Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 28-09-2008, 12:04   #1
shaheer19
Posts: n/a
1.2 Seat Ibiza won't start
My 1.2 Seat Ibiza 2002 has done 69K and has got some major issues. It was fine till the other day it did start with difficulty and drive but only if you gave it loads of revs. The engine made loud clanking/gurgling noises and cut out after a few mins. I got it home eventually but now it doesnt start and the battery has gone flat....and no, its not under warranty. Anyone know what to do to fix this car?
Old 28-09-2008, 12:48   #2
B3NNO
Posts: n/a
well im not sure about the loud clanking/gurgling noises, but for a flat battery sounds like your alternator has packed up
Old 28-09-2008, 14:11   #3
1.9...stefan
HYBRID???
1.9...stefan's Avatar
1.9...stefan has 10 points
posible timing chain slipped
1.9...stefan is offline   Reply With Quote
Old 28-09-2008, 15:45   #4
stezo2k
Anjuna Monkey
stezo2k's Avatar
stezo2k has 10 points
Quote:
my thoughts extactly, hopefully not though
________
Lovely Wendie
stezo2k is offline   Reply With Quote
Old 28-09-2008, 16:05   #5
RUM4MO
Senior Member
RUM4MO has 40 points
Sorry I hope I'm wrong, but I'll third that - and it's not good - not very good at all. I would have thought that all cars still within the dealer service loop would have had modified parts fitted by now, if you are outwith the dealer service loop then I'd expect if you were getting the car serviced by an indep VAG specialist, then if they did not warn you about this that is not too good, if you service the car yourself then its up to you to make yourself aware of any "new" problems and take corrective action. Either way sounds like your wallet is about to be crunched!
RUM4MO is offline   Reply With Quote
Old 30-09-2008, 13:42   #6
mixupz
Just call me Rash-MIX
mixupz's Avatar
mixupz has 10 points
Quote:
dont use a credit card...cos thatd be a credit crunch
u can tell im a crunchy nut
__________________
danmay/mixupz are the doggies dangles of the 1.2's THE ONLY EXTREME BLUE 1.2 IBIZA ON SCN & TOP OF BHP PACK OUT OF THE 1.2 CREWS http://www.seatcupra.net/forums/show...ht=mk4+sleeper My 64bhp MK4 now stands @ 80.5Bhp/92.9lb/ft @ AmD 13/07/08 LONDON MEET http://www.seatcupra.net/forums/showthread.php?t=185099
mixupz is offline   Reply With Quote
Old 30-09-2008, 14:46   #7
danmay
Fast cars, shooting stars
danmay's Avatar
danmay has 10 points
lol
__________________
GUESS WHO'S BACK BACK MUMMAFLUCKAAAA!
They see me rolling....they hating.......
08 FR TDI - DECKED, TT COMPS, TURBO BACK EXHAUST AND WHO THE HELL KNOWS WHAT ELSE. BOI
danmay is offline   Reply With Quote
Old 30-09-2008, 15:11   #8
Nath.
The Gentlemans Express
Nath.'s Avatar
Nath. has 100 pointsNath. has 100 points
I take it you killed the battery from trying in vain to start it ??
As others have said, the no1 cause of this kind of thing is a timing belt tessioner failure, the chain then jumps teeth, one or 2 at first and that makes the engine tough to start and a bit sluggish to drive. When the chain jumps too much you end up with valvs smashing into pistons and a bill for £1k pluss unless you have a warrenty
Good luck, you're going to need it
I think there is more info in the mk4 FAQ bit
Nath. is offline   Reply With Quote
Old 30-09-2008, 15:25   #9
StuPDi
old guy
StuPDi's Avatar
StuPDi has 10 points
i had a belt jump years ago, the RAC man told me if it wont start in the first couple of seconds, turn the key off and try again
keep on cranking the key for long periods of time is bad news as the fuel pump is whacking in more and more fuel and it's not being burnt due to no firing.
i ended up flooding the engine (something i didn't think was possible with fuel injection :s )
sounds a big job if it is a slipped chain, hope you get it sorted
Stu
__________________
StuPDi is offline   Reply With Quote
Old 30-09-2008, 19:02   #10
RUM4MO
Senior Member
sounds a big job if it is a slipped chain, hope you get it sorted Stu
Stu, was it an Audi V6 engine that you flooded - I did that a few months ago - 2.8V6 Passat, in the end needed preheated plugs + a little oil down each bore + AA starter pack! (Root cause was the changing of fuel filter with a cold engine - happens a lot with Jag+BMW+VAG Vee engines - if you do it with a hot engine the residual heat vaporises the excess fuel and you get off with it, with a cold engine it ends up washing the oil (seal) out of the rings so compression is lost!) You live and learn.
Old 01-10-2008, 18:52   #11
StuPDi
old guy
StuPDi's Avatar
na mate, it was a 1.1 Fiesta
Stu
__________________
Old 02-10-2008, 11:24   #12
peasie
Posts: n/a
Sounds like the timing chain has slipped,mine wouldnt rev over 3k dtc showing camshaft sensor error so i replaced this still the same i ended up replacing timing chain but mine had the new longer tensioner fitted 2003 model so i replaced everything anyway timing had jumped reset top dead center using special locking tools and runs perfect now.Good luck any questions i can help with just ask
Old 02-10-2008, 12:35   #13
mixupz
mixupz's Avatar
Quote:
how easy was it do do your self matey!? mines hitting 30k now and im considering fitting the revised kit and replacing the chain early...prevention is better than cure and all...
__________________
Old 02-10-2008, 13:28   #14
peasie
Posts: n/a
Hi mixupz straight forward to do if you have the correct locking tools 2 lock the camshafts at tdc and the flywheel gets locked as well so it cant really move tools are from laser
Timing Tools - VW 3 Cylinder 4083
Timing tools for Volkswagen Lupo and Polo 1.2 litre engines - 2 and 3 cylinder, 6v/12v 12v tools are OEM T10123x2 and T10121x1 with AZQ/BME engine codes and 6v require T10120x1 and T1021x1 for AWY/BMD engine codes.
Typical Retail Price - £72.28
got them from here much cheaper and spot on next day delivery i paid £47 inc p+p
http://www.bennetts.com/
hope this helps if there is out else you need to know i also bought the haynes polo manual same engine spot on info,steve
tools are £50.99 inc p+p in the uk
this was the cheapest i could find and believe me i am tight as a fishes ar*e
Now can someone please help me with my power steering pump aaahhhhhh!!
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 18
andy17, Blanco92, bloody_typical, Dannheath, Exeo Rog, jeffery, joshpmc, JU5 2 SLY, KernowFR, markisgoing, mattbrowning, melkor12, Nasty_balls, Russ_20vt, Ruthers, scottc1088, Steely, stezo2k
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ibiza Mk5 photos in Ibiza Town SEAT dealers warren_cox Ibiza Mk5 17 14-07-2008 02:45
seat ibiza 1.2s and polo 1.2 parts etc help BIGALUK Ibiza Mk4 7 12-10-2007 22:42
Website İ 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
