Revotechnik
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk2
Ibiza Mk2 For VW Group 1993-1999 Discussion (including Pre & Post Facelifted Models)
Reply
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 05-05-2008, 18:29   #1
Krishen
Senior Member
Krishen's Avatar
Krishen has 10 points
Strong Petrol smell inside car
Guys when i come to a stand still, eg, at the lights i get a really strong pertol smell inside the car. It also happens when im driving really slowly like in traffic. I have had bad petrol consumption for a while now just wondering if they are connected? Any ideas what i can check/look for?
Someone mentioned o2/lamda sensor. Will this show up on a VAgcom?
Krishen is offline   Reply With Quote
Old 05-05-2008, 18:54   #2
Fl@pper
Cruising with the 6 Pot..
Fl@pper's Avatar
Location: Easy life Cruise control with 200bhp of Bavarian RWD slushboxed Leather Comfort :)
Fl@pper has 10 points
if petrol smell its probably from petrol leaking and there is 2 favourite spots for it at the pipe connections
check the engine bay one just follow the 2 back from the manifold to just inside the drivers strut tower theres a join there that usually loosens off or gets the pipe twisted from being done up too tight
second one is the fuel pump connection which almost certainly will have the original crimp connections on it - look under the rear seat theres a round panel with 3? screws that once lifted you will have access to the top of the tank sender/pump assy. usually leaks there and puddles up a bit, if its wet its leaking as that should be bone dry there.
had both on mine in past
__________________
Fl@pper SouthernPikeyBigEaredHotRoddingIronMaidenMetallicaFan@e-parts.co.uk
Last edited by Fl@pper; 28-11-2008 at 21:06. Reason: my spelling was way too bad back then - lol
Fl@pper is offline   Reply With Quote
Old 05-05-2008, 19:53   #3
jcs356
Cordy owner
jcs356's Avatar
jcs356 has 10 points
Most likely to be a split in the fuel hose under the bonnet. Had both of mine replaced within about a year of each other. Worth sorting sooner rather than later as you don't want it to go up in smoke!
__________________
Jason 2001 Audi S3; 1997 Cordoba SX 16v ... replacing the(t)Rusty 1994 Ibiza GTi 8v; 1958 Porsche 356 Speedster (Replica)
jcs356 is offline   Reply With Quote
Old 05-05-2008, 20:02   #4
Chrisdaman
1 gearbox dead, any more?
Chrisdaman's Avatar
Chrisdaman has 10 points
i had a massive fuel leak at inters last year (some of you will remember, from the "rich" smell lol) got 30 miles to £10, not good lol. New hoses were £12 i think
__________________
[/B]FlickR
Chrisdaman is offline   Reply With Quote
Old 05-05-2008, 20:04   #5
__B3NNY__
OEM with a 'Twist'
__B3NNY__'s Avatar
__B3NNY__ has 10 points
Happend to my old valver also, mine happend to be leaking for under the rear bench.
__B3NNY__ is offline   Reply With Quote
Old 05-05-2008, 20:12   #6
Cupra Kid
Has a TDI!!
Cupra Kid's Avatar
Cupra Kid has 10 points
Inside driver wing is where mine leaked, not too expensive mind, split breathers also produce the same effect
__________________
Cupra Kid is offline   Reply With Quote
Old 06-05-2008, 20:58   #7
Jamie Boy
Posts: n/a
I had a lovely old-style Polo which used to cut out occassionally. Eventually it turned out to be a leak in the fuel pipe, but I only found this out when I tried to start the engine after it stalled in a rush hour traffic jam and the car burst into flames! I can still picture it after 15 years. It was quite a fire! Nutters were driving past it to get on their way as well. I had to just stand by and watch it go up in smoke. Didn't take long! I would check for a fuel leak if I were you.
Old 07-05-2008, 21:34   #8
Krishen
Senior Member
Krishen's Avatar
Ok. ill have a look tomorrow. I don't really use the car anymore in the week so should be safe
Old 11-05-2008, 16:50   #9
Krishen
Senior Member
Krishen's Avatar
Guys iv found the leak. Its just behind (well to the right) of the throttle body. There is a metal cylider shaped pipe that runs under the T.b, at the end of which the leak is occuring. Iv been told there is rubber ring/seal inside that just need to be replaced. Is this a dealer only part? And does anyone know tha part number?
Also will this cause my car to have flat spots? This weekend iv noticed that there are massive flat spots in the acceleration but not sure if this is due to the heat (living in london now so intense heat) or the leak as they were not there before.
Old 12-05-2008, 09:55   #10
cupra103
cupra103's Avatar
cupra103 has 10 points
Good find,
I had the supply line in the engine bay leak last week at the join from rigid to flex hose. I left the cupra running in the drive & when I came back there was fuel running from under the car to the edge of my drive. I was leaking from the chassis rail under the drivers seat. It had run down the pipe in the engine bay & made it's way under the car.
