Opie Oils
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rate Thread Display Modes
Old 20-11-2008, 09:42   #1
DOWIE
Amateur SEAT specialist!
DOWIE's Avatar
DOWIE has 10 points
Front wheel bearing cost, have i been ripped off?!
Hi all, apolgies, Im not on here much, just dont have the time.
Got the Leon serviced yesterday, its an 06 Stylance DSG 2.0 tdi
The basic service parts Im not fussed about their cost, but I needed a front wheel bearing, and the part ws £145 ! Now im used to £20 wheel bearing kits on fiestas, corsas etc from the yunger days, but that seems unreal
It isnt even a genuine SEAT part either
Unfortunately, the car is no longer under warranty, unless im mistaken and I have a 3 years warranty, and not 2?
Please rest my mond, or tell me otherwise so I can have a go at the mech.
DOWIE
DOWIE is offline   Reply With Quote
Old 20-11-2008, 12:40   #2
DaveysFR
DaveysFR's Avatar
DaveysFR has 10 points
Unless you car is a European Import then it should come with a full 3 year manufacturers warranty starting on the date of first registration (imports are only covered by 2 years warranty). Wheel bearings are not usually covered under warranty though as they are classed as a Wear and Tear part such as brake pads/discs etc, although, if your car has only done VERY low miles, the dealer may be willing to replace it under warranty or help you pay for a percentage of the repairs.
Hope this helps
I agree £145 seems realy steep, my old focus bearings were £25 each including the vat
__________________
Car: 2007 SEAT Leon Cupra Aero Skirts and Spoiler, Xenons, Bluetooth, Armrest, Chrome Dash Bezels, Alu trim kit front and rear
DaveysFR is offline   Reply With Quote
Old 20-11-2008, 12:52   #3
phil3012
Senior Member
phil3012 has 10 points
I thought the Leon was 2 years manufacturer and 1 years dealer warrenty.
It would be worth giving SEAT customer services a call to see if the car it still covered and by who.
__________________
Gone: MY08 SEAT Leon Cupra in Inferi Black
Current: MY09 Audi TT TDi in Condor Grey
phil3012 is offline   Reply With Quote
Old 20-11-2008, 13:40   #4
ghosty
ghosty has 10 points
it seems alot to me for a wheel bearing kit. try giving gsf (http://www.gsfcarparts.com/) or eurocarparts (http://www.eurocarparts.com/) a call for a decent price.
i got a rear wheel bearing for my audi a4 about 6 months ago and it was 60 something quid (from gsf)
cheers,
g
__________________
Silver Audi A4 TDi
Red FR TFSi DSG, 18", Bluetooth, Conv pack, iPod, Parking sensors, Alu door trim kit - collected
ghosty is offline   Reply With Quote
Old 20-11-2008, 13:41   #5
DaveysFR
DaveysFR's Avatar
phil3012,
You are correct mate, 2 years manufacturers and 1years dealer warranty, my mistake.
DOWIE,
It would be worth ringing SEAT Customer Services as phil3012 has said mate.
__________________
Old 20-11-2008, 16:23   #6
Foo56
Foo56 has 10 points
I got quote not long ago from Leicester's Seat and it was exactly the same price as I remember.
Foo56 is offline   Reply With Quote
Old 20-11-2008, 16:24   #7
UncleFester
Grumpier by the day!
UncleFester's Avatar
UncleFester has 10 points
I believe because the dealer supplies it as one piece with the hub when you can get just the bearings and have them pressed in.
UncleFester is offline   Reply With Quote
Old 21-11-2008, 11:29   #8
SEATgod
Banned
SEATgod has 10 points
It's because the ABS rotor is in the wheel bearing!
SEATgod is offline   Reply With Quote
Old 24-11-2008, 09:52   #9
DOWIE
DOWIE's Avatar
DOWIE has 10 points
It was def the hub part also that was replaced. I wish Id checked with SEAT forst as I stupidly assumed it was a 2 year warranty, which has run out!
Happy days
Thanks for the replies
DOWIE
Old 24-11-2008, 10:31   #10
andycupra
status subject to change
andycupra's Avatar
andycupra has 60 points
Quote:
this is what i was thinking.
Charging loads of the part is easier for them. They would probably argue that you save on labour as they dont spend time pressing out the bearing, and then they may say this may not work. (or theydont have the equipment)
IMO its less hassle for them, but potentially more costly for you to get a new hub etc.
IMO Never get a dealer to do jobs like this. Labour if often twice that of decent garages and they appear to be unable to use common sense or initiative and work to the 'book' all the time.
andycupra is offline   Reply With Quote
Old 24-11-2008, 13:48   #11
SEATgod
Banned
Hello,
You can't get the bearing seperate!
It comes as part of the flange which is then pressed into the hub carrier.
It is because the wheel bearing carries the ABS rotor!
KR
Old 24-11-2008, 13:57   #12
andycupra
andycupra's Avatar
Quote:
Originally Posted by SEATgod View Post
Hello,
KR
well if this is the case then its a poor design that a part like a wheel bearing potentially incurs such a cost.
Old 24-11-2008, 13:58   #13
DOWIE
DOWIE's Avatar
DOWIE has 10 points
Tellin me, i was expecting a normal service bill, then had £200 on top!
Old 24-11-2008, 14:02   #14
SEATgod
Banned
Hardly poor design.........just advancements in technology!
