| Problem Issues Q&A A place for common issues affecting any specific SEAT issue, or tuning problems. If you have problems and are looking for answers this maybe a place to start. |
Thread Tools | Rate Thread | Display Modes |
#1 |
Using resistors to replace electrical components.
Electrics have never been my strong point. I had to do electrical engineering as part of my Uni course but I haven't retained much (and it was a long time ago)!
This is mainly a 1.8T engine question.... Without getting into a discussion on why components can be removed, it's possible to remove N112, N249, Evap and Secondary Air from the engine. The ECU will (sometimes) throw up fault codes unless resistors are fitted across the remaining electrical connector. Is there a simple way of calculating what size resistor is required? Can someone explain? I've measured the resistance of the removed components. N112 28 ohms N249 22 ohms Evap canister 24 ohms Secondary Air Motor 0.8 ohms. Are there other factors that need to be taken into account?
__________________
Dave ...................... dpj@seatcupra.net ...............................................................................Alhambra Stylance 140Tdi...KiwiCupra 8v...387.7bhp Leon Cupra GT
#2 |
3071
Bump for info.
__________________
#3 |
Grumpier by the day!
The only problem i could see Dave is if the resistance is variable. Can you not measure the resistance they provide when they're working as surely that's the action you want to mimic? I would assume the ECU is smart enough to detect their presence and then detect whether they're actually doing anything?
If they're similar to EGR operation, could a decent tuner not simply map them out of operation? |
#4 |
Sorry for being thick
..... How does resistance change?(ie SAI is a motor - hence low resistance - apply a current to it and it rotates) It's a little bit difficult to catch N249 or N112 in the act of switching - otherwise I ddon't know what voltage to apply to them.
__________________
#5 |
I was thinking out loud - i was guessing that the ECU detects their presence by resistance .... what i don't know is how it measures / records their operation ... maybe i was being thick and they record that by voltage and not resistance which doesn't change.
![]() In which case all you have to do is fool the ECU into thinking they're not there, what i don't know is whether it would check or look for them working after that. You might not get an error after starting but you may get one after something fails to do something the ECU or another component expected it to do? |
#6 |
I know that I can get a Secondary air code through the Lambda detecting unexpected a/f. We can't easily avoid this sort of thing - and although it would be nice to get it mapped out, we don't want to ditch Revo etc just to solve this.
What I really want to understand is how you establish what the correct size of resistor is to replace the component. Is it the same as the component's resistance?
__________________
#7 |
/me goes to search google for answers ... i'll pop back if i find something
edit: Had a scan around and whilst there is lots of info on specfic ECU mods, there appears to be nothing much on replacing general electric components with resistors that match the original resistance. Last edited by UncleFester; 14-02-2008 at 14:00. |
#8 |
The ECU is looking for a change in voltage? Therefore as the components resistance alters through change, the voltage is also varying. What you need to know is what the resistance is in the components "normal" state, and apply that sized resistor. It could be that the resistance's youve stated could be in fail mode ie. the ecu thinks that component has failed.
HTH ![]() What voltage goes to these components as you also need to know the current being handled. This is calculated via the ohms law equation which states Voltage = Current * Resistance Or in your case Current = Voltage/Resistance Last edited by Neg.; 14-02-2008 at 15:11. Reason: addional info |
#9 |
Cheers, Neg.
![]() The thing is, these things aren't sensors. As far as I'm aware, N112, N249 and Evap Canister top are all electrically controlled valves (air switches) and the Sec air is an electic motor. So surely if the substitute resistors have the same resistance as the components, the ECU will think it IS the component that's operating...... Feel free to say I'm talking sh1t....
__________________
#10 |
Jack-RIP my little Friend
in the case of the solenoids they are inductive-resistive devices... so adding a resistor is not an exact swap...
the resistance will change with frequency.. (inductance etc) Simply adding a resistive load to mimic a coil is not the same, particularly when its a solenoid which is having a frequency applied to it to switch it.. (not on-off like a switch, but switching.... bzzzzzzzz) A resistor is a fixed load a solenoid coil is not.
__________________
![]() BADGER 5 LTD: PERFORMANCE TUNING RACE PROVEN PRODUCTS & HONEST ADVICE: Contact:07976 800775, 01453 822880 Bespoke Big Turbo conversions,AEM WMI,Forge,Ferodo,AP Racing Brakes,Custom Mapping,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compomotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more... http://www.badger-5.com email me at:bill@badger5.co.uk |
#11 | |
Quote:
Cheers Bill!
__________________
#12 |
Senior Member
By the sounds of it the verdic is dont touch it in the first place!! Dammit lol
#13 |
HUD'ER CHAPPIN!!!!!
A bit off topic here, sorry lads.
Bill or anyone else that has removed their EVAP, have any of you had over fueling issues?
__________________
BlackwidowTurbos DMC Performance |
#14 | |
Quote:
__________________
#15 |
HUD'ER CHAPPIN!!!!!
Bigboost ask the question on my emissions thread, and i wasn't sure so i ask on this thread. Here's my thread http://www.seatcupra.net/forums/show...2&postcount=34
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 12
| -pseudonymous-, dai cupra, davidcupra, daza b cupra, L.R.C., mat_106, MichaelMr, mini_hammy, phatchoonz1, RabReith89, Tom's Cupra |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3-way components | Ibiza_46 | Modifications and Tuning | 4 | 16-03-2008 18:49 |
| Strengthening engine/ transmission components | watkins4378 | TDi Tuning | 1 | 05-02-2008 10:55 |
| Aero wipers - how do you replace the blades? | shadw_uk | Ibiza Mk4 | 14 | 08-01-2008 00:22 |
| components into mk3 ibiza cupra doors | stevoibizacupra | Modifications and Tuning | 6 | 14-11-2007 17:33 |
| components | beezertart | Ibiza Mk2 | 36 | 31-10-2007 11:41 |
