SEAT Servicing
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 03-03-2008, 22:32   #1
Aimez
Evil woman of doom beware
Aimez's Avatar
Aimez has 10 points
Swapping reverse and fog wiring over?
http://www.vagcat.com/epc/cat/se/IB/...54/57/4746427/
Can anyonw figure out from this if basically the wiring for the reverse light and fog light can be swapped in some way?
__________________
Mk4 TDI FR Readers Ride
Aimez is online now   Reply With Quote
Old 04-03-2008, 01:35   #2
Guinness
Wish I had a BMW
Guinness's Avatar
Guinness has 10 points
would you need to swap wiring, would it not be a case of swapping the lense and possibly the bulb(if its coloured over). Should be doable aimez
__________________
1.9TDI Mk4 Ibiza
Guinness is offline   Reply With Quote
Old 04-03-2008, 07:34   #3
MTIbiza
www.streetmodified.co.uk
MTIbiza has 10 points
Quote:
It depends on which side the fog light needs to be (either UK or Euro application) UK the fog light has to be on the drivers side for the car to pass the MOT - having 2 fog lights - one on each side is legal too (so long as the drivers side one works)
I would was going to buy some aftermarket rear lights and didn't because the fog and reverse lights were for a european application. could be tricky to swap over.
Mike
__________________
SEAT Strut brace|Green Cotton Filter|PD160 Intake|Milltek Exhaust+decat|Jabba ARB (RED)|Colour coded door strips|Honeycomb vents|LCR Splitter|Red Audi TT 312mm Brakes|SEAT SPORT FMIC + Forge Pipework|Custom Code Remap Phase 2|Sachs Sintered clutch|
MTIbiza is offline   Reply With Quote
Old 04-03-2008, 07:57   #4
Matty.
________
Matty.'s Avatar
Matty. has 10 points
Mike
yeah basically what he said, what is it your trying to do anyway?
baring in mind you will still need your reverse light
Matty. is offline   Reply With Quote
Old 04-03-2008, 19:40   #5
Aimez
Aimez's Avatar
Aimez has 10 points
http://www.motester.co.uk/forums/forum3/565.html these are MOT testers that what they said so it wont work without taking the lights apart.
Want to use German rear lights on my car basically, dont need a reverse light to pass MOT (however need to be blocked out if not in use) but do need a fog on the right or middle of car.
Guinness couldnt do it swapping the lenses without swapping the wiring cos when you put it in reverse the fog would come on? Would need to swap the lenses thou as fog needs to be on the right
__________________
Old 04-03-2008, 20:52   #6
Matty.
________
Matty.'s Avatar
oh so a reverse light isnt needed? so could have two fog lights and no reverse light?
or what about if you had two reverse light units, but wire the fog light to one and put a red bulb in it
would both of these be legal?
Old 04-03-2008, 23:00   #7
Aimez
Aimez's Avatar
Aimez has 10 points
If there is a reverse light it has to work, same as anything on car it has to work if its there. Problem is the fog HAS to be on the right side to be MOT legal. I would pull the fog switch and the fog would work but be on the wrong side of car so fail MOT still?
This is getting confusing now!
__________________
Old 04-03-2008, 23:00   #8
depresion
depresion's Avatar
depresion has 10 points
Yes they would be so long as the red bulb is legal.
__________________
Ibiza modification fund £-1000
(I need more power till my polo is back on the road)
depresion is offline   Reply With Quote
Old 04-03-2008, 23:22   #9
Matty.
________
Matty.'s Avatar
what type of bulb would i need for it to be legal? just a plain red fog bulb do?
Old 04-03-2008, 23:24   #10
depresion
depresion's Avatar
It would need to be CE marked after tinting.
__________________
Old 04-03-2008, 23:28   #11
Matty.
________
Matty.'s Avatar
not tinting my lights
plan on getting a right side cluster from a LHD ibiza
meaning their reverse is my fog
then ill have two white lenses and two red lenses
Old 05-03-2008, 08:16   #12
Aimez
Aimez's Avatar
Aimez has 10 points
Ad lav has done that or maybe it was two red lenses not sure?
__________________
Old 05-03-2008, 09:21   #13
st10587
i only brake for cake!!!!
st10587's Avatar
st10587 has 10 points
i wnt 2 white one and a silver coated red bulb. dont know how legal it will be but would look better imo
__________________
My Ibiza, Emily's Arosa
Project Lupo
st10587 is offline   Reply With Quote
Old 05-03-2008, 19:35   #14
Aimez
Aimez's Avatar
Aimez has 10 points
ask on the MOT forum link iv got up they are all MOT testers who answer you so know what they are talking about sometimes the problem with here is people just say what they think or have heard not what is fact.
__________________
Old 06-03-2008, 07:46   #15
dmjw01
Upstanding Member
dmjw01's Avatar
dmjw01 has 10 points
Quote:
That's not true.
It has to work if it is required to be there. So for example if you have broken front fog lights on your car, that doesn't matter for the MOT test, because front fog lights are not required - it doesn't matter that they're fitted to your car and not working. I know this from experience.
A broken rear fog light would be a different matter. That would fail the MOT test because a rear fog light is a requirement.
So the same rule would apply to your reversing light: If it's not required, then it isn't even part of the MOT test. Doesn't matter if it's present but not working.
__________________
David
And that's why...
dmjw01 is offline   Reply With Quote
Old 06-03-2008, 08:06   #16
Aimez
Aimez's Avatar
Aimez has 10 points
ah ok so i really only need the fog to be on the right and working, would rather have reverse as well really for car parks. I got the idea that it had to be working if present from people on here! The mot forum i went on didnt answer that part of my question at least you know from experience not just saying what you think!
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 7
BeezaDave, diggerbycroft, george130, Hargo, scardy, si87bocanegra, wrexham
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Leon - Reverse Light Problem leon1p Leon Mk2 6 15-05-2011 15:32
Reverse Lights Problem!??? Smart22186 Leon Mk1 4 22-09-2007 18:05
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
