Formula One Brighton
SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1 » 1.9tdi 110 SX Power Loss Problem
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Old 13-01-2009, 13:03   #1
Culli
Newbie
53 plate Leon 1.9tdi 110 SX
I suffered a strange loss of power a few weeks ago whilst over taking a slow moving lorry. In 3rd gear as the revs built up the engine suddenly seemed to die. It would then struggle to get over 2500rpm whilst in gear, although it would rev normally in neutral. Upon restaring the engine the problem was gone and the car drove as normal.
I was told not to worry about it unless it happened again.
Last night it did happen again. In 3rd gear it suddenly dropped power and refused to get over 2500rpm in any gear. I drove it for a while with the problem and although sluggish it would drive well. Once again after restarting the engine the problem was gone and i failed to be able to reproduce the problem. It feels like its a problem with the turbo as it usually kicks in around 2000rpm and it below that rev range the engine seems no different.
Any help is much appreciated.
Culli is offline   Reply With Quote
Old 13-01-2009, 13:12   #2
1.9...stefan
HYBRID???
1.9...stefan's Avatar
sounds like its going into limp mode, have you got any mods on the car, really need to getit on vag com
__________________
1.9...stefan is offline   Reply With Quote
Old 13-01-2009, 14:05   #3
Culli
Newbie
the car has no mods. what exactly is vag com?
edit * i dont have any error messages appearing so not sure how vag com would help.
Old 13-01-2009, 14:29   #4
Muttley
Catch that diesel!
Muttley's Avatar
VAG-com is a type of diagnostic software that you can purchase and run on a laptop, provided you have the right connection lead - it has a dongle in it, and is relatively expensive. There is a section of the forum devoted to VAG-com. Using it, you can find out what the fault codes are that have caused dashboard lights to come on, and can make some modifications to the stored parameters - for instance, closing down the EGR system to minimum activity, programming the doors to lock as you drive away, etc.
Limp mode is a protection mechanism built into the ECU. If it detects some readings from the engine that are outside its preset limits, it goes to a more conservative map, reducing the amount of power available to avoid damage to the engine.
It sounds like you are hitting limp mode. How many miles has the car done, and has much of it been slow-speed, shopping trips or in-town commuting? There are two faults I know of that are likely to cause the symptoms you're seeing.
The one that gets reported most on here is sticky vanes in the turbo - soot builds up and causes the turbo's variable geometry inlet blades to stick in the "closed" position, the one that is used at low engine speeds to increase the gas flow velocity through the turbo and get it spinning earlier to provide boost from low revs. If the vanes stick, then as revs rise the turbo tries to overspeed, raising the boost and triggering an inlet manifold overpressure fault. This drops you into limp mode, to keep the revs down. Limp mode is reset when you switch off the engine (well, most limp modes).
The other one is sticky EGR valves. The exhaust gas (hot, sooty) added to the inlet (yuck) for emission control purposes (yes, really!) combines with oil from the crankcase breather (plumbed into the inlet upstream of the turbo) to form a sticky sludge that bakes onto the hot inlet manifold, choking it and eventually causing the EGR valve to stick partly open (it's supposed to close at higher revs). This allows too much exhaust pressure into the inlet manifold which again results in an overpressure reading and limp mode.
The EGR fault is usually seen on higher-mileage engines - it happened to me on an Ibiza at 80K. The sticky vanes can occur at relatively low mileages.
Muttley is offline   Reply With Quote
Old 13-01-2009, 14:45   #5
Culli
Newbie
the car has just passed 50,000 miles. when originally bought i lived about 60 minutes from work which included several bypass roads where i could open her up. about a year ago i moved about 5 minutes from my work and the car rarely hits the higher revs. i do the occasional longer motorway journey traveling to and from basketball games, but maybe not enough. so i presume the problem is the first one you mentioned. how would i go about getting this fixed? is it something which will clear on its own? or do i need to repair/replace parts. it has only happened the twice and i have run the car upto the rev limiter in 2nd and third and not been able to reproduce so does that mean its not a big problem or the start of a problem.
please excuse my lack of knowledge of car parts etc.
Old 13-01-2009, 15:20   #6
Robb1990
Robb1990's Avatar
You need to clean the turbo out. There are 3 ways to do it really, either take the whole thing off, strip it, clean it and build it back up and replace. Use a cleaning product which will involve taking off the axhaust and spraying in a cleaner. The third option is to give it a good old ragging. Get the engine warm, then run through all the gears to around 4000Rpm, obviously keeping to the speed limit Do that and it should see you clearing out the turbo, if its only just started doing it, then the soot shoudlnt be too baked on yet and fairly easy to clear.
4th and 5th gear work the tubo hardest, full throttle from around 2000Rpm
Id try the driving hard option first obviously. then if the problem still persists and is annoying you, go for the other 2 options. the strip down wont be cheap though, so be warned now
If its any help mine is doing the same thing, if i go on the dual carrigeway near me, cain it in 3rd to 4000rpm, shift to 4th keeping the revs high, then 5th, it helps ALOT, if i then go a week or so without doing this, it'll be back into limp driving normally (ie shifting at around 2Krmp, then planting it in 4th when on bigger stretches of road) So key is - once its hot, rev the balls off the *******, it'll love you for it
__________________
Leon TDi Red, CCV bypass, LED sidelights, stickahs, BASS, 40GB's of music.......... sticky VNT Oddly i still love it!
Robb1990 is offline   Reply With Quote
Old 13-01-2009, 15:32   #7
Muttley
Catch that diesel!
Muttley's Avatar
It does sound like sooted-up turbo vanes. One way to fix this is to burn the soot off, by getting the turbo hot and keeping it hot for several minutes. This will happen when the engine is loaded at mid-high rpm. Ideally you need to find the longest continuous hill on a motorway or dual carriageway near you and hold your speed as high as you can (keeping legal limits and traffic conditions in mind) while climbing the hill. Some have reported seeing sparks behind them (in their mirror, obviously) which is the smouldering soot being ejected. However, you aren't looking for fireworks, just to burn the soot off the turbine section of the turbocharger, the bit that is in the exhaust flow.
http://www.kadekticaret.com/whatisaturbocharger.htm
http://forum.ih8mud.com/80-series-te...-faq-info.html
http://www.motortrend.com/roadtests/.../photo_17.html
http://www.motortrend.com/roadtests/.../photo_18.html
Turbo stripdown and cleaning pictures here, including an animation of the vanes.
Reply
Bookmarks
Tags
110, 19tdi, loss, power, problem
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 32
1.9...stefan, Adz87, BoardTracker, bombheads12, chris toone, Culli, depex, dh, dieselpower, DPJ, egypt, james walker, JimmyCupra, MarkWales, matt-drummer, Muttley, NinjaFlavour, paul geraghty, pete147, r1convert, ramzy_86, Robb1990, RSTuning, sat21, shaft65, sheptdi, sssstew, Stubbo, Tartan58, tony19b, WeeJase, zeroSignal
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
loss of power and it s not coil pack or MAF. Cupra_20vT Ibiza Mk3 1 19-09-2008 15:51
Loss of power - 1.8T CH1 Leon Mk1 8 15-05-2008 18:38
Air Con Problem - Intermittant Power wvw Leon Mk1 0 08-05-2008 17:38
High Input Power - Rear Speaker Loss??? V15NEV ICE - In Car Entertainment & Security 3 10-03-2008 11:31
TDi 110 Chip Remap v Power box? dd2005 TDi Tuning 1 08-02-2008 14:17
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
