| Mk4 Ibiza FAQ's (6L) 2002-2008 A list of helpful information provided by Mk4 Ibiza/Cordoba owners, for Mk4 owners |
Thread Tools | Rate Thread | Display Modes |
#1 |
Senior Member
Disabling Auto Locks & Selective Unlocking
This comes up every now and then, here is the procedure to amend using VAG-COM.
To disable Auto Locks... Turn on ignition, start up VAG-COM... Go to "Select control module" from the main menu. Select "46 - Central conv." Click on "Adaption - 10" Press "Up" next to channel number and watch for "Auto Lock" at the top. When found Auto Lock, set "New Value" to '0' from '1' click "Test" then "Save" Press "Up" next to channel number and watch for "Auto Unlock" at the top. When found Auto Unlock, set "New Value" to '0' from '1' click "Test" then "Save" Then click "Done, Go Back" Remove key from ignition then the next time you start up those annoying locks won't bother you. To disable Selective Unlocking... Turn on ignition, start up VAG-COM... Go to "Select control module" from the main menu. Select "46 - Central conv." Click on "Recode - 07" The number in at present will be a even number, add one to that number to make it an odd number then click "Do It". Remove keys from ignition and lock the car - the next time you go to unlock pressing the unlock button will unlock everything. |
#2 |
How do you get vag-com? where do you get the connection cable too? is it compatible with mac? Thanks
#3 |
cheesy quaver
whats the process of putting the auto lock on? just a reversal of the above?
selective locking??? never heard of this... what is it? |
#4 | |
Senior Member
Quote:
Selective locking is where the first click is drivers door, second click for other doors and boot. |
#5 |
cheesy quaver
so look for auto lock, and change it to 1 from 0..
was told this came standard but mine hasnt got it on |
#6 |
Senior Member
0 = Off
1 = On |
#7 |
Senior Member
I don`t mind the selective unlock or lock when you pull away. It`s the point when you stop the car and get out, go to the boot and its locked still
![]() On my Leon as soon as you remove the ignition ALL the doors unlock
#8 |
On my gf's dads 53 plate Leon all the doors lock when the car starts moving - is there a way to set this up on my MK4 Ibiza? Would that be the reversal of the above also?
__________________
Matt J |
#9 |
Senior Member
Yip.
#10 |
Cheers, anyone know the cheapest place to buy VAG COM?
__________________
Matt J |
#11 |
Race Lupo in progress...
buy vag-com software...only place is www.ross-tech.com, you can buy a cable from there or ebay but the ebay lead wont work with the latest version of vag-com
#12 |
cheesy quaver
got mine done saturday thank to a lad i know with vagcom.... but selective locking isnt an option on mine... well i couldn't find the option haha
#13 | |
Senior Member
Quote:
#14 |
HI, if you want to buy the Vag com you have different options. You can buy it in Ross-tech.com,
you can buy it in ebay with the drivers, but not with the software (you will have to "buy" it on the Internet,, the crack version). In my opinion, is better in ross-tech.com (the original). If you are going to use a laptop with Vista you may have some problems ( between the version and the operative sytem) because with Win Xp is OK but with Vista... I have a laptop with Vista and the version of the vag com is 311.2,and is perfectly working so If I can help you, let me know. |
#15 | |
Sir Bob,a geordy legend..
Quote:
#16 |
tinkerer
Hi Chaps,
I have a 2003 cordoba se tdi130pd (with performance torque - brilliant but eats clutches!) I am desperate to disable auto locking as it's driving me crackers (for 4 years!) and i didn't know it could disabled. Any how I'm in Chesterfield area, anyone out there with vagcom who could help would earn my eternal gratitude (body and soul if required). also got a permanent airbag light that needs sorting. Cheers Dave e |
#17 |
drivers vista
hi Damoegan,
attached is the folder with the drivers (vista). If you have any problem you can use google and type " FTDI" one of the options is "drivers". and choose the option of vista. <i'll try to give you a direct link to the website. <ok...i don't know how to attach a document...can anyone tell me how to do it? thanks |
#18 |
Damoegan,
I've got the version 311.2n (no problems to use with vista) / release 311.2n /vag com keygen , drivers and everything. But I don't know how to attach documents here... tell me what you need. Last edited by txavi; 22-10-2008 at 18:22. |
#19 | |
Quote:
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to set auto lights when unlocking car via Vagcom | Al | VAG-COM & Diagnostics | 2 | 18-02-2008 20:06 |
| Auto Lock on Ibiza | terry.h | Ibiza Mk4 | 11 | 22-01-2008 21:22 |
| selective door unlocking | PlymLeon | Leon Mk1 | 9 | 16-09-2007 11:58 |
| Selective unlocking | k11jrp | VAG-COM & Diagnostics | 1 | 23-07-2004 13:51 |
| Selective unlocking not working ? | agent | Leon Mk1 | 0 | 12-03-2004 21:49 |
