| Ibiza Mk3 For 2000-2002 Specific Information. |
Thread Tools | Rate Thread | Display Modes |
#1 |
Banned
clutch pedal problems
hi after my clutch pedal broke i had it welded and now back together . it feels to slack the pedal goes half way down before the clutch engages anyone had these problems before many thanks
#2 |
did you put the spring back in?
#3 |
Banned
spring is in there lol
#4 |
Same thing happens to mine mate! What springs u on about? I have like an inch of play at the top of the pedal before it becomes really heavy nearer the floor :s
David! |
#5 |
Banned
same here mate behind the pedal there shuld b a spring i gota make sure mine is in secure as it clicks on way out lol
#6 |
a spring behind the black metal plunger u mean?
#7 |
Banned
behind the pedal its self there should be a spring check to see if it has moved . have u had the problem with clutch pedal snapping yet
#8 |
ahh i see! yeah mine snapped about 6 months ago so i welded it up. Got a few new pieces from my local SEAT dealership and fitted them (white clip and a large white clicker type thing <--great description haha!) anyway..over time theres now play in the top of the pedal like i said :s
I'l have to get under and have a good luck..could be an easy explanation.. David! |
#9 |
I mentioned the spring because when I had my clutch pedal welded up I couldn't get the spring back in so just left it off, over time I noticed I couldn't get into gears, anyhoo if you put got foot under the clutch and pull up and it comes out a bit, you will know what I mean when you try it, then the spring is missing/ not in place correctly... Give it a bash let me know if any effect
#10 |
OEM with a 'Twist'
Sounds like the spring isnt located properly, if its there.
#11 |
Banned
u really need spring to kick back pedal
#12 |
Senior Member
the problem you are having sounds like its the pedal adjuster! if its adjusted too far out then its in default mode! the top of the pedal is slack and the bite point is literaly on the floor! sound like your problem???
__________________
Mk 3 Ibiza TDi Sport 110...ish! Take a look here: http://www.seatcupra.net/forums/showthread.php?t=214257 |
#13 |
Banned
and where would u locate the adjuster
#14 |
Senior Member
if its the problem you will need to remove the lower scuttle panel, at the top of the pedal (well under the dash!) will be a black box with a wire on it and a small white plunger that touches it! it is screwed into a bracket, when the pedal snaps it usualy rips the thread off and knocks it out of adjustment! (made of plastic) just screw it in or out to adjust!
__________________
#15 |
Banned
is it a white sensor thing wich pushes in and out is it a white thing
#16 |
Senior Member
i think so! the pedal arm rests on it!
__________________
#17 |
Power, Beauty, Soul
i had teh same problem and it turned out the pedal box was broken, dont know if that helps
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 45
| A.m.C_Ibiza1, AaronGS, Alex.j.89, Alf Hucker, andy_tratter, AngryAlan, Atlantia, bditai, Blucupra, BoardTracker, Brego, ChrisCurzon, chrissy1502002, cupra87, dai cupra, Dan1.6, davidsonley1, daza b cupra, egypt, EZ Tutty, greg, ian_cupra, Ibiza125, Jordan22, kieran cupra, kyle'87, lm_gauci, loveturbopower, mitch2028, mt audio, Myki da Pyki, phil8vgti, Pidge, r2d2hp, raymondk, Razor, Reuvers, Ricardo_Smooth, s20ty c, Sandy1985, SeanyK, SidewaysCupra, ttothec, turbo009, __B3NNY__ |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Clutch pedal problem | Danpongetti | Ibiza Mk3 | 6 | 13-09-2008 14:55 |
| clutch pedal noise??? | loveturbopower | Ibiza Mk3 | 5 | 04-06-2008 08:29 |
| strange clutch pedal | gazman | Ibiza Mk4 | 4 | 22-05-2008 18:07 |
| Vibrating clutch pedal! | Neel-Cupra | Ibiza Mk3 | 0 | 08-04-2008 17:40 |
