SERE
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net Sponsors - Trading area » REVO Technik Tuning
REVO Technik Tuning Serial Port Tuning that doesn't require ECU Removal - The 1st VAG specialist to develop and market this new Technology.
Reply
Thread Tools Rate Thread Display Modes
Old 01-06-2003, 18:10   #1
Blast
Blast has 10 points
What exactly is a revo?
Is it a replacement ECU, or and add on chip like a Dastek? And what exactly is an sps1, 2,3 etc?!?! Whats the difference.
What does the chip alter in the engine? The pressure of the turbo? What bar is it at normally?
Regards
Stu
Blast is offline   Reply With Quote
Old 01-06-2003, 18:12   #2
Blast
Blast has 10 points
forgot to mention, i'm talking about an ibiza 1.8 20v turbo.
Regards
Stu
Old 01-06-2003, 19:43   #3
m0rk
sarcasm comes free
m0rk's Avatar
m0rk has 100 pointsm0rk has 100 points
www.revotechnik.com
basically it's new software that gets uploaded to your ECU via the diagnostics port, so is non invasive (nobody solders to your ECU)
the SPS units provide switching to various levels to adjust from Stock (standard) to tuned in various levels
their website explains it pretty well - failling that call them on 01327 301901
Ask for Kev
M
__________________
m0rk is offline   Reply With Quote
Old 01-06-2003, 19:55   #4
Blast
Blast has 10 points
so, you could like have the normal ECU settings, and then press something and have the modified setting?
Regards
Stu
Old 01-06-2003, 20:42   #5
Rage
Rage's Avatar
Rage has 10 points
More of a switching unit. which isn't as instant as you make it sound. It takes about 5-10 seconds to switch between programs and the ignition switched on and off during the process. Most people I've spoken to tend to leave it on as fuel economy is largely unaffected under carefull driving and the performance is addictive.
Rage is offline   Reply With Quote
Old 01-06-2003, 21:42   #6
Blast
Blast has 10 points
I've had a look at their website, and this product seems wicked!
With the SPS3 then, you can alter how much boost the turbo is pushing out? If you have a nitrous system on to reduce turbo lag, could the unit control that?
Regards
Stu
Old 01-06-2003, 21:50   #7
Colin
Colin's Avatar
Colin has 10 points
Stu,
To my knowledge, (Guys correct me if iam wrong) Nitrous does not work well on the 1.8T engines. If you were to do this you would need a seperate controller anyhow.
__________________
Click here to email me
Formally Known as C2PRA
Colin is offline   Reply With Quote
Old 01-06-2003, 21:59   #8
Blast
Blast has 10 points
oh right. i was thinking that if the boost was up high, with nitrous there may be a problem with too much pressure, and you would risk blowing the head gasket?
Regards
Stu
Old 01-06-2003, 22:20   #9
m0rk
sarcasm comes free
m0rk's Avatar
NOS burns very hot. so it'll melt your pistons
M
__________________
Old 02-06-2003, 11:27   #10
Blast
Blast has 10 points
OK, no nitrous then. lol. can the revo be used to reduce turbo lag? I supopse not, because the turbo still needs to spin up doesn't it.
And how do you work the little black box? I think if I did it I would get the SPS3, so that I could adjust the turbo boost.
Regards
Stu
Old 02-06-2003, 11:32   #11
m0rk
sarcasm comes free
m0rk's Avatar
SPS3 has a 10 position switch to change the boost settings
M
PS - also can adjust the timing for different fuels etc
__________________
Old 02-06-2003, 14:41   #12
Blast
Blast has 10 points
When the new program is uploaded to the car, is it specific to what the car is running or is it a standard progam? For example, if I had an enclosed induction kit, new manifold & decat on the car, would the new mapping be adjusted to get the best out of these.... or not?
Regards
Stu
Old 02-06-2003, 14:45   #13
Cupramax
Uber pimp meister
Cupramax's Avatar
Cupramax has 10 points
Thumbs down
No there is a set mapping for each type of ECU but they are not customised for your mods.
__________________
A5 Cab 2.0T Sline
Cupramax is offline   Reply With Quote
Old 02-06-2003, 14:46   #14
Cupramax
Uber pimp meister
Cupramax's Avatar
Cool
Quote:
M
And exhaust valves and spark plugs, seen some picks of an obliterated 1.8T TT engine that had been bodged with NOS. Not a pretty site
__________________
A5 Cab 2.0T Sline
Old 02-06-2003, 14:48   #15
LDoR
Senior Member
LDoR's Avatar
LDoR has 10 points
No, it's a standard map as far as i'm aware, you can get specific maps from other companies but they aren't stealth like Revo which is a major attraction for many people.
__________________
Now drives and Audi S3 with Revo
LDoR is offline   Reply With Quote
Old 02-06-2003, 14:56   #16
Blast
Blast has 10 points
well, the thing i like about the revo is the serial port programming bit, especially the adjustable boost settings and the security features. Shame it's not specific. Does anyone else offer these types of features with a chip? What happens if i want the cams done, because they need the ECU adjusting so that the idle will work properly won't they?
If the revo is just a standard setup thing, can I get it sent to me, and let me do it myself then? I'm in Jersey you see, and I don't believe that there is a dealer here. I would have to fork out £500 odd quid on getting over to the UK mainland. Plus I won't pay the VAT if I get it sent here.
Regards
Stu
Old 02-06-2003, 15:06   #17
Cupramax
Uber pimp meister
Cupramax's Avatar
What sort of car have you got/are you getting? Cams seem a bit overkill. Having driven in Jersy I cant see where you'd go to enjoy the power?????
__________________
A5 Cab 2.0T Sline
Old 02-06-2003, 15:13   #18
Blast
Blast has 10 points
At the moment I've got a saxo VTR, but I'm looking into an Ibiza 1.8 20v Turbo. Dunno what it's like on the ibiza, but on the saxo, liek £800 odd would get you a set of cams & a dastek to smooth out the idle. Don't ask me the details, cause I never had it done! Just seemed like if you then had a nice cold feed from an enclosed induction kit, increased boost on the turbo, fast road cams, new manifold & decat and a less restrictive exhaust.. oh and a revo, the car would be running nice and powerfully! lol. Okay, it would get expensive, but if it was done over time it would be okay!
And you can still easily enjoy the power over here, we have endless numbers of country roads to hammer on, there is the 5 mile road (which lives up to it's name)... and I'm off to uni at the end of the year (yes with the car) so hopefully I can find a track over there where i can do some safe fast driving! lol
Regards
Stu
Old 02-06-2003, 15:13   #19
Blast
Blast has 10 points
oh yeah, a mate of mine who lives over here has an impreza running 416bhp, but i think he's had something else done since then!
Regards
Stu
Old 02-06-2003, 15:16   #20
edc
Blue Leather & Shiny Bits
edc's Avatar
edc has 10 points
Paying for the 'stealth' of revo is pointless then with alll these mods, plus, you will need a more specfic map to benefit from the extra work you intend. Try AmD or Jabba.
__________________
1997 Ibiza 2L 16V Cupra GTI - long gone in 2008!
edc is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 5
alien1974, danstederz, Gtiracer, nemo1983, ScottHmk4
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
