How to change your headlamps to xenon
SEATgod
Hello,
It is a legality to have self levelling and headlight washers on Xenon's....
If you fit self levelling (front and rear axle sensors) you will need an upgraded On Board Voltage control unit (PR code for Xenons) and you will need a headlight control module!
You will also need to upgrade the wiring between on board voltage and the Xenons as the igniters carry a greater amp load.....fire anyone??...oh dont forget to install the correct rating fuse either!
Plus the ball ache of fitting headlight washers!
Xenons aren't just a bolt on part!
Regards,
leviathan18
452
Venezuela, Caracas
Hello,
Regards,
well this is far more "legal" than just get a xenon kit because this wont blind anyone.
you dont need the voltage control unit its the same if the car has xenon or halogen
you need the headlight control unit with the axle sensors
again you are wrong with the cables they are the same in the cars with halogen and xenon, besides the tension load of the amps in the xenon last micro seconds and the car then consume 35w, with halogen you are consuming 55w at all time which the cable needs to be more robust in either case they use the same cable for both applications
and the headlight washer is the easiest of the mods.
if you want xenon in your car the best you can do is this, buy the oem headlamps with projectors and the headlight washers.
Leon_MHX
Stealth TDi
Nov 6, 2008
163
Cheshire
Leviathan, add part numbers for uk market to your description 1P2 941 039 and 1P2 941 040.
For anyone who is interested i got these for £166 a light then bulbs/ballast £50 a pair
Mac10menace
hi im new to seat.net and ive ben offered some original xenon headlight units complete with balasts , bulbs etc , would it be possible to plug and play ? or is there mods which i need to carry out such as wiring to the ecu ? i had an 2004 audi a3 and they were straight forward plug in and working but then i bought and a4 and managed to get some original xenon headlights and the looms were diferent so i had to buy connecting looms, when installed they came on but after a couple of seconds flashed and went off ??? any help guys would be appreciated before i buy these headlamps . i am not bothered about washers etc, just want them to light up. thanks guys
Leon_MHX
Stealth TDi
Nov 6, 2008
163
Cheshire
Get them coded in, via VAG-COM!
Maximus2000uk
Seeing as I cannot find a clear answer, if I retro-fit xenons onto my FR, WITHOUT fitting the headlamp washers, will my car be legal, or illegal?
If illegal, why so? There is nothing in the MOT test that would cause a failure, hence my query.
Thanks all!
seremotors
Dave the Parts Manager
Mar 11, 2008
12,507
9
Belfast UK
www.seatcupra.net
Been asked for part numbers in another thread so this is probably the best place to post them :)
LEFT HEADLAMP 1P2941039 - £164
RIGHT HEADLAMP 1P2941040 - £164
CONTROL UNIT 4L0907391 - £150 x 2
RANGE CONTROL MOTOR 1P0941295B - £57 x 2
XENON BULB N10566103 - £120 X 2
LEFT BULB COVER 1P0941607 - £8
RIGHT BULB COVER 1P0941608 - £8
CONNECTOR 1J0973737 - £3 x 2
WIRE 000979131 - £1.41 x 2
P13ULC
182
Preston
As said in my thread regarding these, you could buy just the headlights costing £328 and an aftermarket HID kit around £90, change the car loom connector to the new one to fit the Bi-xenon headlights ('how to' shown 1st page on this thread) and should be ok.
May have to wire the aftermarket HID kit using a relay which you can buy the kit of eBay etc so you dont melt any wires and maybe turn Bi-xenons on using VAG-Com.
hoping to try this next year
Im surprised if no one has allready done this as its a very common modification on all other car forums.
S2TTB
The fake K1...
Apr 28, 2008
650
Glesga
Thats a big of a ****ed up way of doing it.. :confused:
why not just...
buy just the headlights costing £328 and matching bulbs, change the car loom connector to the new one to fit the Bi-xenon headlights ('how to' shown 1st page on this thread) and should be ok.
Done it myself. No self levelling, washers, nothing. best 300 quid i've spent. NOt had any problems with the levelling being fixed.
P13ULC
182
Preston
why not just...
When you say matching bulbs, what kind do you mean because we are all talking about having HIDs/Xenons so which ever way, you need the bulbs and ballasts,
OEM = £540
Aftermarket = £90
S2TTB
The fake K1...
Apr 28, 2008
650
Glesga
OEM = £540
Aftermarket = £90
You claiming it costs 540 quid for 2 x bulbs and 2 x ballasts to suit the Bi Xenon lamps?
I bought mine off someone on here, but i have the original invoice and its about the 500 mark all in to get all the OEM parts.
Remember, you dont have to buy the bulbs & "ballasts /starters from Seat. Who i presume like most car manufacturers want over 100 a bulb. You can easily pick up the same bulb online for half the price.
P13ULC
182
Preston
= £540
I know it's cheaper buying an aftermarket HID kit that's why I said that would be a cheaper option, go back and re read slowly because your clearly missing what I'm saying :D
S2TTB
The fake K1...
Apr 28, 2008
650
Glesga
= £540
You're clearly missing what i'm saying.....
Those prices above are from Seat. YOU DO NOT HAVE TO BUY FROM SEAT.
A xenon bulb to fit the OEM xenon lamp can be bought on line along with the suitable ballasts from Veleo for a lot less than what is quoted above. And they will be identical to what comes from VAG dealers.
Simple ;)
I'll direct you to here as an example of bulb prices
http://www.google.co.uk/#sclient=ps...4&aql=&oq=&gs_rfai=&pbx=1&fp=2b2d56b05f1a03c6
dannychapman10
K04 Time ;)
Mar 30, 2009
1,268
Grimsby, UK
Yeah, as S2TTB said, the gas bulbs can be bought from anywhere, HIDS-Direct do D1S and D2S I believe, but I can see where he's coming from with after market HIDS, just like Jon did when he made his own Bi-Xenon headlamps with lenses from USA etc :)
Danny.
P13ULC
182
Preston
Buying D1S or D1R bulbs from HIDS-Direct or anywhere else is the same as I was suggesting an aftermarket kit, there the same thing, think there was some confusion, lol.
I never once suggested paying the £540 from the stealers when I know you can buy a kit from HIDS-Direct for £90, that would be daft!
S2TTB
The fake K1...
Apr 28, 2008
650
Glesga
You were making out that you would fit a full hid kit - ballasts & bulbs. which again, i see pointless :lol:
P13ULC
182
Preston
Yea, not being stupid but fitting just the ballasts or just the HID bulbs wouldn't work, so how else would you get HID bulb in without fit a full HID kit.
Dont want to fall out and im new to the forum but am I missing something here or have you got the wrong end of the stick?