Phil
cupra103 is offline   Reply With Quote
Old 19-11-2008, 10:52   #11
Bentley1989
Mk2 Ibiza 1.4s
Bentley1989's Avatar
Bentley1989 has 10 points
thought id bring this thread up again cos ive got this problem now
it happens when i have the windown down or the sunroof back, the same for when the heaters on too..
when i 1st got the car we took the fuel pump out becuase we thought the pump was bust (ended up being no fuel pump relay) so i dont know if its not on tight enough, was kinda hard to put back in.
but now reading that there might be pipes in the engine bay that need replacing im thinking it could be this....when you had your heaters on did the smell come through more, it doesnt matter if its hot or cold air, still comes through?
__________________
Bentley1989 is offline   Reply With Quote
Old 23-11-2008, 23:05   #12
cupra103
cupra103's Avatar
I think I was just lucky, I'd had no other indications of a fuel leak, no smell at any time. I just walked out to the car & found a 5 foot stream of fuel running out from under the car.
Check your engine bay just in case, the join from flex to rigid pipes is on engine side of the right hand suspension tower under a little heat shield.
good luck
Phil
Old 23-11-2008, 23:08   #13
Bentley1989
Mk2 Ibiza 1.4s
another thing ill get looked at, got an oill leek too...
anoying these cars but i wuddnt want any other as my 1st runner!
__________________
Old 28-11-2008, 21:00   #14
Krishen
Senior Member
Krishen's Avatar
Yeh i had the fuel smell coem even more when the heaters were on (i think lol)
Check the fuel rail and see if you can see anywhere it has been leaking. Might just be the rubber washers on the end having perished.
Old 28-11-2008, 21:05   #15
Fl@pper
Fl@pper's Avatar
if it's worse when windows open and/or heaters on then it's under the bonnet for sure
hot/cold air won't matter as the hot air is just cold blown through a small radiator inside the car anyway
__________________
Old 28-11-2008, 21:09   #16
Bentley1989
Mk2 Ibiza 1.4s
cheers for that guys...another little job ill get round to one day lol
__________________
Old 28-11-2008, 21:17   #17
Fl@pper
Fl@pper's Avatar
if it's a mk2 theres is always at least one to do
__________________
Old 28-11-2008, 21:22   #18
Bentley1989
Mk2 Ibiza 1.4s
haha at least 1;
Ive got a oil leek, leaking radiator, a rattle from somewhere, needs tuning...
It goes on really lol
__________________
Old 16-12-2008, 18:08   #19
JLH
Posts: n/a
i'm havin the same problem too. it only smells a tiny bit at the moment but probably best to have a look at it sooner rather than later. And my fuel consumption seems really crap atm
Old 16-12-2008, 18:10   #20
Fl@pper
Fl@pper's Avatar
you'll smell it slightly if its hanging around - if its pouring out on the road you'll get a whiff and lose fuel everywhere
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 113
-pseudonymous-, AlexG, alexj124, alfaman8, Allsebrook2006, AlpineWhite, ather`s, Baxter, ben450, Bentley1989, Black TDI Turbo, Bluemerlin, brookesmk4, C11PRA DC, CaptainBosh, carlossus, caztech, chris27, chris285, chris2r, CraigW, crezz, Cupra Kid, cupra103, cupra_ahhh, DangerNoodle, dicko's, Duke, edc, Escortdan, F2 Ed, Fl@pper, Flyin Scots, fuey, G223, GrayT, greg, GtiBoy, gulzar, hopkinsgm, hydroextreme, Ibiza Dan, Jarre, jcs356, jenk, Kai_1600, krisby, Krishen, Leespat69, Leon Paul, LukeArrowsmith, M14KCY, M1KEH, mark garfoot, martin_hill_198, martziniuk, Matt3743, meltonlad, mickeykdan, milner575, moggytom, MooRzy, mozzer1985, mrurbanite, nally270lb,TQE, Nick Hallett, Novataken, old 'uns, OllieL, peck10, PompeyPete, projectgingawar, Pure:Torque, Quidam, R1TCH1E, R3 NDD, Rayner1990, Rick, rjessett, rk696, rob 23, robreidmotors, rocket_ronnie, roiLaredo, Rory1984, rsmith, sambo19, SHADY-NINJA, sionowz, sl1m1thy, smokinjoka, sooty16v, Spirit Furtive, sterae21, stoner41, STU3Y, suj, Super gaz, surreyfull, Tangerine_Dream, teeth2k, thewilfmeister, Tomas, turbo87, twitterers, Updown789, vaudaz, Vegas1982, westie309, Wiggy20, woody1986, __B3NNY__
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The famous car Audi is keeping a big secret. ZBOYD Audi Brand Group Discussion 6 14-02-2008 21:33
Petrol Smell jizzy_jazzo Leon Mk1 4 19-11-2007 18:29
Another tale of Woe (long) JonTelfer Altea - includes XL and Freetrack 23 21-10-2007 20:37
Strong smell of petrol djscorch REVO Performance 6 21-09-2006 13:45
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
