Ibiza Mk4 6 10-05-2007 13:09
Anyone know where the Temp Sensor is on a TDI 110 Engine ? AndyC567 TDi - SEAT Diesel specific topics 6 28-01-2007 10:57
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
