PROSPORT
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net Sponsors - Trading area » APR Motorsport
APR Motorsport APR—Performance Without Compromise—Engineering the highest quality, turn-key, hardware and software solutions for the VAG community since 1997. Call 0845 680 3527 or email apruk@goapr.com with enquiries. GO APR!
Reply
Thread Tools Rate Thread Display Modes
Old 13-04-2008, 18:23   #1
cmccabe165
cmccabe165's Avatar
cmccabe165 has 10 points
APR remap nackered
ryt
ive got a LCR with an APR remap to 265bhp that is switchable through the cruise control and i think it has stopped working,
when i switch the ignition on and select the second program im gettin no increase in power,
was wondering if anybody has experienced this problem with their APR remap,or any other suggestions to what it might be causing the fault cause its driving me nuts.lol
cmccabe165 is offline   Reply With Quote
Old 13-04-2008, 19:28   #2
Feel
Veedubya 'velle
Feel's Avatar
Feel has 10 points
It'll not be the remap, unless it's been reflashed with stock software (been in the dealers lately?).
More likely to be the MAF or other problem, like the nut behind the steering.
Vag-com for a fault code, or just some logging would/might find it.
You could try a reset - write down your radio code, then disconnect the battry for 10 mins.
__________________
Phil
http://www.itseeze-nottingham.co.uk
Feel is offline   Reply With Quote
Old 13-04-2008, 19:30   #3
cmccabe165
cmccabe165's Avatar
how do you mean the nut behind the steering?
Old 13-04-2008, 19:31   #4
cmccabe165
cmccabe165's Avatar
not been to the dealer either!!!!
Old 14-04-2008, 13:06   #5
jaime
I need more money!!!!!!!!
jaime's Avatar
jaime has 10 points
I think he means you mate!
__________________
Koni FSD's, Eibach Pro Kit Springs, Neuspeed ARB's - 22mm front/25mm rear, Powerflex Dog-bone Bush, EBC Turbo Groved Discs/Red Stuff Pads, Forge TIP / 007P DV / Short Shift, K&N Panel Filter..... so far!!
Coming soon.... Forge FMIC.....what else can I have.....hmmmm??!!
jaime is offline   Reply With Quote
Old 14-04-2008, 13:14   #6
Feel
Veedubya 'velle
Feel's Avatar
Feel has 10 points
Yeah, I did. Just poking a little bit of fun, you never know, you might be doing something wrong...
Not sure where you are, but a little trip to Awesome would sort it, I'm sure.
__________________
Phil
Old 14-04-2008, 18:19   #7
cmccabe165
cmccabe165's Avatar
lol.thot thats wat u ment.........honest.
Old 14-04-2008, 19:40   #8
AaronGS
AaronGS has 10 points
Are you getting the correct number of flashes when switching between maps? Just wondering if you have locked it to the stock version?
__________________
2001 Ibiza Cupra: Faster by APR, cooled by Forge, slowed by Brembo. Just gone, already missed.
Stage 3+ Golf now here
AaronGS is offline   Reply With Quote
Old 16-04-2008, 15:57   #9
cmccabe165
cmccabe165's Avatar
yeah its definetly in the unlock position because when i lock it i get no visual feedback from the engine check light at all,think am just gonna get it flashed back to stock then go with revo :P cos i didnt pay for the apr so no loss.lol
Old 16-04-2008, 16:17   #10
AndyHazza
Ex-Awesome GTi Staff
AndyHazza's Avatar
AndyHazza has 10 points
Howdy, sorry only just noticed this thread. Where abouts are you based?
AndyHazza is offline   Reply With Quote
Old 16-04-2008, 17:13   #11
RichardBW
RichardBW has 10 points
If your car has an APR emcs chip fitted then its not going to be a simple refalsh back to stock..it will require hardware removal and a stock chip refitting before that can happen.
You probably need to ask the previous owner how the sw was installed, if it was obd then no problem just getting a simple reflash to stock.
I would get Awesome to check it out tho, it may be something really simple and daft, you could get your remap back to life for very little effort and £??
__________________
Rich.
RichardBW is offline   Reply With Quote
Old 16-04-2008, 17:54   #12
cmccabe165
cmccabe165's Avatar
hey andy
im based in glasgow
thanks
Old 16-04-2008, 20:05   #13
Ianb
Ianb has 10 points
Are you getting the flashing engine light to enable you to switch between programmes i.e. 1 flash Programme 1, 2 flashes = programme 2 etc and so on??
If not then you need to re enter the security lock down code which Awesome will have unless you have got the code. You do this via the cruise stalk. I won't tell you how as it will compromise security of the software but Awesome will talk you through.
Ianb is offline   Reply With Quote
Old 17-04-2008, 09:14   #14
AndyHazza
AndyHazza's Avatar
As Ian mentioned that could be the issue. Do you know if the car has security lock out on it? IS the cruise control functioning as it should normally? If the cruise isnt working then this could be down to something like a brake pedal switch fault, this in turn would stop the switching programs from working.
Being an LCR i'd pretty much guarentee that it is a diarect port remap. If you can get to us to check that would be great, otherwise there is an APR dealer in Kirkcaldy which would be a bit closer to you. They would be able to plug the car in and see what software is on the car.
Old 06-07-2008, 18:10   #15
cmccabe165
cmccabe165's Avatar
are you talking bout Star Performance in kirkcaldy.sorry for taking so long
__________________
Skoda Fabia vRS (standardish but not for long )
Old 06-07-2008, 22:37   #16
Smiler-MK2
Fear The Inferi
Smiler-MK2 has 10 points
Quote:
Pm Sent
Smiler-MK2 is offline   Reply With Quote
Old 23-07-2008, 09:45   #17
bigd
bigd's Avatar
bigd has 10 points
Once the program has been selected on the cruise control, you need to turn the engine off and leave it for 10 seconds before you turn the car over. I made that mistake and thought the map was knackered.
__________________
01 Leon Cupra Arctic Grey
bigd is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 69
150 TDI, 225 Cupra R, 932matthew, alx_chung, Al_G, Arin@APR, AwesomeHassan, Beaconjon, Braindeadhmster, cheungy, ChrisGTL, chrissy1502002, cjhawker, Cupra R, cupra r, ash, Cupra Tommy, cupra.al, DannyC87, DDC_, dkmusic, Doctor Gonzo, ebo007, EZ Tutty, Fahid82, Fredlcr, gammar, Geert16V, Gulfstream, gus, Havok316, IGGYTR, ikhlaq206, joedalton, JP_LCR, KennyPOLO_Gti, kev2477, leon cupra r, Leon_MHX, lm_gauci, lordgibbness, LOU ROB, lukester85, Lukeyy, mardon, MaXXeH, mhill, Mikey P, mookster, morrischad, Mukkyman, munkyboy, ne11er, nicksxjr, PeteB, R1ch85, rudgey, rvdbarnes, seddi, sheeran92, sheffboy, smoothuk, super_electric, thewilfmeister, torquesteer, Vipers_Venom, vwbassett, YIN, _IvY_, __B3NNY__
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Which DV? Forge or APR? ChrisJ Leon Mk1 2 13-01-2008 11:34
Stage 2 remap - PD150 Husbandofstinky Performance Torque 0 20-12-2007 11:42
APR H2O International Show Special AwesomeSarah Awesome GTI 0 19-09-2007 15:22
Remap question AndyC85 Ibiza Mk4 2 20-06-2007 16:40
New Product: APR R1 Diverter Valve £85+vat awesomeade Awesome GTI 0 13-06-2007 15:00
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