Years ago a set of plugs, points and a condenser cost amount 3 bob and a shilling!
Now a set of plugs will set you back £80 for 4.
Technology costs money!
I would not want any vehicle now out of warranty...costs are just to high for repair!
Old 24-11-2008, 14:09   #15
andycupra
andycupra's Avatar
not if you are comparing like for like. The plugs you refer to as being £80 are platinum and so a much higher quality product.
You can get plugs that are much the same for £12 or even cheaper.
Advancements in technology are good. But there is no reason why a part that is often requiring servicing or replacement cannot be designed to be replaced.
An example would be wishbone bushes, some places will replace to bush, but a dealer will often look to replace the wishbone as its 'easier'.
Old 24-11-2008, 14:13   #16
SEATgod
Banned
Its not some much easier as cheaper....look the repair times up and the hydraulic press you need for fitting the bushes!
R & R wishbone on a Leon, against R & R a wishbone and then strip out and replace the two bushes!
It's actually cheaper for you! Mor efficient for the Dealer!
Old 24-11-2008, 15:18   #17
UncleFester
Then we come to the iffy topic of cars that have headlight bulbs that are innacessible to all but the smallest of 18 year old trainee double jointed fingers.
Now to be fair, SEAT aren't the worst culprit for this, Rover and Jaguar are right up there at the top .... but it illustrates the point being made.
Actually it's cheaper to buy the part and take it to a 'normal' garage who can fit the part without invalidating the warranty than it is to pay dealer price for the part and then dealer price for the labour.
Old 24-11-2008, 15:52   #18
andycupra
andycupra's Avatar
i agree, - dependant on the labour rate....
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 223
140SPORT, 225sport, aaron99099, abs111, Adamm, Adrian., Adz87, Al, albevan, alexj124, alx_chung, andycupra, Andy_FR, AP2000, Bakerycraig, bakester69, Baldie, basil, Bassedout, bbob, betts, bill, blackcupra, blackhandcupra, BoardTracker, bobphatboyphat, bobster555, Boyskew, br0wny21, brad1, Bretty, C11PRA DC, carew, CBRED, Chri$, chrisboyle999, clarkeg, creation72, cupra fan, Cupra Kev, Cupra-Dan, CUPRACAR, Cupra_Tim, Czechboy, DAC84, danfr, DanGB, darkhorse, dave170fr, Davego46, daveh1, DaveP, DaveysFR, davyboy, DIFT, djfixter, Doey1978, Donnyboy, DOWIE, Dozer360, dre, Dubb, Dudemeister, Eebaroo, egypt, EoinM, Fergal84, Fien, flak monkey, flattodamat, Foo56, freestyler, FRLeon, fyfe9, gac, gammar, Gary@Cookies, GavinM, gav_FR, Gazguthrie, gazR, ghosty, gjt880, Glovepup, Gm8, GrizzlyUK, GTFR, hammaye19, Hamzilla, hawtin1584, Ian_Cupra_R, ibiza75, Ibiza_Dave, Igor23, Imteyaz, intruder, Ithaca, J-me, jamalster, jammio, Jase7, jaymd, jeffery, jenk, jeyre, jimbo1876, jimmer111, jj06, jmackay2, Jockular, johnbev, johnboy98, jon-tfsi, jonjay, Jubjubbird, karizma_fas, KingofTrash, knight, L3ONLB, landie9, lee123, LEE69, leero783, leon sport, leonbtcc140, leonfr170, LeonFSi, leonpower, lofer, M-c-G, machapman001, maggs, markbrum, markoos, martziniuk, matylad, mckfoxy, metamarc, metroarmadillo, Michael B, micknoon, midgetgem, Moley RUFC, morleymackam, mr_smith, mumblist, Muttley, NeilW, nog, norm29, nsheeka, OldNick, OLDOILER, olethalb, p-twirler, Pacey, palmer84, paul m, Paul Merritt, penfold uk, Peter 87, phil3012, Pinocchio, Pod-ni, Ptar64, Pummy, QuietQuackers, r6_allan, Rampage, rllmuk, Rob GTI, robdf2, Robertotoledo, Robster5, rodneysmart, roly, Ruddmeister, rymon, SaneDave, Scottl, scottslb1111, Scotty2hotty, SeanCorky, seanD, SEATgod, seremotors, shaunymac, sie77, singh123, Songman, SPARKY999, SpeedyJ, Spireite, SpursMadDave, SSimpson3, steve_1017, stophere, Street, sven7, sxi20vt, sydoggkdy, Tam, Tartan58, taxi ray, TDCupra, Thev5, tom fada, Tom99, tommot, tommycx, tomseattdi, top0cat, traumapat, UncleFester, waddo1958, wanna_cupra, warhamster, Wilko, Woulda-Coulda, wrexham, YIN, ZAO
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cost of replacing front wheel bearing on LCR andyj Leon Mk1 12 23-08-2011 08:58
Front passenger wheel squeeks SRStdi Leon Mk1 6 08-09-2008 15:29
cost of a new front wing J.Topaz Ibiza Mk3 5 19-05-2008 11:21
Wheel bearing replacment.... damaged hub ! andyj Leon Mk1 29 25-01-2008 09:57
Guide to changing a front wheel bearing? chris27 Ibiza Mk2 2 15-11-2007 19:04
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
